I made this Lua, which I have succesfully driven on to control a 4R70W
Right now it has Intended vs Desired checking, Downshift RPM lockout, and uses two seperate shift tables which have TPS on X axis, and shift direction on Y axis (logic I copied from GM OEM tunes). It has a few other features which you cna paste the code in Gemini and it'll properly comment the code more lol, but here it is; later I will update with videos of the truck i'm using running
-- TCU Lua Script: Normal var names, Corrected VSS logic, Toggleable filters
-- Configuration Flags (Manually change for testing)
local enableVssSpikeFilter = false -- Set to false to disable VSS spike filtering
local enableGearErrorCheck = false -- Set to false to disable gear match error detection
-- Sensor Declarations
local cltSensor = Sensor.new("Clt")
local rpmSensor = Sensor.new("Rpm")
local mapSensor = Sensor.new("Map")
local tps1Sensor = Sensor.new("Tps1")
local vehicleSpeedSensor = Sensor.new("VehicleSpeed")
local inputShaftSpeedSensor = Sensor.new("InputShaftSpeed")
local detectedGearSensor = Sensor.new("DetectedGear")
-- Sensor Timeouts
local SENSOR_TIMEOUT_MS = 3000
cltSensor:setTimeout(SENSOR_TIMEOUT_MS)
rpmSensor:setTimeout(SENSOR_TIMEOUT_MS)
mapSensor:setTimeout(SENSOR_TIMEOUT_MS)
tps1Sensor:setTimeout(SENSOR_TIMEOUT_MS)
vehicleSpeedSensor:setTimeout(SENSOR_TIMEOUT_MS)
inputShaftSpeedSensor:setTimeout(SENSOR_TIMEOUT_MS)
detectedGearSensor:setTimeout(SENSOR_TIMEOUT_MS)
-- Core State Variables
local IntendedGear = 3
local initialDataReceived = false
local lastKnownRawVss = nil -- Raw VSS after idle override, before scaling (used by spike filter & print)
local lastSetVehicleSpeed = 0.0 -- Scaled VSS value that was last set to the firmware sensor
local idleStateForcedInLastCanCycle = false
-- PWM Configuration
local SOLENOID_A_PWM_INDEX = 0
local SOLENOID_B_PWM_INDEX = 1
local PWM_FREQUENCY = 10
-- Solenoid State Strings for Printing
local solenoid_A_state_str = "OFF"
local solenoid_B_state_str = "OFF" -- Will be correctly set during init by setSolenoidsForGear
-- Shift Process Timers and Flags
local shift_in_progress_timer = Timer.new()
local is_shifting = false
local gearMatchTimer = Timer.new()
local is_checking_gear_match = false
local shiftErrorActive = false
local printStatusTimer = Timer.new()
-- User-Configurable Settings (loaded in init, using normal length Lua variable names)
local wotTpsThresholdSetting
local shiftExecutionTimeSecondsSetting
local downshiftLockoutRpmSetting
local gearMatchTimeoutSecondsSetting
local numberOfGearSolenoidsSetting
-- Table and Curve Indices (loaded in init)
local upshiftScheduleTableIndex
local downshiftScheduleTableIndex
local wotRpmCurveIndex
local solenoidPatternCurveIndex
-- Helper: Get 16-bit unsigned value from CAN data (Big Endian based on your usage)
function getTwoBytesUnsignedLsb(data, startIndex)
local msb = data[startIndex]
local lsb = data[startIndex + 1]
if msb == nil or lsb == nil then return 0 end
return lsb + (msb * 256)
end
-- Helper: Get signed byte
function getSignedByte(rawValue)
if rawValue > 127 then return rawValue - 256
else return rawValue end
end
-- Helper: Command solenoids based on pattern from "solPattern" curve
function setSolenoidsForGear(targetGear)
if solenoidPatternCurveIndex == nil then
print("ERR: solPattern Idx nil")
if numberOfGearSolenoidsSetting >= 1 then setPwmDuty(SOLENOID_A_PWM_INDEX, 0.0); solenoid_A_state_str = "OFF" end
if numberOfGearSolenoidsSetting >= 2 then setPwmDuty(SOLENOID_B_PWM_INDEX, 0.0); solenoid_B_state_str = "OFF" end
return
end
local patternCode = curve(solenoidPatternCurveIndex, targetGear)
if patternCode == nil then
print("WARN: No solPattern for gear " .. targetGear)
patternCode = 0
end
patternCode = math.floor(patternCode)
local tempPattern = patternCode
-- Solenoid A
local solA_duty = 0.0
if numberOfGearSolenoidsSetting == 1 then
if tempPattern == 1 then solA_duty = 1.0 end
elseif numberOfGearSolenoidsSetting == 2 then
if math.floor(tempPattern / 10) == 1 then solA_duty = 1.0 end
elseif numberOfGearSolenoidsSetting == 3 then
if math.floor(tempPattern / 100) == 1 then solA_duty = 1.0 end
