[help needed] Does the new trigger need decoding? Kawasaki KX450F
This is an 18 tooth crankshaft. The starting RPM shows 0
Re: New trigger code request
Welcome to the forum!
You have to provide way more details for this to be a good question.
What vehicle is that? Do you have a picture of the trigger wheel? Are there any skipped tooth?
This is a kx450 engine. I plan to refit it on my motorcycle. This is a picture of the trigger wheel
Kawasaki KX450F
Progress!
Wheel clearly has one special tooth. Is that VR or Hall sensor? Your engine sniffer does not seem to show special tooth. Why do I see one special tooth on the photos but not on the engine sniffer image?
Yes, that seems like new trigger custom code. I can add once we gather more data.
Progress!
Well, actually I kind of see it on the engine sniffer
Re: Does the new trigger need decoding? Kawasaki KX450F
Yes, the trigger mode is VR sensor
One of the teeth on the trigger wheel is long,TDC is located behind this tooth
Done - please use latest firmware you should see new option in the drop down
ok, thank you very much
I have updated the firmware and used the trigger mode, but the startup rpm is still 0, and I found that TDC is behind the long teeth, but not before. Does the startup RPM display have anything to do with TDC?
tdc is not relevant for rpm
please try "inverted" setting
please turn on verbose trigger sync messages on TS and provide messages from console
Ooopppps, looks like I have not pushed all the changed publicly until an hour ago. Please update to latest one more time.
After I tried many times, starting RPM still didn't respond, and the trigger waveform was consistent. The latest firmware has been updated. But it has to be reset every time there is a power failure
There are two unrelated problems it looks to me:
1) something not great with writing settings, please start separate thread or write a video of how you write/burn settings, are you doing it while cranking? do you give ECU time to write with settings applied? hopefully your unit is not defective
2) please turn on "verbose trigger sync messages" on TunerStudio
Close TunerStudio, connect to rusEFI with rusEFI console - that's another tool from the bundle
in the "Messages" tab where would be a wall of text related to synchronization process. Please copy-paste that wall of text here.
2021-04-12_09_17_59_450: ConsoleUI: COMPOSITE_OFF_RPM=300
2021-04-12_09_18_01_189: EngineState: initHardware()
2021-04-12_09_18_01_190: EngineState: led: CRITICAL status on PE3
2021-04-12_09_18_01_190: EngineState: initRtc()
2021-04-12_09_18_01_191: EngineState: engine chart: No
2021-04-12_09_18_01_222: EngineState: Idle Valve on ext:TLE8888.OUT5
2021-04-12_09_18_01_222: EngineState: Fuel pump Relay on ext:TLE8888.OUT21
2021-04-12_09_18_01_222: EngineState: Fan Relay on ext:TLE8888.OUT22
2021-04-12_09_18_01_264: EngineState: READ mode=1 offset=15104 size=256
2021-04-12_09_18_01_264: EngineState: READ mode=1 offset=15360 size=256
2021-04-12_09_18_01_265: EngineState: READ mode=1 offset=15616 size=256
2021-04-12_09_18_01_265: EngineState: READ mode=1 offset=15872 size=256
2021-04-12_09_18_01_265: EngineState: READ mode=1 offset=16128 size=256
2021-04-12_09_18_01_265: EngineState: READ mode=1 offset=16384 size=256
2021-04-12_09_18_01_266: EngineState: READ mode=1 offset=16640 size=256
2021-04-12_09_18_01_266: EngineState: READ mode=1 offset=16896 size=256
2021-04-12_09_18_01_266: EngineState: READ mode=1 offset=17152 size=256
2021-04-12_09_18_01_267: EngineState: WRITE CHUNK mode=1 o=44 s=250
2021-04-12_09_18_01_270: EngineState: 1618219080 - unix time
2021-04-12_09_18_01_271: EngineState: WARNING: logging NULL
2021-04-12_09_18_01_271: EngineState: confirmation_set date 1618219080:19
2021-04-12_09_20_08_738: EngineState: got Query command
2021-04-12_09_20_08_739: EngineState: got S/H (queryCommand) mode=1
2021-04-12_09_20_08_740: EngineState: TunerStudio size=340 / total=19319 / errors=0 / H=3 / O=16021 / P=162 / B=2
2021-04-12_09_20_08_740: EngineState: TunerStudio W=0 / C=29 / P=1
2021-04-12_09_20_08_741: EngineState: 1618219208 - unix time
2021-04-12_09_20_08_746: EngineState: WARNING: logging NULL
2021-04-12_09_20_08_747: EngineState: confirmation_set date 1618219208:19
You are very close!!!
in rusEFI please execute "enable trigger_details" command which would get you more or less following text in "messages" area while you would be cranking
please post your "enable trigger_details" results here
2021-04-07_16_24_50_902: EngineState: TRG rpm=1378 time=66 index=0: gap=0.122 expected from 6.375 to 14.000 error=No
2021-04-07_16_24_50_912: EngineState: TRG duty 0.000000000 0
2021-04-07_16_24_50_912: EngineState: TRG rpm=1378 time=66 index=0: gap=1.557 expected from 0.349 to 0.980 error=No
2021-04-07_16_24_50_982: EngineState: TRG duty 0.000000000 0
2021-04-07_16_24_50_982: EngineState: TRG rpm=1378 time=66 index=0: gap=0.635 expected from 0.349 to 0.980 error=No
instead of "execute "enable trigger_details" command" you can select "print verbose sync" or something similar in trigger dialogs in TunerStudio.
But the text output goes to console only.
2021-04-12_10_45_19_875: EngineState: *** rusEFI LLC (c) 2012-2021. All rights reserved.
