Lua Scripting
Lua Scripting
Re: Lua Scripting
I assume that at some point FSIO would be completely removed? https://github.com/rusefi/rusefi/issues/2928
Re: Lua Scripting
New method: https://github.com/rusefi/rusefi/wiki/Lua-Scripting#readpinpinname
Working on Lua auxiliary analog inputs at the moment.
Re: Lua Scripting
the following works now
function onTick()
auxV = getAuxAnalog(0)
print('Hello analog ' .. auxV)
endVery limited telepathic abilities - please post logs & tunes where appropriate - http://rusefi.com/s/questions
Re: Lua Scripting
here's the most advanced rusEFI Lua script I am currently capable of:
there are two problems
1) "t.reset(t);" mentioning "t" twice is a bit weird
and more importantly
2) if I attempt to change "2" into "2.5" we get
t = Timer.new();
function onTick()
if auxV > 2 then
t.reset(t);
end
val = t.getElapsedSeconds(t);
print('Hello analog ' .. auxV .. " " .. val)
end
2021-09-18_17_29_36_863: EngineState: LUA: Tearing down instance...
2021-09-18_17_29_36_864: EngineState: LUA loading script length: 193...
2021-09-18_17_29_36_865: EngineState: LUA ERROR loading script: not enough memory
2021-09-18_17_29_36_865: EngineState: LUA: Tearing down instance...
2021-09-18_17_29_36_867: EngineState: Writing pending configuration...
Re: Lua Scripting
Apparently @mck1117 knows Lua syntax, no more mentioning same field twice.
t = Timer.new();
function onTick()
if auxV > 2 then
t:reset();
end
val = t:getElapsedSeconds();
Re: Lua Scripting
Some Lua progress:
We now have "Pid" class (todo make syntax less clunky
We now have six named curves - the idea is that one does not have to use a piece of paper to track magic curve indices
Similar names for tables are coming. I am still deciding how to approach input and output names best - I am not a huge fan of magic indices anywhere.
here's the my most advanced script to date:
startPwm(0, 800, 0.1)
-- direction
startPwm(1, 80, 1.0)
-- disable
startPwm(2, 80, 0.0)
pid = Pid.new()
pid:setP(2)
pid:setMinValue(-100)
pid:setMaxValue(100)
biasCurveIndex = findCurveIndex("bias")
function onTick()
local targetVoltage = getAuxAnalog(0)
local target = interpolate(1, 0, 3.5, 100, targetVoltage)
-- clamp 0 to 100
target = math.max(0, target)
target = math.min(100, target)
print('Decoded target: ' .. target)
local tps = getSensor("TPS1")
tps = (tps == nil and 'invalid TPS' or tps)
print('Tps ' .. tps)
pid:setTarget(target)
local output = pid:get(tps)
local bias = curve(biasCurveIndex, target)
print('bias ' .. bias)
print('pid output ' .. output)
local duty = (bias + output) / 100
isPositive = duty > 0;
pwmValue = isPositive and duty or -duty
setPwmDuty(0, pwmValue)
dirValue = isPositive and 1 or 0;
setPwmDuty(1, dirValue)
print('pwm ' .. pwmValue .. ' dir ' .. dirValue)
print('')
end
Re: Lua Scripting
One open question is indexing convention.
In TS we clearly go curves 1 to 6 and tables 1 to 4, not 0 to 5 and 0 to 3.
In addition Lua array indexing is from 1
With that it's obvious to me that findCurveIndex has to return 1-base index. As a consequence, curve function would have to accept same 1-base index?
Re: Lua Scripting
A demo of where rusEFI Lua is today (hint: it's pretty cool nowadays)
Small microRusEFI runs
larger Proteus runs
txPayload = {}
function onTick()
print('Hello analog ' .. auxV )
-- first byte: integer part, would be autoboxed to int
txPayload[1] = auxV
-- second byte: fractional part, would be autoboxed to int, overflow would be ignored
txPayload[2] = auxV * 256;
auxV = getAuxAnalog(1)
txPayload[3] = auxV
txPayload[4] = auxV * 256;
auxV = getAuxAnalog(2)
txPayload[5] = auxV
txPayload[6] = auxV * 256;
txCan(1, 0x600, 1, txPayload)
-- direction
-- disable
pid = Pid.new(2, 0, 0, -100, 100)
canRxAdd(0x600)
voltageFromCan = 0
function onCanRx(bus, id, dlc, data)
print('got CAN id=' .. id .. ' dlc=' .. dlc)
voltageFromCan = data[2] / 256.0 + data[1]
end
function onTick()
-- local target = interpolate(1, 0, 3.5, 100, targetVoltage)
local target = interpolate(1, 0, 3.5, 100, voltageFromCan)
-- clamp 0 to 100
local output = pid:get(target, tps)
print('')
end
mtmotorsport
Re: Lua Scripting
look at that new button!
