Firmware developent status
It's all about the code!
Post by puff »
5ms timeout?
puff wrote:
Sun Feb 19, 2023 11:36 am
5ms timeout?
Please use more words
Post by puff »
there seems to be a 5 ms pause between these two bytes - could be a timeout
puff wrote:
Sun Feb 19, 2023 6:05 pm
So we both see two bytes on the wire yet my code fails to read at least one byte. At the moment I would be happy to just read one byte. Not sure how is that 5ms relevant for my current cry for help to read one byte :(
Post by puff »
what's the schematics? which exactly wire is that? kline usually works at much higher levels (12v).
can it read bytes sent from usb-uart adapter?
Thank you!!! That's actually an amazing idea for me to try next.
It's https://github.com/rusefi/rusefi_documentation/raw/master/Hardware/Hellen/hellen125honda-a-schematic.pdf it already after the LIN transceiver so I show RX exactly how it goes into stm32. had to add a 1K pull-up since that's missing in the schematics at the moment
Post by puff »
"No LIN transceiver is fully compliant to the K-LINE, but compatible. You can see the difference from the document. So I think TJA1021 can work"
https://community.nxp.com/t5/MPC5xxx/TJA1021-K-LINE-compatibilty/td-p/550725
unfortunatelly, it's 403 for me.
rusEFI discovery, adafruit, secondary serial feature with perfect timing https://github.com/rusefi/rusefi/issues/5105 fix
9600 and 14400 works while 10400 does not work. Smells like uart configuration magic?!
Post by puff »
10400 is not supported by some usb-uart converters... (that's why people prefer ft232)
I got a chance to try my fake cheap eBay 16 channel logic analyzer! Looks like CP210x has performed as expected at 10400?
10400
9600
Post by puff »
you can tell for sure by measuring the length of the start bit probably.
still, didn't get: it doesn't work even when bytes are sent from the usb-uart dongle? so, it's a firmware bug?
puff wrote:
Sun Feb 19, 2023 11:06 pm
As a test step I've decided to run proven and known to work TS protocol at 10400 not k-line connector. And at the moment TS protocol does NOT run at 10400 which makes me stretch my head and post https://forum.chibios.org/viewtopic.php?f=16&t=6194 wondering if I can blame stm32 or ChibiOS
please use a dedicated thread instead of clogging a pinned announcement thread
mck1117 wrote:
Sun Feb 19, 2023 11:12 pm
What pinned thread? What announcement thread?
Wow just wow.
The fix for https://github.com/rusefi/rusefi/issues/5354 turned out to be https://github.com/rusefi/rusefi/commit/1e43299eab2b2af033cb79d03446dbf07e4bd2c3
F4 does not seem to care. F7 cares deeply but compiled only throws us under the train at -Os optimization level.
Kudos @dron_gus for fixing.
Anyone with a Bluetooth board interested to test https://github.com/rusefi/rusefi/issues/5927?
Time flies - it has been over three years since @mck1117 has contributed that amazing performance tracing!
@andreika has just fixed a defect reviving it and I've added a touch of usability.
I have some questions around high frequency CANbus processing with Lua let's see if PTrace would be the magic tool.
@dbh97 has revamped the build scripts! I expect way less broken local proteus builds now.
ADC sample value just a bit above 12 bits, that's not what one would expect from stm32f7?
Do we have a wild memory overrun which just happens to touch ADC region? Are we not good at reading that ADC app note? Else?
That's https://github.com/rusefi/rusefi/issues/6376
AndreyB wrote:
Mon Apr 22, 2024 11:49 pm
Status update:
* finally I am able to reproduce on the bench, vehicle not required
* looks like SD card has to be logging for the issue to occur. Wow, we have some sort of a connection between SD card and ADC?!
* so far I can reproduce only on one type of PnP board
Another surprise - USB CDC ACM and 64 bytes transaction - https://forum.chibios.org/viewtopic.php?f=35&t=6395
Roman has added J30 trigger support
https://github.com/rusefi/rusefi/wiki/All-Supported-Triggers#honda-j30
That recent SD card report logger is doing the job! Got first report of hard fault in the field https://github.com/rusefi/rusefi/issues/7623
Yet another trigger, yet another struggle
Desperately need help see https://github.com/rusefi/rusefi/issues/7946 and https://github.com/rusefi/rusefi/issues/7947