2021-04-12_10_45_19_876: EngineState: *** rusEFI v20210411@28917
2021-04-12_10_45_19_877: EngineState: *** Chibios Kernel: 6.1.3
2021-04-12_10_45_19_877: EngineState: *** Compiled: Apr 11 2021 - 03:36:47
2021-04-12_10_45_19_878: EngineState: *** COMPILER=9.3.1 20200408 (release)
2021-04-12_10_45_19_878: EngineState: UID=46001C 3036510E 31303437
2021-04-12_10_45_19_879: EngineState: rev=419 size=2048
2021-04-12_10_45_19_879: EngineState: CORTEX_MAX_KERNEL_PRIORITY=2
2021-04-12_10_45_19_879: EngineState: STM32_ADCCLK=21000000
2021-04-12_10_45_19_880: EngineState: STM32_TIMCLK1=84000000
2021-04-12_10_45_19_880: EngineState: STM32_TIMCLK2=168000000
2021-04-12_10_45_19_880: EngineState: STM32_PCLK1=42000000
2021-04-12_10_45_19_881: EngineState: STM32_PCLK2=84000000
2021-04-12_10_45_19_881: EngineState: PORT_IDLE_THREAD_STACK_SIZE=32
2021-04-12_10_45_19_882: EngineState: CH_DBG_ENABLE_ASSERTS=1
2021-04-12_10_45_19_882: EngineState: CH_DBG_SYSTEM_STATE_CHECK=1
2021-04-12_10_45_19_882: EngineState: CH_DBG_ENABLE_STACK_CHECK=1
2021-04-12_10_45_19_883: EngineState: EFI_LOGIC_ANALYZER=1
2021-04-12_10_45_19_883: EngineState: EFI_TUNER_STUDIO=1
2021-04-12_10_45_19_884: EngineState: EFI_SIGNAL_EXECUTOR_SLEEP=0
2021-04-12_10_45_19_884: EngineState: EFI_SIGNAL_EXECUTOR_HW_TIMER=0
2021-04-12_10_45_19_884: EngineState: EFI_SHAFT_POSITION_INPUT=1
2021-04-12_10_45_19_884: EngineState: EFI_INTERNAL_ADC=1
2021-04-12_10_45_19_884: EngineState: confirmation_hello:5
2021-04-12_10_45_24_515: EngineState: unexpected [jtrigger_details]
2021-04-12_10_45_24_516: EngineState: confirmation_enable jtrigger_details:23
2021-04-12_10_45_30_185: EngineState: TRG duty 0.000000000 208658117
2021-04-12_10_45_30_186: EngineState: TRG rpm=0 time=749 index=0: gap=336.927 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_188: EngineState: calc 0: action 103 value 749.00
2021-04-12_10_45_30_189: EngineState: calc 1: action 1 value 0.00
2021-04-12_10_45_30_190: EngineState: calc 2: action 5 value 1.00
2021-04-12_10_45_30_191: EngineState: calc 3: action 103 value 749.00
2021-04-12_10_45_30_192: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-12_10_45_30_192: EngineState: calc 5: action 2 value 0.00
2021-04-12_10_45_30_193: EngineState: calc 6: action 6 value 0.00
2021-04-12_10_45_30_193: EngineState: calc 7: action 127 value 0.03
2021-04-12_10_45_30_194: EngineState: calc 8: action 1 value 1.00
2021-04-12_10_45_30_194: EngineState: calc 9: action 2 value 1.00
2021-04-12_10_45_30_195: EngineState: calc 10: action 7 value 1.00
2021-04-12_10_45_30_195: EngineState: setPin pump on
2021-04-12_10_45_30_252: EngineState: TRG duty 0.000000000 208658117
2021-04-12_10_45_30_252: EngineState: TRG rpm=0 time=749 index=0: gap=0.012 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_335: EngineState: TRG duty 0.000000000 209170255
2021-04-12_10_45_30_335: EngineState: TRG rpm=0 time=749 index=0: gap=0.399 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_335: EngineState: TRG rpm=0 time=749 index=0: gap=0.719 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_335: EngineState: TRG duty 0.000000000 209317475
2021-04-12_10_45_30_336: EngineState: TRG rpm=0 time=749 index=0: gap=0.735 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_455: EngineState: TRG duty 0.000000000 209317475
2021-04-12_10_45_30_456: EngineState: TRG rpm=0 time=749 index=0: gap=0.826 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_457: EngineState: TRG duty 0.000000000 209407025
2021-04-12_10_45_30_458: EngineState: TRG rpm=0 time=749 index=0: gap=0.815 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_458: EngineState: TRG duty 0.000000000 209407025
2021-04-12_10_45_30_459: EngineState: TRG rpm=0 time=749 index=0: gap=0.857 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_459: EngineState: TRG duty 0.000000000 209469672
2021-04-12_10_45_30_460: EngineState: TRG rpm=0 time=749 index=0: gap=1.081 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_461: EngineState: TRG duty 0.000000000 209469672
2021-04-12_10_45_30_461: EngineState: TRG rpm=0 time=749 index=0: gap=0.923 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_560: EngineState: TRG duty 0.000000000 209532191
2021-04-12_10_45_30_561: EngineState: TRG rpm=0 time=749 index=0: gap=1.013 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_561: EngineState: TRG duty 0.000000000 209532191
2021-04-12_10_45_30_561: EngineState: TRG rpm=0 time=749 index=0: gap=0.943 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_561: EngineState: TRG duty 0.000000000 209591983
2021-04-12_10_45_30_562: EngineState: TRG rpm=0 time=749 index=0: gap=0.844 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_562: EngineState: TRG duty 0.000000000 209591983
2021-04-12_10_45_30_562: EngineState: TRG rpm=0 time=750 index=0: gap=1.339 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_562: EngineState: TRG duty 0.000000000 209659598
2021-04-12_10_45_30_563: EngineState: TRG rpm=0 time=750 index=0: gap=0.836 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_563: EngineState: TRG duty 0.000000000 209659598
2021-04-12_10_45_30_564: EngineState: TRG rpm=0 time=750 index=0: gap=0.983 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_564: EngineState: TRG duty 0.000000000 209715215
2021-04-12_10_45_30_564: EngineState: TRG rpm=0 time=750 index=0: gap=0.940 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_565: EngineState: TRG duty 0.000000000 209715215
2021-04-12_10_45_30_565: EngineState: TRG rpm=0 time=750 index=0: gap=1.047 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_634: EngineState: TRG duty 0.000000000 209769988
2021-04-12_10_45_30_634: EngineState: TRG rpm=0 time=750 index=0: gap=0.942 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_634: EngineState: TRG rpm=0 time=750 index=0: gap=1.018 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_634: EngineState: TRG duty 0.000000000 209822580
2021-04-12_10_45_30_635: EngineState: TRG rpm=0 time=750 index=0: gap=0.968 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_635: EngineState: TRG duty 0.000000000 209822580
2021-04-12_10_45_30_635: EngineState: TRG rpm=0 time=750 index=0: gap=1.029 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_635: EngineState: TRG duty 0.000000000 209875019
