Thanks,I thought you are still using gcc 4.7russian wrote: ↑Sun Feb 10, 2019 4:08 amthe part about 2013 looks to be the problem. Please use current gnu arm 8 or recent gnu arm 7.3yyj876790646 wrote: ↑Sun Feb 10, 2019 2:59 amMy gcc version is cc version 4.7.3 20130312 (release) [ARM/embedded-4_7-branch revision 196615] (GNU Tools for ARM Embedded Processors)
At the moment I am using 7.3.1 20180622
[info] How to compile the firmware
Re: How to compile the firmware
- NormanAlphaspeed
- Contact:
the git submodule update --init does nothing for me, I only get
I disabled the first 8 lines of the rusefi.mk and obviously, got the same error as the people that were not running git submodule update --init
BTW, before that I got:
Over and over. I tried running the command manually and it just exits and does pretty much nothing.C:\Users\User\Downloads\rusefi-master\firmware>make
Invoking "git submodule update --init"
Invoked "git submodule update --init"
rusefi.mk:7: *** Please run 'make' again. Stop.
C:\Users\User\Downloads\oldrusefi\efi\firmware>git submodule update --init
fatal: not a git repository (or any parent up to mount point /cygdrive)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
AlphaX Auto Electronics
Tuned by AlphaSpeed
Tuned by AlphaSpeed
If you want to compile without having a git folder, you have to manually download the chibios and chibios contrib and put in the folders.NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 10:00 amthe git submodule update --init does nothing for me, I only getOver and over. I tried running the command manually and it just exits and does pretty much nothing.C:\Users\User\Downloads\rusefi-master\firmware>make
BTW, before that I got:C:\Users\User\Downloads\oldrusefi\efi\firmware>git submodule update --init
Have been fighting the firmware myself for a while.
- NormanAlphaspeed
- Contact:
I mean I'd compile it with a git folder... but how do I create it?960 wrote: ↑Tue Feb 12, 2019 1:50 pmIf you want to compile without having a git folder, you have to manually download the chibios and chibios contrib and put in the folders.NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 10:00 amthe git submodule update --init does nothing for me, I only getOver and over. I tried running the command manually and it just exits and does pretty much nothing.C:\Users\User\Downloads\rusefi-master\firmware>make
I'll give what you said a shot, thanks!
**EDIT** IT WORKED! THANK YOU!
**EDIT 2 **
The fix allowed me to start compiling, but I keep failing to compile since I apparently don't have "stm32_gpio.h", which is supposed to be included in the GCC toolchain I think?
Tuned by AlphaSpeed
Tuned by AlphaSpeed
Download Git for Windows.NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 3:45 pmI mean I'd compile it with a git folder... but how do I create it?960 wrote: ↑Tue Feb 12, 2019 1:50 pmIf you want to compile without having a git folder, you have to manually download the chibios and chibios contrib and put in the folders.NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 10:00 amthe git submodule update --init does nothing for me, I only getOver and over. I tried running the command manually and it just exits and does pretty much nothing.C:\Users\User\Downloads\rusefi-master\firmware>make
**EDIT 2 **
I have still never gotten it to compile with command line. It always end in some error.960 wrote: ↑Tue Feb 12, 2019 8:38 pmDownload Git for Windows.NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 3:45 pmI mean I'd compile it with a git folder... but how do I create it?960 wrote: ↑Tue Feb 12, 2019 1:50 pmIf you want to compile without having a git folder, you have to manually download the chibios and chibios contrib and put in the folders.NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 10:00 amthe git submodule update --init does nothing for me, I only getOver and over. I tried running the command manually and it just exits and does pretty much nothing.C:\Users\User\Downloads\rusefi-master\firmware>make
**EDIT 2 **
But ChibiStudio works for me.
No, stm32_gpio.h is not part of compiler - I suspect your older? updated? folder has mismatched version of ChibiOS maybe?NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 3:45 pm**EDIT 2 **
could be helpful to update submodule since there was ChibiOS migration recentlygit submodule update --recursive --remote
- NormanAlphaspeed
- Contact:
The link to ChibiOS on your Github takes me to the ChibiOS fork... on your Github, I downloaded that and put it in ChibiOS (and downloaded Contrib and put it there too) and apaprently I'm missing stm32_gpio.russian wrote: ↑Tue Feb 12, 2019 11:25 pmNo, stm32_gpio.h is not part of compiler - I suspect your older? updated? folder has mismatched version of ChibiOS maybe?NormanAlphaspeed wrote: ↑Tue Feb 12, 2019 3:45 pm**EDIT 2 **
Tuned by AlphaSpeed
Tuned by AlphaSpeed
This does not sound like the way you are supposed to be using github. I would recommend against manually resolving submodules put getNormanAlphaspeed wrote: ↑Thu Feb 14, 2019 5:49 amThe link to ChibiOS on your Github takes me to the ChibiOS fork... on your Github, I downloaded that and put it in ChibiOS (and downloaded Contrib and put it there too) and apaprently I'm missing stm32_gpio.
or maybe
Also, why do you need to compile - why would pre-compiled binaries not work for you?