nmstec
Re: Lua Scripting
It needs fixing. Its putting spaces between all characters. Seen in pic: "0 .02" "every50msTimer : getElapsedSeconds()"
"Dave B. 5:03 PM
Re: Lua Scripting
Thank you for the bug report! This should be fixed now.
mtmotorsport
Re: Lua Scripting
Is there a significant memory difference between MRE and Proteus? Reason for asking is my own relatively simple script and most of the example scripts cause a error loading script : not enough memory. Or is this something addressed with firmware? I tried the release firmware dated 2022.02.18 for MRE
Matt
MT Motorsport / EcotecMiata
Re: Lua Scripting
MRE is indeed set to allow less memory usage than Proteus for the Lua VM. I've just made a PR to increase the allocation for both MRE and Proteus.mtmotorsport wrote: ↑Sun Feb 27, 2022 10:00 pmIs there a significant memory difference between MRE and Proteus? Reason for asking is my own relatively simple script and most of the example scripts cause a error loading script : not enough memory. Or is this something addressed with firmware? I tried the release firmware dated 2022.02.18 for MRE
https://github.com/rusefi/rusefi/pull/3969
Re: Lua Scripting
Also, if you're willing to share your script somewhere, I can make some suggestions about how to reduce memory usage.
mtmotorsport
Re: Lua Scripting
This is what is currently loaded and it consumes 73% (10974/15000 bytes). Its a bit of a mess as I've been chopping and modifying it all day trying to get it to run. The print portion is purely to see that it runs.
Ideally I need it to send about 25 can messages once on boot, and ~6 at 1hz thereafter.
setTickRate(1)
local cm = 0
function onTick()
if cm == 0 then
txCan(1, 0x14EF1E11, 1, { 0x06, 0x6E, 0x0E, 0x6E, 0x2E, 0x6D, 0x6D, 0xFF })
txCan(1, 0x14EF1E11, 1, { 0x07, 0x6E, 0x6E, 0x6E, 0x1C, 0x2C, 0x6E, 0xFF })
txCan(1, 0x14EF1E11, 1, { 0x00, 0x01, 0xFF, 0x00, 0xFE, 0xFF, 0x00, 0xFF })
txCan(1, 0x14EF1E11, 1, { 0x00, 0x02, 0xFF, 0X00, 0xFE, 0xFF, 0x04, 0xFF })
txCan(1, 0x14EF1E11, 1, { 0x00, 0x03, 0x32, 0x01, 0xFC, 0xFF, 0x04, 0xFF })
print('hello can ')
cm = 1
else
print('hello can sent')
end
endMatt
Re: Lua Scripting
@mck1117 any interest in https://github.com/rusefi/rusefi/issues/3970
mtmotorsport
Re: Lua Scripting
I see the latest firmware has 25k of Lua memory available! That's great.
I can't see to find where whatever libraries are in use are listed. I'm a little new to Lua and just looking for ways to optimize my code.
Matt
Re: Lua Scripting
One day we should simply adjust MRE for F7 or H7 chips but that's not going to happen in 2022. On microRusEFI you cannot simply swap F4 for F7/H7 unfortunatellymtmotorsport wrote: ↑Thu Mar 03, 2022 7:06 pmI see the latest firmware has 25k of Lua memory available! That's great.
We only have math library attached at the moment that's because Lua libraries are pretty heavy
https://github.com/rusefi/rusefi/issues/3970 is the best hope for Lua MRE progress but not a huge priority. Let's see if you can get your stuff to work with current setup.
Re: Lua Scripting
This is the reference for the functions we've added: https://github.com/rusefi/rusefi/wiki/Lua-Scriptingmtmotorsport wrote: ↑Thu Mar 03, 2022 7:06 pmI can't see to find where whatever libraries are in use are listed. I'm a little new to Lua and just looking for ways to optimize my code.
This is the language reference for the "base language": https://www.lua.org/manual/5.4/
- Zeiss
- Github Username: HeinrichG-V12
Re: Lua Scripting
Hello Matt,
I will use a very small Lua script on my M70 to provide "driver requirement" for ASC/MSR and EGS as PWM signal. See this (below at Signal = DKV) and this (pseudo code! not quite finished yet).