2021-04-12_10_45_30_635: EngineState: TRG rpm=0 time=750 index=0: gap=0.955 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_636: EngineState: TRG rpm=0 time=750 index=0: gap=1.023 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_636: EngineState: TRG duty 0.000000000 209926276
2021-04-12_10_45_30_636: EngineState: TRG rpm=0 time=750 index=0: gap=1.005 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_760: EngineState: TRG duty 0.000000000 209926276
2021-04-12_10_45_30_761: EngineState: TRG rpm=0 time=750 index=0: gap=0.964 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_761: EngineState: TRG duty 0.000000000 209976007
2021-04-12_10_45_30_762: EngineState: TRG rpm=0 time=750 index=0: gap=1.049 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_762: EngineState: TRG duty 0.000000000 209976007
2021-04-12_10_45_30_763: EngineState: TRG rpm=0 time=750 index=0: gap=0.949 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_763: EngineState: TRG duty 0.000000000 210025531
2021-04-12_10_45_30_764: EngineState: TRG rpm=0 time=750 index=0: gap=1.015 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_764: EngineState: TRG duty 0.000000000 210025531
2021-04-12_10_45_30_773: EngineState: TRG rpm=0 time=750 index=0: gap=0.951 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_773: EngineState: TRG duty 0.000000000 210073370
2021-04-12_10_45_30_774: EngineState: TRG rpm=0 time=750 index=0: gap=0.835 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_774: EngineState: TRG duty 0.000000000 210073370
2021-04-12_10_45_30_775: EngineState: TRG rpm=0 time=750 index=0: gap=1.362 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_775: EngineState: TRG duty 0.000000000 210127819
2021-04-12_10_45_30_775: EngineState: TRG rpm=0 time=750 index=0: gap=0.833 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_776: EngineState: TRG duty 0.000000000 210127819
2021-04-12_10_45_30_776: EngineState: TRG rpm=0 time=750 index=0: gap=1.025 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_861: EngineState: TRG duty 0.000000000 210174352
2021-04-12_10_45_30_861: EngineState: TRG rpm=0 time=750 index=0: gap=0.966 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_863: EngineState: TRG rpm=0 time=750 index=0: gap=1.060 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_863: EngineState: TRG duty 0.000000000 210222046
2021-04-12_10_45_30_863: EngineState: TRG rpm=0 time=750 index=0: gap=0.971 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_863: EngineState: TRG rpm=0 time=750 index=0: gap=1.061 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_863: EngineState: TRG duty 0.000000000 210271236
2021-04-12_10_45_30_864: EngineState: TRG rpm=0 time=750 index=0: gap=0.969 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_864: EngineState: TRG duty 0.000000000 210271236
2021-04-12_10_45_30_864: EngineState: TRG rpm=0 time=750 index=0: gap=1.029 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_866: EngineState: TRG duty 0.000000000 210320333
2021-04-12_10_45_30_866: EngineState: TRG rpm=0 time=750 index=0: gap=0.935 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_866: EngineState: TRG rpm=0 time=750 index=0: gap=0.961 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_938: EngineState: TRG duty 0.000000000 210364494
2021-04-12_10_45_30_938: EngineState: TRG rpm=0 time=750 index=0: gap=0.938 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_938: EngineState: TRG rpm=0 time=750 index=0: gap=0.920 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_939: EngineState: TRG duty 0.000000000 210402660
2021-04-12_10_45_30_939: EngineState: TRG rpm=0 time=750 index=0: gap=1.070 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_939: EngineState: TRG rpm=0 time=750 index=0: gap=1.038 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_939: EngineState: TRG duty 0.000000000 210445076
2021-04-12_10_45_30_939: EngineState: TRG rpm=0 time=750 index=0: gap=1.010 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_939: EngineState: TRG rpm=0 time=750 index=0: gap=1.001 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_940: EngineState: TRG duty 0.000000000 210487999
2021-04-12_10_45_30_940: EngineState: TRG rpm=0 time=750 index=0: gap=0.817 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_940: EngineState: TRG rpm=0 time=750 index=0: gap=1.422 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_941: EngineState: TRG duty 0.000000000 210537897
2021-04-12_10_45_30_941: EngineState: TRG rpm=0 time=750 index=0: gap=0.845 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_30_941: EngineState: TRG rpm=0 time=750 index=0: gap=1.001 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_062: EngineState: TRG duty 0.000000000 210580175
2021-04-12_10_45_31_063: EngineState: TRG rpm=0 time=750 index=0: gap=0.965 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_063: EngineState: TRG duty 0.000000000 210580175
2021-04-12_10_45_31_064: EngineState: TRG rpm=0 time=750 index=0: gap=1.047 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_064: EngineState: TRG duty 0.000000000 210622923
2021-04-12_10_45_31_065: EngineState: TRG rpm=0 time=750 index=0: gap=0.948 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_065: EngineState: TRG duty 0.000000000 210622923
2021-04-12_10_45_31_065: EngineState: TRG rpm=0 time=750 index=0: gap=1.043 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_065: EngineState: TRG duty 0.000000000 210665243
2021-04-12_10_45_31_065: EngineState: TRG rpm=0 time=750 index=0: gap=0.966 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_066: EngineState: TRG duty 0.000000000 210665243
2021-04-12_10_45_31_067: EngineState: TRG rpm=0 time=750 index=0: gap=1.052 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_067: EngineState: TRG duty 0.000000000 210708296
2021-04-12_10_45_31_067: EngineState: TRG rpm=0 time=750 index=0: gap=0.956 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_067: EngineState: TRG rpm=0 time=750 index=0: gap=1.019 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_067: EngineState: TRG duty 0.000000000 210750263
2021-04-12_10_45_31_067: EngineState: TRG rpm=0 time=750 index=0: gap=1.015 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_067: EngineState: TRG rpm=0 time=750 index=0: gap=0.976 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_139: EngineState: TRG duty 0.000000000 210791886