- NormanAlphaspeed
- Contact:
As I posted before, git submodule update --init just does evidently nothing and returns to cmd without apparently doing anythingrussian wrote: ↑Thu Feb 14, 2019 6:13 amThis does not sound like the way you are supposed to be using github. I would recommend against manually resolving submodules put getNormanAlphaspeed wrote: ↑Thu Feb 14, 2019 5:49 amThe link to ChibiOS on your Github takes me to the ChibiOS fork... on your Github, I downloaded that and put it in ChibiOS (and downloaded Contrib and put it there too) and apaprently I'm missing stm32_gpio.
or maybe
the other command hasn't been mentioned and I'll try it out now: I want to compile so I can start fiddling around with it. I have a Github repo of my own ( https://github.com/ElDominio ) and I like to learn about this, and seeing as rusEFI uses an OS I'd like to learn about how they work, especially in an ECU
Tuned by AlphaSpeed
Tuned by AlphaSpeed
You dont have a git folder in firmware? Try CD..NormanAlphaspeed wrote: ↑Thu Feb 14, 2019 7:26 amAs I posted before, git submodule update --init just does evidently nothing and returns to cmd without apparently doing anythingrussian wrote: ↑Thu Feb 14, 2019 6:13 amThis does not sound like the way you are supposed to be using github. I would recommend against manually resolving submodules put getNormanAlphaspeed wrote: ↑Thu Feb 14, 2019 5:49 amThe link to ChibiOS on your Github takes me to the ChibiOS fork... on your Github, I downloaded that and put it in ChibiOS (and downloaded Contrib and put it there too) and apaprently I'm missing stm32_gpio.
or maybe
Try the git command(s) from C:\Users\user\Downloads\rusefi-master
Notice this is one folder above "firmware"
I believe git command should not care
Yes it does. It does not work in firmware folder.
You have to be in the git folder. If you show hidden files, you see the git folder in the folder.
so type cd.. one time first and it should work fine.
- NormanAlphaspeed
- Contact:
Same error
BTW I haven't deleted any folder or anything. AlphaX Auto Electronics
Tuned by AlphaSpeed
Tuned by AlphaSpeed
You cloned into that directory? not copied?NormanAlphaspeed wrote: ↑Thu Feb 14, 2019 3:23 pmSame error
I do not see the ".git" folder. I suspect you did not clone, but instead downloaded from the web page. Try obtaining the folder with git instead of the web page download.
I believe the commands will be something like this.
cd C:\Users\user\Downloads
git clone https://github.com/rusefi/rusefi.git
cd rusefi
cd rusefi
- NormanAlphaspeed
- Contact:
Nothing yet.
BTW, there is a . git inside the "rusefi" folderAlphaX Auto Electronics
Tuned by AlphaSpeed
Tuned by AlphaSpeed
git clone has created a new 'rusefi' folder. You should be somewhere inside the folder to invoke orher git command including git aubmodjlez
cd rusefi
cd rusefi
- NormanAlphaspeed
- Contact:
Well that was quite stupid of me lol
Color me burned out.
It is finally working, thanks everyone.
Compiled fine, finally. Thanks everyone!
Tuned by AlphaSpeed
Tuned by AlphaSpeed
I just edited my prior post which included the commands you followed. Not this thread makes out to look bad
At least now if someone find it, they'll have the proper commands to try.
Hi everybody!
I used manual for compile the firmware and come to this stage....
Where i made something wrong?
Who meeted with this problem also?
- 123.png (70.12 KiB) Viewed 66199 times
Where did you get these source codes how exactly? How did you get chibios submodule exactly?
I see chibios/os/ports on your screenshot. I do not see "ports" folder at https://github.com/rusefi/ChibiOS/tree/4012d627c92b0e60bdbfdfca4af823852c341e18/os
this makes me think your chibios is wrong. since chibios is supposed to be downloaded automatically I wonder what else is wrong. So, Where did you get these source codes how exactly? How did you get chibios submodule exactly?
I've just edited the first post in that 2013 topic. There were updates in the comments but first post was very very outdated.Kavabanga wrote: ↑Sun Jul 07, 2019 11:10 pmI took it here
https://rusefi.com/forum/viewtopic.php?f=9&t=253
We are chatting now, let's use https://rusefi.com/forum/viewtopic.php?f=13&t=1198 or Skype for chatting.
Is it possible to use the STM32CubeIDE for compiling?
Anything is possible, just depends on how much effort you want to put into it.
I'm familiar with IAR and STM32CubeIDE, not gnu toolchain.
Now I want to modify some GPIO and Timer setting of your firmware and compile it.
Below is the first headache of make:
I think the best compiler tool is available in linux, Just install a linux on a virtual machine like virtualbox and compile it.
As i had experience, The cygwin sometimes goes unstable especially with lib(s).
https://www.youtube.com/watch?v=H3ZQDkpKwQo
The Linux way!
You must have installed gcc-arm-none-eabi(v9) in path and maybe some other utility packets(git, make etc)
In Terminal:
$ mkdir retest
$ cd retest
$ git clone https://github.com/rusefi/rusefi.git
$ cd rusefi/
$ git submodule update --init
$ cd firmware/
$ git log --oneline | head
$ make
Then you have "rusefi.bin" in "Build" directory
In Terminal:
$ mkdir retest
$ cd retest
$ cd rusefi/
$ cd firmware/
$ make
as far as I remember, git clone takes up too much space and network traffic, downloading unnecessary hardware-related files, datasheets, etc. I don't remember if I managed to find a solution to download it partially ;-(
