seems a tad bit out of date, and I cant get it to work for the life of me.
I continue to get this error
Tried it on two separate windows 7 Machines.
java.lang.IllegalStateException: Failed to connect to simulator
at com.rusefi.io.tcp.TcpConnector.connect(TcpConnector.java:93)
at com.rusefi.io.LinkManager.open(LinkManager.java:98)
at com.rusefi.Launcher.windowOpenedHandler(Launcher.java:204)
at com.rusefi.Launcher.access$100(Launcher.java:40)
at com.rusefi.Launcher$2.onWindowOpened(Launcher.java:95)
at com.rusefi.ui.util.FrameHelper$1.windowOpened(FrameHelper.java:36)
at java.awt.AWTEventMulticaster.windowOpened(Unknown Source)
at java.awt.Window.processWindowEvent(Unknown Source)
at javax.swing.JFrame.processWindowEvent(Unknown Source)
at java.awt.Window.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$400(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at com.rusefi.io.tcp.TcpConnector.connect(TcpConnector.java:88)
... 32 more
And then trying to connect to tunerstudio is a completely separate ordeal. With the latest version it connects then disconnects once per second.
When downgrading to ~v2.6.01 it corrupts the project files before they are made.
Hopefully someone on here will show me the way.