2021-04-12_10_45_31_139: EngineState: TRG rpm=0 time=750 index=0: gap=1.048 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_140: EngineState: TRG duty 0.000000000 210791886
2021-04-12_10_45_31_140: EngineState: TRG rpm=0 time=750 index=0: gap=0.944 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_140: EngineState: TRG duty 0.000000000 210833085
2021-04-12_10_45_31_140: EngineState: TRG rpm=0 time=750 index=0: gap=1.036 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_140: EngineState: TRG rpm=0 time=750 index=0: gap=0.967 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_140: EngineState: TRG duty 0.000000000 210874414
2021-04-12_10_45_31_140: EngineState: TRG rpm=0 time=750 index=0: gap=0.828 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_141: EngineState: TRG rpm=0 time=750 index=0: gap=1.375 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_141: EngineState: TRG duty 0.000000000 210921483
2021-04-12_10_45_31_141: EngineState: TRG rpm=0 time=750 index=0: gap=0.845 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_141: EngineState: TRG rpm=0 time=750 index=0: gap=1.041 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_141: EngineState: TRG duty 0.000000000 210962944
2021-04-12_10_45_31_141: EngineState: TRG rpm=0 time=750 index=0: gap=0.949 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_258: EngineState: TRG duty 0.000000000 210962944
2021-04-12_10_45_31_259: EngineState: TRG rpm=0 time=750 index=0: gap=1.068 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_260: EngineState: TRG duty 0.000000000 211005020
2021-04-12_10_45_31_260: EngineState: TRG rpm=0 time=750 index=0: gap=0.964 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_261: EngineState: TRG duty 0.000000000 211005020
2021-04-12_10_45_31_261: EngineState: TRG rpm=0 time=750 index=0: gap=1.071 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_261: EngineState: TRG duty 0.000000000 211048525
2021-04-12_10_45_31_262: EngineState: TRG rpm=0 time=750 index=0: gap=0.958 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_262: EngineState: TRG duty 0.000000000 211048525
2021-04-12_10_45_31_262: EngineState: TRG rpm=0 time=750 index=0: gap=1.046 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_263: EngineState: TRG duty 0.000000000 211092124
2021-04-12_10_45_31_263: EngineState: TRG rpm=0 time=750 index=0: gap=0.934 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_264: EngineState: TRG rpm=0 time=750 index=0: gap=0.984 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_264: EngineState: TRG duty 0.000000000 211132250
2021-04-12_10_45_31_264: EngineState: TRG rpm=0 time=750 index=0: gap=0.941 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_265: EngineState: TRG duty 0.000000000 211132250
2021-04-12_10_45_31_265: EngineState: TRG rpm=0 time=750 index=0: gap=0.934 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_265: EngineState: TRG duty 0.000000000 211167557
2021-04-12_10_45_31_266: EngineState: TRG rpm=0 time=750 index=0: gap=1.068 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_369: EngineState: TRG duty 0.000000000 211167557
2021-04-12_10_45_31_369: EngineState: TRG rpm=0 time=750 index=0: gap=1.033 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_372: EngineState: TRG duty 0.000000000 211206548
2021-04-12_10_45_31_372: EngineState: TRG rpm=0 time=750 index=0: gap=1.003 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_373: EngineState: TRG rpm=0 time=750 index=0: gap=1.007 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_374: EngineState: TRG duty 0.000000000 211245956
2021-04-12_10_45_31_375: EngineState: TRG rpm=0 time=750 index=0: gap=0.820 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_375: EngineState: TRG duty 0.000000000 211245956
2021-04-12_10_45_31_376: EngineState: TRG rpm=0 time=750 index=0: gap=1.425 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_376: EngineState: TRG duty 0.000000000 211292040
2021-04-12_10_45_31_377: EngineState: TRG rpm=0 time=750 index=0: gap=0.845 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_378: EngineState: TRG duty 0.000000000 211292040
2021-04-12_10_45_31_379: EngineState: TRG rpm=0 time=750 index=0: gap=1.015 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_379: EngineState: TRG duty 0.000000000 211331606
2021-04-12_10_45_31_380: EngineState: TRG rpm=0 time=750 index=0: gap=0.959 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_380: EngineState: TRG duty 0.000000000 211331606
2021-04-12_10_45_31_381: EngineState: TRG rpm=0 time=750 index=0: gap=1.041 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_381: EngineState: TRG duty 0.000000000 211371182
2021-04-12_10_45_31_382: EngineState: TRG rpm=0 time=750 index=0: gap=0.962 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_383: EngineState: TRG duty 0.000000000 211371182
2021-04-12_10_45_31_384: EngineState: TRG rpm=0 time=750 index=0: gap=1.053 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_450: EngineState: TRG duty 0.000000000 211411284
2021-04-12_10_45_31_450: EngineState: TRG rpm=0 time=750 index=0: gap=0.956 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_451: EngineState: TRG duty 0.000000000 211411284
2021-04-12_10_45_31_451: EngineState: TRG rpm=0 time=750 index=0: gap=1.049 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_451: EngineState: TRG duty 0.000000000 211451531
2021-04-12_10_45_31_452: EngineState: TRG rpm=0 time=750 index=0: gap=0.970 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_452: EngineState: TRG duty 0.000000000 211451531
2021-04-12_10_45_31_452: EngineState: TRG rpm=0 time=750 index=0: gap=1.012 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_453: EngineState: TRG duty 0.000000000 211491074
2021-04-12_10_45_31_453: EngineState: TRG rpm=0 time=750 index=0: gap=1.021 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_454: EngineState: TRG rpm=0 time=750 index=0: gap=0.963 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_454: EngineState: TRG duty 0.000000000 211529981
2021-04-12_10_45_31_455: EngineState: TRG rpm=0 time=750 index=0: gap=1.063 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_456: EngineState: TRG duty 0.000000000 211529981
