[README] End users, PLEASE subscribe to this topic - MAJOR firmware announcements
This thread is used to announce MAJOR firmware changes which could affect all users. Please subscribe if you use rusEfi.
A typical example of an announcement would be incompatible configuration change - in such cases you one cannot simply flash latest firmware but some kind of special considerations would be needed.
Re: End users, PLEASE subscribe to this topic - MAJOR firmware announcements
Just made an incompatible configuration change - please load&save&migrate your settings via TS while updating to latest version. This was about https://github.com/rusefi/rusefi/issues/688
trigger input code could be FUBAR at the moment, will update this post once https://github.com/rusefi/rusefi/issues/767 is fixed
https://github.com/rusefi/rusefi/issues/776 is hopefully an improvement which makes I and D term scale of all PID settings to use the right time scale, so all I and D pid settings would need to be adjusted accordingly.
We have changed the way some corrections are treated under https://github.com/rusefi/rusefi/issues/773 - so while migrating to latest the scale of configuration has changed.
Bumping configuration version to 1.06 to highlight the fact of incompatible change.
https://github.com/rusefi/rusefi/issues/805 "calibrate TPS" feature is now (hopefully) working again with Tuner Studio. Please use latest project .ini file.
Incompatible configuration change - https://github.com/rusefi/rusefi/commit/04bc1128dfb2d5cab3fdc7878298a939f5af4b1a
You would need to migrate configuration prior to 20190712 version migration: save settings in TunerStudio project & update mainController.ini file.
Idle air valve PID now has iTermMin/iTermMax settings, if you migrate to latest firmware you might need to manually set this value. min=-200 max=200 is a good starting point to have same behavior as previously. See https://github.com/rusefi/rusefi/issues/913
FSIO https://github.com/rusefi/rusefi/issues/922 incompatible change:
fan_on_setting is now cfg_fanOnTemperature
fan_off_setting is now cfg_fanOffTemperature
Please adjust your FSIO settings if you use these variables!
https://github.com/rusefi/rusefi/issues/796 is now fixed. This interesting defect mostly affects users with few tooth trigger wheels like Miata and similar Mitsubishi, mostly low RPM like cranking is affected - sometimes spark would not happen altogether. That's an important one unless you have a 36/1 or 60/2 trigger!
With https://github.com/rusefi/rusefi/pull/1029 stepper pin modes are now used - so if you had non-default mode configured behavior would now change!
We've made incompatible changes to TS gauges - data logging speed could go up with smaller data packet, but you would need to create new project if you update to latest firmware.
Configuration part of the project was not changed, only the gauges.
https://github.com/rusefi/rusefi/pull/1112 changes the way we handle TPS calibration, please re-calibrate your TPS.
We had a major defect since November 2019 - trigger sensors processing was inverted. This is now fixed https://github.com/rusefi/rusefi/issues/1176 - please update to latest firmware and maybe you would have to un-invert your settings.
That's a good point for a new release - https://github.com/rusefi/rusefi/releases
Going forward we should have a release every couple of months, with 6+ bundles attached to it.
We now have https://www.facebook.com/groups/rusEfi/
A lot of great progress in terms of documentation these days: work is definitely not finished and everyone is welcomed to contribute to https://github.com/rusefi/rusefi/wiki
See https://github.com/rusefi/rusefi/wiki/Documentation_Strategy
See https://github.com/rusefi/rusefi/wiki/Documentation_Workflow
Do you see that cute new icon on my profile? That's cool new community tools coming soon.
To get yourself the same icon you would need to to have your Engine Make and Engine Code fields filled in - those fields are available in the latest version of the firmware.
See https://github.com/rusefi/rusefi/wiki/Online
https://rusefi.com/online/ is now up & running!
Please use https://rusefi.com/online/ to share your logs for others to learn from you and while asking for advice.
CRITICAL DEFECT NOT FIXED YET: https://github.com/rusefi/rusefi/issues/1592
Depending on your tune and weather on Mars injector(s) could stay open during transitioning from cranking to running mode.
Current recommendation is to run the same fuel mode for cranking and running. For example, if running mode is sequential, run sequential for cranking too.AndreyB wrote: ↑Sun Jul 19, 2020 4:48 amCRITICAL DEFECT NOT FIXED YET: https://github.com/rusefi/rusefi/issues/1592
We believe that https://github.com/rusefi/rusefi/issues/1592 is resolved now
https://github.com/rusefi/rusefi/pull/1636 changes Alpha-N mode in a incompatible way. I assume no one was using legacy Alpha-N hopefully
- Slack: Orchardperformance
Our august release candidate is now available at the link below:
https://github.com/rusefi/rusefi/releases/tag/20200803
We have had releases for a while but it seems people were not aware of them so this month is the first time we are trying to make a bit more of an announcement of it.
Hopefully in the future we will be both publicising this more and providing a bit more in the way of user focus on the releases, long term goal of this is to provide default builds for users with any known bugs and a better idea of stability before they dive in and update the firmware.
Not exactly rusEFI issue - but if you are using Lite edition of TunerStudio you better upgrade to latest 3.1.04 in light of https://github.com/rusefi/rusefi/issues/1420 fix
Early October is the best time for September release, right?
3rd attempt at October release https://github.com/rusefi/rusefi/releases/tag/2020.10.11
See https://github.com/rusefi/rusefi/blob/master/firmware/CHANGELOG.md for future November release incompatible configuration changes
https://github.com/rusefi/rusefi/releases/tag/2020.11.27_release 2020 Black Friday release
All LS GM x24 trigger users: next release will have a breaking change https://github.com/rusefi/rusefi/issues/2054 you would have to substract 50 from "global trigger offset"
We have a change to rusEFI license https://github.com/rusefi/rusefi/commit/b914c8229edf7d363d15cb5428d9be0d6cd29ac8
