Hi All,
I downloaded the bundle, ran the console, and tried installing the drivers. It wasn't clear if it ran correctly, but regardless, I went into the dirs and right right-clicked installed on all the INFs to be sure. I'm pretty sure the bat file is failing on privilege escalation, where I do click yes, but nothing happens on Windows 11.
So after it is seemingly installed, I don't see any new comports in the device manager, which leads me to believe it's not installed, when I click Pcan, it says no drivers installed. When I open TS, it can not find any ports to connect to, probably because there is no virtual hardware on any port that I see.
Does this not work on Windows 11?