2021-04-12_10_45_31_456: EngineState: TRG rpm=0 time=750 index=0: gap=0.943 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_457: EngineState: TRG duty 0.000000000 211568995
2021-04-12_10_45_31_457: EngineState: TRG rpm=0 time=750 index=0: gap=1.032 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_458: EngineState: TRG rpm=0 time=750 index=0: gap=0.966 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_555: EngineState: TRG duty 0.000000000 211607908
2021-04-12_10_45_31_556: EngineState: TRG rpm=0 time=750 index=0: gap=0.842 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_556: EngineState: TRG duty 0.000000000 211607908
2021-04-12_10_45_31_557: EngineState: TRG rpm=0 time=750 index=0: gap=1.364 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_557: EngineState: TRG duty 0.000000000 211652677
2021-04-12_10_45_31_558: EngineState: TRG rpm=0 time=750 index=0: gap=0.847 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_558: EngineState: TRG duty 0.000000000 211652677
2021-04-12_10_45_31_558: EngineState: TRG rpm=0 time=751 index=0: gap=1.086 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_559: EngineState: TRG duty 0.000000000 211693904
2021-04-12_10_45_31_559: EngineState: TRG rpm=0 time=751 index=0: gap=1.013 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_559: EngineState: TRG rpm=0 time=751 index=0: gap=1.124 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_560: EngineState: TRG duty 0.000000000 211740876
2021-04-12_10_45_31_560: EngineState: TRG rpm=0 time=751 index=0: gap=0.991 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_560: EngineState: TRG rpm=0 time=751 index=0: gap=1.129 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_560: EngineState: TRG duty 0.000000000 211793500
2021-04-12_10_45_31_561: EngineState: TRG rpm=0 time=751 index=0: gap=1.036 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_663: EngineState: TRG duty 0.000000000 211793500
2021-04-12_10_45_31_664: EngineState: TRG rpm=0 time=751 index=0: gap=1.111 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_664: EngineState: TRG duty 0.000000000 211854124
2021-04-12_10_45_31_665: EngineState: TRG rpm=0 time=751 index=0: gap=0.963 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_665: EngineState: TRG duty 0.000000000 211854124
2021-04-12_10_45_31_665: EngineState: TRG rpm=0 time=751 index=0: gap=0.952 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_666: EngineState: TRG duty 0.000000000 211909738
2021-04-12_10_45_31_666: EngineState: TRG rpm=0 time=751 index=0: gap=0.901 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_667: EngineState: TRG rpm=0 time=751 index=0: gap=0.900 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_667: EngineState: TRG duty 0.000000000 211954884
2021-04-12_10_45_31_667: EngineState: TRG rpm=0 time=751 index=0: gap=1.072 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_668: EngineState: TRG duty 0.000000000 211954884
2021-04-12_10_45_31_668: EngineState: TRG rpm=0 time=751 index=0: gap=1.079 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_764: EngineState: TRG duty 0.000000000 212007127
2021-04-12_10_45_31_765: EngineState: TRG rpm=0 time=751 index=0: gap=1.265 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_765: EngineState: TRG duty 0.000000000 212007127
2021-04-12_10_45_31_766: EngineState: TRG rpm=0 time=751 index=0: gap=1.263 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_766: EngineState: TRG duty 0.000000000 212090678
2021-04-12_10_45_31_766: EngineState: TRG rpm=0 time=751 index=0: gap=1.039 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_768: EngineState: TRG duty 0.000000000 212090678
2021-04-12_10_45_31_768: EngineState: TRG rpm=0 time=751 index=0: gap=1.681 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_31_860: EngineState: TRG duty 0.000000000 212236761
2021-04-12_10_45_31_861: EngineState: TRG rpm=0 time=751 index=0: gap=1.145 expected from 2.250 to 3.750 error=No
2021-04-12_10_45_32_388: EngineState: engine has STOPPED
2021-04-12_10_45_32_390: EngineState: templog engine has STOPPED 0.501528978
2021-04-12_10_45_32_390: EngineState: trigger ICU hw: 677 677 1
2021-04-12_10_45_32_391: EngineState: Template MICRO_RUS_EFI (60) trigger TT_TOOTHED_WHEEL_60_2 (8) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-12_10_45_32_392: EngineState: trigger#1 event counters up=0/down=677
2021-04-12_10_45_32_392: EngineState: expected cycle events 58/0/0
2021-04-12_10_45_32_393: EngineState: trigger type=8/need2ndChannel=No
2021-04-12_10_45_32_393: EngineState: expected duty #0=0.51/#1=0.00
2021-04-12_10_45_32_394: EngineState: synchronizationNeeded=Yes/isError=No/total errors=0 ord_err=0/total revolutions=0/self=No
2021-04-12_10_45_32_394: EngineState: gap from 2.25 to 3.75
2021-04-12_10_45_32_394: EngineState: VVT input: PA5 mode VVT_INACTIVE
2021-04-12_10_45_32_395: EngineState: VVT event counters: 0/0
2021-04-12_10_45_32_396: EngineState: primary trigger input: PC6
2021-04-12_10_45_32_396: EngineState: primary trigger simulator: NONE OM_DEFAULT freq=1200
2021-04-12_10_45_32_397: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-12_10_45_32_397: EngineState: primary logic input: NONE
2021-04-12_10_45_32_398: EngineState: secondary logic input: NONE
2021-04-12_10_45_32_398: EngineState: totalTriggerHandlerMaxTime=379
2021-04-12_10_45_32_893: EngineState: calc 0: action 103 value 752.00
2021-04-12_10_45_32_893: EngineState: calc 1: action 1 value 0.00
2021-04-12_10_45_32_894: EngineState: calc 2: action 5 value 1.00
2021-04-12_10_45_32_894: EngineState: calc 3: action 103 value 752.00
2021-04-12_10_45_32_895: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-12_10_45_32_895: EngineState: calc 5: action 2 value 0.00
2021-04-12_10_45_32_896: EngineState: calc 6: action 6 value 0.00
2021-04-12_10_45_32_896: EngineState: calc 7: action 127 value 1.00
2021-04-12_10_45_32_896: EngineState: calc 8: action 1 value 1.00
2021-04-12_10_45_32_897: EngineState: calc 9: action 2 value 0.00
2021-04-12_10_45_32_897: EngineState: calc 10: action 7 value 0.00
2021-04-12_10_45_32_898: EngineState: setPin pump off
My trigger decoder expect a higher magic gap once in a while - closer to 2.28
Maybe you need to flip your VR sensor wires or change the software settings to start responding to other front?
