In the rare case you have a car that has no actual VSS, but need an idea of speed, this would be the future LUA script to do so.
SCRIPT GOES HERE
Info go here:
FIRST GEAR
22kph @1890 - 85.90
25kph @2189 - 87.56
31kph @2768 - 89.29
39kph @3497 - 89.66
49kph @4361 - 89.00
51kph @4595 - 90.09
OVERALL AVERAGE RPM/88.583
SECOND GEAR
27kph @1654 - 61.25
29kph @1777 - 61.27
33kph @2013 - 61
35kph @2172 - 62.05
40kph @2491 - 62.27
59kph @3760 - 63.72
68kph @4244 - 62.41
73kph @4597 - 62.97
OVERALL AVERAGE RPM/62.117
THIRD GEAR
31kph @1552 - 50.06
35kph @1763 - 50.37
39kph @1937 - 49.66
46kph @2325 - 50.54
53kph @2695 - 50.84
72kph @3778 - 52.47
85kph @4414 - 51.92
91kph @4672 - 51.34
OVERALL AVERAGE RPM/50.9
FOURTH GEAR
42kph @1787 - 42.54
47kph @1937 - 41.21
49kph @2052 - 41.87
53kph @2191 - 41.33
79kph @3433 - 43.45
91kph @3853 - 42.34
99kph @4233 - 42.75
OVERALL AVERAGE RPM/42.21
FIFTH GEAR
56kph @1969 - 35.16
59kph @2086 - 35.35
63kph @2239 - 35.53
76kph @2731 - 35.93
94kph @3419 - 36.37
101kph @3659 - 36.22
OVERALL AVERAGE RPM/35.76
SIXTH GEAR
70kph @1971 - 28.15
74kph @2118 - 28.62
80kph @2283 - 28.53
86kph @2464 - 28.65
105kph @3062 - 29.16
122kph @3345 - 27.41
OVERALL AVERAGE RPM/28.42
Calculate VSS with RPM vs GEAR position
nmstec
"Dave B. 5:03 PM
nmstec
Re: Calculate VSS with RPM vs GEAR position
Very true. But hey, Andrey says he wants this info saved, so I figure fuck it. Gear sensing AND A 30K sequential tranny lol
"Dave B. 5:03 PM
Show me your Lua
Do you already print speed into console? Did you try Lua PWM frequency?
nmstec
Haven't gotten to it yet, working slowly now. Was finishing up with the LSX.
"Dave B. 5:03 PM
nmstec
Basic write up at home, with 0 tests done, and voltage values pulled out of my very fine magical ass.
local gear = 0 --added for later usage and data logging
local vss = 0
local ratio = 0
function onTick()
rpm = getSensor("RPM")
gPos = getAuxAnalog(0)
if gPos < 0.7 then --Reverse
gear = 0--no fucks given
elseif gPos > 0.7 and gPos < 1.1 then --neutral
gear = 9--noone cares
elseif gPos > 1.1 and gPos < 1.6 then --1
ratio = 88.583
elseif gPos > 0.7 and gPos < 1.1 then --2
ratio = 62.117
elseif gPos > 1.1 and gPos < 1.7 then --3
ratio = 50.9
elseif gPos > 1.7 and gPos < 2.4 then --4
ratio = 42.21
elseif gPos > 2.4 and gPos < 3.0 then --5
ratio = 35.76
elseif gPos > 3.0 and gPos < 4.0 then --6
ratio = 28.42
end
if ratio > 0 then --hack to make sure never divide by 0. set to R
vss = rpm/ratio
else
vss = 0
end
print(vss)
end"Dave B. 5:03 PM