end
setPwmDuty(SOLENOID_A_PWM_INDEX, solA_duty)
solenoid_A_state_str = (solA_duty == 1.0) and "ON" or "OFF"
else
solenoid_A_state_str = "N/A"
end
-- Solenoid B
local solB_duty = 0.0
if tempPattern % 10 == 1 then solB_duty = 1.0 end
if math.floor((tempPattern % 100) / 10) == 1 then solB_duty = 1.0 end
end
setPwmDuty(SOLENOID_B_PWM_INDEX, solB_duty)
solenoid_B_state_str = (solB_duty == 1.0) and "ON" or "OFF"
else
solenoid_B_state_str = "N/A"
end
end
-- Initialization Function
function initializeShiftLogic()
-- Load user settings using shortened camelCase names for findSetting
wotTpsThresholdSetting = findSetting("wotTps", 90.0)
local shiftExecutionTimeMsSetting = findSetting("shiftTime", 500)
shiftExecutionTimeSecondsSetting = shiftExecutionTimeMsSetting / 1000.0
downshiftLockoutRpmSetting = findSetting("dsLockRpm", 7000)
local gearMatchTimeoutMsSetting = findSetting("gearMatch", 3000)
gearMatchTimeoutSecondsSetting = gearMatchTimeoutMsSetting / 1000.0
numberOfGearSolenoidsSetting = findSetting("numGearSol", 2)
-- Load table and curve indices using shortened camelCase names
upshiftScheduleTableIndex = findTableIndex("upSched")
downshiftScheduleTableIndex = findTableIndex("downSched")
wotRpmCurveIndex = findCurveIndex("wotRpm")
solenoidPatternCurveIndex = findCurveIndex("solPattern")
if upshiftScheduleTableIndex == nil or downshiftScheduleTableIndex == nil or wotRpmCurveIndex == nil or solenoidPatternCurveIndex == nil then
print("ERR: Table/Curve nil")
end
if numberOfGearSolenoidsSetting >= 1 then startPwm(SOLENOID_A_PWM_INDEX, PWM_FREQUENCY, 0.0) end
if numberOfGearSolenoidsSetting >= 2 then startPwm(SOLENOID_B_PWM_INDEX, PWM_FREQUENCY, 0.0) end
setSolenoidsForGear(IntendedGear) -- Set solenoids to initial IntendedGear (3rd)
printStatusTimer:reset()
end
-- onCanRx: Callback for received CAN messages
function onCanRx(bus, id, dlc, data)
if id == 0x360 then -- RPM, MAP, TPS
rpmSensor:set(getTwoBytesUnsignedLsb(data, 1))
mapSensor:set(getTwoBytesUnsignedLsb(data, 3) / 10.0)
tps1Sensor:set(getTwoBytesUnsignedLsb(data, 5) / 10.0)
elseif id == 0x3E0 then -- Coolant Temp
cltSensor:set(getTwoBytesUnsignedLsb(data, 1) / 100.0)
elseif id == 0x470 then -- ECU Transmitted Gear Data
local rawGearValue = data[8]
if rawGearValue ~= nil then
local actualGear = getSignedByte(rawGearValue)
detectedGearSensor:set(actualGear)
end
elseif id == 0x370 then -- Vehicle Speed, and main shift logic trigger
idleStateForcedInLastCanCycle = false -- Reset per 0x370 cycle
local newRawVssFromCan = getTwoBytesUnsignedLsb(data, 1)
local processedRawVss = newRawVssFromCan -- This will hold raw VSS after idle forcing
local currentFinalVehicleSpeed -- This will hold scaled VSS after spike filter & idle forcing
local forceIdleState = false -- True if idle conditions (low RPM/TPS) are met
-- One-time check for initial sensor data
if not initialDataReceived then
if getSensor("Rpm") ~= nil and getSensor("Tps1") ~= nil and newRawVssFromCan ~= nil then
initialDataReceived = true
end
end
local currentRpm = getSensor("Rpm")
local currentTps = getSensor("Tps1")
-- Force VSS to 0 if idle-like conditions met
if currentRpm ~= nil and currentTps ~= nil then
if currentRpm < 1300 and currentTps < 1.0 then
processedRawVss = 0 -- Force the VSS value used for logic to 0
forceIdleState = true
idleStateForcedInLastCanCycle = true
end
end
-- VSS Spike Filter (conditionally active)
local useLastSpeedDueToSpike = false
if enableVssSpikeFilter then
if lastKnownRawVss ~= nil and processedRawVss ~= nil and math.abs(processedRawVss - lastKnownRawVss) > 100 then
useLastSpeedDueToSpike = true
end
end
if useLastSpeedDueToSpike then
currentFinalVehicleSpeed = lastSetVehicleSpeed -- Use last scaled VSS
-- lastKnownRawVss is NOT updated with the spiky processedRawVss
elseif processedRawVss ~= nil then
currentFinalVehicleSpeed = processedRawVss -- Scale the (potentially overridden) raw VSS
lastKnownRawVss = processedRawVss -- Store the raw (but potentially overridden) value
else
currentFinalVehicleSpeed = lastSetVehicleSpeed -- Fallback
end
vehicleSpeedSensor:set(currentFinalVehicleSpeed)