Please post your tune on rusEFI online
Have you figured our the "does not save settings" issue?
index=0: gap=1.00 expected from 1.50 to 2.50 error=No
index=0: gap=0.61 expected from 1.50 to 2.50 error=No
index=0: gap=2.28 expected from 1.50 to 2.50 error=No
index=0: gap=0.72 expected from 1.50 to 2.50 error=No
Just changed it a bit to "from 1.71 to 2.85" but that would not change anything for you, your values are way off what I expect. I could be wrong in my expectations.
The wire turnover of VR sensor has been tried, and the trigger signal has not changed. I still haven't solved the problem of unsaved settings. I have to reset them after power failure. This is my tuning file
I think it should be the setup problem of the tuner Studio software. When I run the software, I disconnect the power supply of the device and find that the settings have not changed. However, after I quit the software, I will be prompted that the current configuration conflicts with the previous configuration
I am really sorry but I really need the tune not attached but uploaded to https://rusefi.com/online
flipping VR wires probably maybe changes gap messages, I guess we will see once I can comfortably see your tune online.
I have uploaded the tune,I believe that the problem will be solved soon
https://rusefi.com/online/view.php?msq=487
I think I'm trapped. Now what do I need to do next
Please set "Display logic signals" to "true"
Please remove spark plugs, crank it long and post both engine sniffer image and "verbose trigger sync messages" text
At this point I have no idea what is wrong where.
2021-04-18_13_29_22_938: EngineState: TRG rpm=0 time=645 index=0: gap=1.023 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_22_939: EngineState: TRG duty 0.000000000 17947310
2021-04-18_13_29_22_939: EngineState: TRG rpm=0 time=645 index=0: gap=1.005 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_004: EngineState: TRG duty 0.000000000 17960804
2021-04-18_13_29_23_004: EngineState: TRG rpm=0 time=645 index=0: gap=0.979 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_007: EngineState: TRG duty 0.000000000 17973846
2021-04-18_13_29_23_010: EngineState: TRG rpm=0 time=645 index=0: gap=1.037 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_012: EngineState: TRG duty 0.000000000 17987378
2021-04-18_13_29_23_014: EngineState: TRG rpm=0 time=645 index=0: gap=0.955 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_015: EngineState: TRG duty 0.000000000 18000307
2021-04-18_13_29_23_015: EngineState: TRG rpm=0 time=645 index=0: gap=1.034 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_015: EngineState: TRG duty 0.000000000 18013450
2021-04-18_13_29_23_015: EngineState: TRG rpm=0 time=645 index=0: gap=0.974 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_015: EngineState: TRG duty 0.000000000 18026325
2021-04-18_13_29_23_016: EngineState: TRG rpm=0 time=645 index=0: gap=0.835 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_016: EngineState: TRG duty 0.000000000 18034723
2021-04-18_13_29_23_016: EngineState: TRG rpm=0 time=645 index=0: gap=1.402 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_016: EngineState: TRG duty 0.000000000 18051170
2021-04-18_13_29_23_016: EngineState: TRG rpm=0 time=645 index=0: gap=0.838 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_017: EngineState: TRG duty 0.000000000 18063972
2021-04-18_13_29_23_019: EngineState: TRG rpm=0 time=645 index=0: gap=1.051 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_022: EngineState: TRG duty 0.000000000 18077712
2021-04-18_13_29_23_022: EngineState: TRG rpm=0 time=645 index=0: gap=0.958 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_024: EngineState: TRG duty 0.000000000 18090299
2021-04-18_13_29_23_025: EngineState: TRG rpm=0 time=645 index=0: gap=1.020 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_025: EngineState: TRG duty 0.000000000 18103764
2021-04-18_13_29_23_025: EngineState: TRG rpm=0 time=645 index=0: gap=0.993 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_025: EngineState: TRG duty 0.000000000 18116901
2021-04-18_13_29_23_026: EngineState: TRG duty 0.000000000 18130134
2021-04-18_13_29_23_026: EngineState: TRG rpm=0 time=645 index=0: gap=0.981 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_026: EngineState: TRG duty 0.000000000 18143393
2021-04-18_13_29_23_026: EngineState: TRG rpm=0 time=645 index=0: gap=1.057 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_026: EngineState: TRG duty 0.000000000 18157253
2021-04-18_13_29_23_027: EngineState: TRG rpm=0 time=645 index=0: gap=0.953 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_104: EngineState: TRG duty 0.000000000 18170602
2021-04-18_13_29_23_104: EngineState: TRG rpm=0 time=645 index=0: gap=1.007 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_105: EngineState: TRG duty 0.000000000 18183743
2021-04-18_13_29_23_105: EngineState: TRG rpm=0 time=645 index=0: gap=0.981 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_105: EngineState: TRG duty 0.000000000 18196845
2021-04-18_13_29_23_106: EngineState: TRG rpm=0 time=645 index=0: gap=0.952 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_107: EngineState: TRG duty 0.000000000 18209249
2021-04-18_13_29_23_108: EngineState: TRG rpm=0 time=645 index=0: gap=1.059 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_109: EngineState: TRG duty 0.000000000 18222537
