AndreyB wrote: ↑Wed Oct 28, 2020 9:14 am
amunozho wrote: ↑Wed Oct 28, 2020 8:32 am
Why the TunnerStudio shows 6V?
because rusEFI firmware expects same voltage divider on all analog inputs
if you do not have same dividers on all analog inputs (with exception of VBatt) you would need custom firmware to handle this custom hardware setup.
Thanks AndryB!!
I have changed the value of the analog divider ratio to 1.66V and CLT and IAT sensor show the temperature correctly.
But when I see the voltage raw, the voltage of the IAT is OK but the raw of voltage of the CLT is wrong:
[/url]
In my case, for the IAT and the CLT I have the same pull up resistor but the thermistor are diferent:
- IAT sensor is a 2K thermistor at 25ºC.
- CLT sensor is a 10K thermistor at 25ºC.
Here is the current view of my tunner Studio where you can see the volages of the sensors:
AndreyB when you said that we should need the same dividers, it means I need the same thermistors with the same resistance too and if we use different thermistors we need to change something at the sofware of the config.ini file of the TunnerStudio project or the rusEFI firmware. Is it correct?
Actually with this config, I can saw temperatures up to around 250ºC.
Again, thanks you very much!