inputShaftSpeedSensor:set(currentFinalVehicleSpeed)
lastSetVehicleSpeed = currentFinalVehicleSpeed
-- Check "Shift In Progress" Timer
if is_shifting then
if shift_in_progress_timer:getElapsedSeconds() >= shiftExecutionTimeSecondsSetting then
is_shifting = false
end
end
-- High Priority: Force to 1st gear if idle state is active and not already in 1st/shifting
if forceIdleState and IntendedGear ~= 1 and not is_shifting then
IntendedGear = 1
is_shifting = true; shift_in_progress_timer:reset()
is_checking_gear_match = true; gearMatchTimer:reset()
end
-- Main Shift Decision Logic: Only if not shifting, data received, tables loaded
if not is_shifting and initialDataReceived and
upshiftScheduleTableIndex ~= nil and downshiftScheduleTableIndex ~= nil and
wotRpmCurveIndex ~= nil and solenoidPatternCurveIndex ~= nil then
currentRpm = getSensor("Rpm") -- Re-fetch for current values
if currentRpm == nil or currentTps == nil then
-- Skip if essential sensor data still missing for this cycle
else
local isWOT = (currentTps >= wotTpsThresholdSetting)
local newPotentialDesiredGear = IntendedGear
-- 1. WOT Upshift
if isWOT and IntendedGear < 4 then
local wotTargetRpm = curve(wotRpmCurveIndex, IntendedGear)
if wotTargetRpm ~= nil and currentRpm >= wotTargetRpm then
newPotentialDesiredGear = IntendedGear + 1
end
end
-- 2. Table Downshift (if no WOT upshift)
if newPotentialDesiredGear == IntendedGear and IntendedGear > 1 then
local yAxis = IntendedGear
local targetVss = table3d(downshiftScheduleTableIndex, currentTps, yAxis)
if targetVss ~= nil and currentFinalVehicleSpeed <= targetVss and currentRpm <= downshiftLockoutRpmSetting then
newPotentialDesiredGear = IntendedGear - 1
end
end
-- 3. Table Upshift (if no WOT upshift or downshift)
if newPotentialDesiredGear == IntendedGear and IntendedGear < 4 then
local vssForTableLookup = currentFinalVehicleSpeed
if currentRpm < 1200 then vssForTableLookup = 0.0 end -- RPM override for VSS in table lookup
local targetVss = table3d(upshiftScheduleTableIndex, currentTps, yAxis)
if targetVss ~= nil and vssForTableLookup >= targetVss then
end
end
-- Shift Execution
if newPotentialDesiredGear ~= IntendedGear and newPotentialDesiredGear >= 1 and newPotentialDesiredGear <= 4 then
IntendedGear = newPotentialDesiredGear
end
end
end
end
end
canRxAdd(0x360); canRxAdd(0x3E0); canRxAdd(0x370); canRxAdd(0x470) -- 0x470 is added in initializeShiftLogic
-- onTick: Called periodically by TCU firmware
function onTick()
-- Check "Gear Match" Timer (conditionally active)
if enableGearErrorCheck and is_checking_gear_match then
local actualGear = getSensor("DetectedGear")
if actualGear ~= nil and IntendedGear == actualGear then
elseif gearMatchTimer:getElapsedSeconds() >= gearMatchTimeoutSecondsSetting then
shiftErrorActive = true
end
elseif not enableGearErrorCheck and is_checking_gear_match then
end
-- Periodic Status Print (every 500ms)
if printStatusTimer:getElapsedSeconds() >= 0.5 then
if initialDataReceived then
local detectedGearString = "nil"; local detectedGearValue = getSensor("DetectedGear")
if detectedGearValue ~= nil then detectedGearString = detectedGearValue end
local rpmString = "nil"; local rpmValue = getSensor("Rpm")
if rpmValue ~= nil then rpmString = rpmValue end
local tpsString = "nil"; local tpsValue = getSensor("Tps1")
if tpsValue ~= nil then tpsString = tpsValue end
local lastKnownRawVssString = "nil"
if lastKnownRawVss ~= nil then lastKnownRawVssString = lastKnownRawVss end
local shiftErrorString = "N/A"
if enableGearErrorCheck then shiftErrorString = (shiftErrorActive and "TRUE" or "false") end
local isShiftingString = (is_shifting and "YES" or "no")
local idleForcedString = (idleStateForcedInLastCanCycle and "YES" or "no")
print("VSS:"..lastSetVehicleSpeed.."(Raw:"..lastKnownRawVssString..") RPM:"..rpmString.." TPS:"..tpsString..
" IGear:"..IntendedGear.." AGear:"..detectedGearString..
" SolA:"..solenoid_A_state_str.." SolB:"..solenoid_B_state_str..
" SErr:"..shiftErrorString.." Shft'ing:"..isShiftingString.." IdleFrc:"..idleForcedString)
end
end
end
setTickRate(100) -- 100 Hz
Oh and Gemini made most of this code, I take no real credit