2021-04-18_13_29_23_110: EngineState: TRG rpm=0 time=645 index=0: gap=0.997 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_111: EngineState: TRG duty 0.000000000 18235960
2021-04-18_13_29_23_112: EngineState: TRG rpm=0 time=645 index=0: gap=1.098 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_113: EngineState: TRG duty 0.000000000 18250524
2021-04-18_13_29_23_113: EngineState: TRG rpm=0 time=645 index=0: gap=1.012 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_113: EngineState: TRG duty 0.000000000 18264983
2021-04-18_13_29_23_113: EngineState: TRG rpm=0 time=645 index=0: gap=0.820 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_113: EngineState: TRG duty 0.000000000 18274265
2021-04-18_13_29_23_113: EngineState: TRG rpm=0 time=645 index=0: gap=1.448 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_114: EngineState: TRG duty 0.000000000 18293237
2021-04-18_13_29_23_114: EngineState: TRG rpm=0 time=645 index=0: gap=0.868 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_114: EngineState: TRG duty 0.000000000 18308267
2021-04-18_13_29_23_114: EngineState: TRG rpm=0 time=645 index=0: gap=1.035 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_114: EngineState: TRG duty 0.000000000 18324081
2021-04-18_13_29_23_114: EngineState: TRG rpm=0 time=645 index=0: gap=0.973 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_114: EngineState: TRG duty 0.000000000 18339315
2021-04-18_13_29_23_116: EngineState: TRG rpm=0 time=645 index=0: gap=1.062 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_117: EngineState: TRG duty 0.000000000 18355783
2021-04-18_13_29_23_118: EngineState: TRG rpm=0 time=645 index=0: gap=0.965 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_207: EngineState: TRG duty 0.000000000 18371583
2021-04-18_13_29_23_208: EngineState: TRG rpm=0 time=645 index=0: gap=1.073 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_209: EngineState: TRG duty 0.000000000 18388333
2021-04-18_13_29_23_212: EngineState: TRG rpm=0 time=645 index=0: gap=0.985 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_216: EngineState: TRG duty 0.000000000 18404903
2021-04-18_13_29_23_216: EngineState: TRG rpm=0 time=645 index=0: gap=1.062 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_216: EngineState: TRG duty 0.000000000 18422784
2021-04-18_13_29_23_217: EngineState: TRG rpm=0 time=645 index=0: gap=0.968 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_217: EngineState: TRG duty 0.000000000 18440104
2021-04-18_13_29_23_217: EngineState: TRG rpm=0 time=645 index=0: gap=1.062 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_217: EngineState: TRG duty 0.000000000 18458114
2021-04-18_13_29_23_217: EngineState: TRG rpm=0 time=645 index=0: gap=1.015 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_218: EngineState: TRG duty 0.000000000 18476664
2021-04-18_13_29_23_220: EngineState: TRG rpm=0 time=645 index=0: gap=1.011 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_223: EngineState: TRG duty 0.000000000 18495164
2021-04-18_13_29_23_225: EngineState: TRG rpm=0 time=645 index=0: gap=1.070 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_226: EngineState: TRG duty 0.000000000 18515346
2021-04-18_13_29_23_226: EngineState: TRG rpm=0 time=645 index=0: gap=0.964 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_226: EngineState: TRG duty 0.000000000 18534679
2021-04-18_13_29_23_226: EngineState: TRG rpm=0 time=645 index=0: gap=1.064 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_226: EngineState: TRG duty 0.000000000 18554922
2021-04-18_13_29_23_227: EngineState: TRG rpm=0 time=645 index=0: gap=0.984 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_307: EngineState: TRG duty 0.000000000 18574847
2021-04-18_13_29_23_307: EngineState: TRG rpm=0 time=645 index=0: gap=0.857 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_308: EngineState: TRG duty 0.000000000 18588128
2021-04-18_13_29_23_309: EngineState: TRG rpm=0 time=645 index=0: gap=1.372 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_311: EngineState: TRG duty 0.000000000 18613939
2021-04-18_13_29_23_313: EngineState: TRG rpm=0 time=645 index=0: gap=0.845 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_316: EngineState: TRG duty 0.000000000 18633671
2021-04-18_13_29_23_318: EngineState: TRG rpm=0 time=645 index=0: gap=1.100 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_321: EngineState: TRG duty 0.000000000 18656529
2021-04-18_13_29_23_325: EngineState: TRG rpm=0 time=645 index=0: gap=1.036 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_325: EngineState: TRG duty 0.000000000 18677983
2021-04-18_13_29_23_325: EngineState: TRG rpm=0 time=645 index=0: gap=1.097 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_326: EngineState: TRG duty 0.000000000 18703957
2021-04-18_13_29_23_326: EngineState: TRG rpm=0 time=645 index=0: gap=0.975 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_326: EngineState: TRG duty 0.000000000 18729232
2021-04-18_13_29_23_327: EngineState: TRG rpm=0 time=645 index=0: gap=1.137 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_327: EngineState: TRG duty 0.000000000 18756808
2021-04-18_13_29_23_327: EngineState: TRG rpm=0 time=645 index=0: gap=1.021 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_413: EngineState: TRG duty 0.000000000 18785711