In the list of sensors there is a sensor called DriverThrottleIntent. What is the unit of this sensor, is it percent, is it angle, what is it? And it is the correct sensor, which I need or should I use AcceleratorPedal instead?
Re: Lua Scripting
Driver Throttle Intent is a synthetic sensor that's simply multiplexed to either throttle position or pedal position, based on whether you have electronic throttles or not. There were places in the firmware that we needed to determine "is the driver pushing the pedal" not just "is the throttle open", so we added that fake sensor to map to whatever sensor is connected to the driver's foot. In your case, TPS means the actual throttle plate, AcceleratorPedal means the thing inside the cabin the human touches, and DriverThrottleIntent is a copy of AcceleratorPedal.Zeiss wrote: ↑Fri Mar 04, 2022 5:10 pmIn the list of sensors there is a sensor called DriverThrottleIntent. What is the unit of this sensor, is it percent, is it angle, what is it? And it is the correct sensor, which I need or should I use AcceleratorPedal instead?
All of the TPS-related channels output 0-100, 0 indicating closed throttle, and 100 indicating fully open.
- Zeiss
Re: Lua Scripting
Thank you very much for this explanation! I will then use the AcceleratorPedal sensor because EGS and ASC/MSR want a signal from the accelerator pedal, not the TPS.mck1117 wrote: ↑Fri Mar 04, 2022 8:53 pmDriver Throttle Intent is a synthetic sensor that's simply multiplexed to either throttle position or pedal position, based on whether you have electronic throttles or not. There were places in the firmware that we needed to determine "is the driver pushing the pedal" not just "is the throttle open", so we added that fake sensor to map to whatever sensor is connected to the driver's foot. In your case, TPS means the actual throttle plate, AcceleratorPedal means the thing inside the cabin the human touches, and DriverThrottleIntent is a copy of AcceleratorPedal.Zeiss wrote: ↑Fri Mar 04, 2022 5:10 pmIn the list of sensors there is a sensor called DriverThrottleIntent. What is the unit of this sensor, is it percent, is it angle, what is it? And it is the correct sensor, which I need or should I use AcceleratorPedal instead?
So I have to divide this value by 100 and put them into setPwmDuty.
Thank you!
mtmotorsport
Re: Lua Scripting
I'm able to add all 25 txCan config messages required, and then the txCan messages required for my PDM to turn on the fuel pumps, rad fans, ignition coils, etc. Where I seem to run out of memory is trying to read can message, compare two bytes, compile can message data packet and then tx this new can message. But I think it must be my lack of knowledge, because available memory drops by 10k trying to do this.AndreyB wrote: ↑Fri Mar 04, 2022 2:17 amOne day we should simply adjust MRE for F7 or H7 chips but that's not going to happen in 2022. On microRusEFI you cannot simply swap F4 for F7/H7 unfortunatellymtmotorsport wrote: ↑Thu Mar 03, 2022 7:06 pmI see the latest firmware has 25k of Lua memory available! That's great.
We only have math library attached at the moment that's because Lua libraries are pretty heavyon F4 we would probably not have more of these.
Matt
Re: Lua Scripting
plz paste your complete script on your build thread
Re: Lua Scripting
Someone has asked privately if PWM input is supported by Lua. Nope, not at the moment - it's probably possible just not implemented. RC filter and analog input could be a work around for now?
mtmotorsport
Re: Lua Scripting
Matt
mtmotorsport
Re: Lua Scripting
Another Lua question. This one is not specific to my car so perhaps this can help others out as well.
rxCan data received and printing as expected in console. What we would like to do is use this value from CAN message to look up another value in a Script Curve then txCan that looked up value.
I've attached screenshots, and the code. Any pointers?
-- READ CAN SENSOR
if id == 351211806 then
id1 = data [1]
if id1 == 128 then
tt1 = data[6] * 256.0 + data[5]
end
end
function transTemp ()
print("Trans Sensor---" ..tt1)
temp = findCurveIndex("gmtemp")
local tt = curve(temp, tt1)
print("Trans Temp?------------" ..tt)
end
Matt
Re: Lua Scripting
thank you for the report. latest firmware now asserts that X bins are in ascending order on start up
https://github.com/rusefi/rusefi/commit/95c3b0bca299fd9a5d888bf587be40e3a951db4a