2021-04-18_13_29_23_413: EngineState: TRG rpm=0 time=645 index=0: gap=1.058 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_415: EngineState: TRG duty 0.000000000 18816318
2021-04-18_13_29_23_417: EngineState: TRG rpm=0 time=645 index=0: gap=0.984 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_419: EngineState: TRG duty 0.000000000 18845954
2021-04-18_13_29_23_424: EngineState: TRG rpm=0 time=645 index=0: gap=0.951 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_425: EngineState: TRG duty 0.000000000 18873117
2021-04-18_13_29_23_426: EngineState: TRG rpm=0 time=645 index=0: gap=0.907 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_426: EngineState: TRG duty 0.000000000 18898172
2021-04-18_13_29_23_426: EngineState: TRG rpm=0 time=645 index=0: gap=0.902 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_426: EngineState: TRG duty 0.000000000 18920722
2021-04-18_13_29_23_426: EngineState: TRG rpm=0 time=645 index=0: gap=1.063 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_426: EngineState: TRG duty 0.000000000 18945648
2021-04-18_13_29_23_427: EngineState: TRG rpm=0 time=645 index=0: gap=1.059 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_427: EngineState: TRG duty 0.000000000 18972751
2021-04-18_13_29_23_432: EngineState: TRG rpm=0 time=645 index=0: gap=1.243 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_512: EngineState: TRG duty 0.000000000 19006294
2021-04-18_13_29_23_512: EngineState: TRG rpm=0 time=645 index=0: gap=1.201 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_513: EngineState: TRG duty 0.000000000 19046459
2021-04-18_13_29_23_515: EngineState: TRG rpm=0 time=645 index=0: gap=0.854 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_517: EngineState: TRG duty 0.000000000 19073131
2021-04-18_13_29_23_521: EngineState: TRG rpm=0 time=645 index=0: gap=1.547 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_522: EngineState: TRG duty 0.000000000 19129945
2021-04-18_13_29_23_522: EngineState: TRG rpm=0 time=645 index=0: gap=0.931 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_614: EngineState: TRG duty 0.000000000 19177227
2021-04-18_13_29_23_614: EngineState: TRG rpm=0 time=645 index=0: gap=1.106 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_618: EngineState: TRG duty 0.000000000 19230896
2021-04-18_13_29_23_622: EngineState: TRG rpm=0 time=645 index=0: gap=1.086 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_623: EngineState: TRG duty 0.000000000 19288592
2021-04-18_13_29_23_625: EngineState: TRG rpm=0 time=645 index=0: gap=1.247 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_722: EngineState: TRG duty 0.000000000 19363293
2021-04-18_13_29_23_722: EngineState: TRG rpm=0 time=645 index=0: gap=1.209 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_23_722: EngineState: TRG duty 0.000000000 19456130
2021-04-18_13_29_23_722: EngineState: TRG rpm=0 time=645 index=0: gap=1.583 expected from 1.710 to 2.849 error=No
2021-04-18_13_29_24_236: EngineState: engine has STOPPED
2021-04-18_13_29_24_237: EngineState: templog engine has STOPPED 0.521905004
2021-04-18_13_29_24_240: EngineState: trigger ICU hw: 6731 6730 1
2021-04-18_13_29_24_245: EngineState: Template MICRO_RUS_EFI (60) trigger TT_KAWA_KX450F (57) useRiseEdge=Yes onlyFront=No useOnlyFirstChannel=No tdcOffset=0.00
2021-04-18_13_29_24_248: EngineState: trigger#1 event counters up=6730/down=6731
2021-04-18_13_29_24_251: EngineState: expected cycle events 36/0/0
2021-04-18_13_29_24_252: EngineState: trigger type=57/need2ndChannel=No
2021-04-18_13_29_24_255: EngineState: expected duty #0=0.82/#1=0.00
2021-04-18_13_29_24_256: EngineState: synchronizationNeeded=Yes/isError=No/total errors=0 ord_err=1/total revolutions=3/self=No
2021-04-18_13_29_24_256: EngineState: gap from 1.71 to 2.84
2021-04-18_13_29_24_257: EngineState: VVT input: PA5 mode VVT_INACTIVE
2021-04-18_13_29_24_258: EngineState: VVT event counters: 0/0
2021-04-18_13_29_24_258: EngineState: primary trigger input: PC6
2021-04-18_13_29_24_259: EngineState: primary trigger simulator: NONE OM_DEFAULT freq=1200
2021-04-18_13_29_24_259: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-18_13_29_24_266: EngineState: primary logic input: NONE
2021-04-18_13_29_24_272: EngineState: secondary logic input: NONE
2021-04-18_13_29_24_273: EngineState: totalTriggerHandlerMaxTime=381
2021-04-18_13_29_24_739: EngineState: calc 0: action 103 value 646.00
2021-04-18_13_29_24_740: EngineState: calc 1: action 1 value 0.00
2021-04-18_13_29_24_740: EngineState: calc 2: action 5 value 1.00
2021-04-18_13_29_24_741: EngineState: calc 3: action 103 value 646.00
2021-04-18_13_29_24_743: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-18_13_29_24_746: EngineState: calc 5: action 2 value 0.00
2021-04-18_13_29_24_749: EngineState: calc 6: action 6 value 0.00
2021-04-18_13_29_24_752: EngineState: calc 7: action 127 value 1.02
2021-04-18_13_29_24_755: EngineState: calc 8: action 1 value 1.00
2021-04-18_13_29_24_757: EngineState: calc 9: action 2 value 0.00
2021-04-18_13_29_24_757: EngineState: calc 10: action 7 value 0.00
2021-04-18_13_29_24_758: EngineState: setPin pump off
https://rusefi.com/forum/download/file.php?id=7328 is an example of what I expect to see with ""Display logic signals" to "true"" - instead of bars for signals I am hoping to see just the important lines.
Can you please attempt "Display logic signals" to "true" one more time?
