2003 Miata Transmission Conroller
It's all about the code!
Pretty simple automatic transmission - two shift solenoids and torque converter clutch solenoid, "line pressure is by mechanical cable" whatever it means.
Diagram
http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_2001#Automatic_Transmission
https://github.com/rusefi/rusefi/wiki/HOWTO-TCU-A42DE-on-Proteus
I've got couple of units as connector donors and just got a pigtail today. First step would be making a harness extension so that I can analyze stock TCU behavior.
Looks like a 35 position connector? Will try getting part number from TE support people on Monday.
Re: 2003 Miata Transmission Conroller
High-side solenoid control and VR speed sensors? Will measure solenoid resistance soon.
I've destroyed the connector pictured above while trying to solder wires to it :( Looks like a PCB is pretty much required, next step is measuring the pinout. TE Live Product Chat were not able to identify this part.
matt
donator
donator
Post by matt »
did you mean controlling auto trans via rusefi?
mattsabun wrote:did you mean controlling auto trans via rusefi?
Yes
matt
donator
donator
Post by matt »
great!!
i got kia carens with auto transmission very similar with lantis gearbox.
faulty maybe from ecu or wiring harness, I am not check it yet.
Finally I've decided to open my eyes and realize that it's a JAE connector. Wire side is MX7-A-35SC http://jae-connector.com/en/pdf/SJ028726.pdf
For board side we can use left part of attached larger header, I was not able to find a 35 header so far.
Actually page 4 of attached has the 35 header.
Solenoids diagram added to http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_2001#Gear_diagram
All three solenoids are 18 Ohm each. Looking at the diagram these seem to be high-side controlled? Could it be simple on/off? Should I solder a couple of toggle switches and try to drive it like that?!
[video]https://www.youtube.com/watch?v=rYto781SRiw[/video]
Post by stefanst »
russian wrote:[...]All three solenoids are 18 Ohm each. Looking at the diagram these seem to be high-side controlled? Could it be simple on/off? Should I solder a couple of toggle switches and try to drive it like that?![...]
AFAIK the solenoids A/B are definitely just on/off. So is -presumably- TCC.
There could be a lot of overlap with this unit
porelmundo
Post by porelmundo »
Several years ago i was working with AW4/A340 transmissions for drag racing applications meaning that are only for manual paddle operation,
is basically a driver board with a 7 segment display for gear indication and a simple Arduino logic arrangement. Today im converting a Lexus with a 1JZ GTE VVTI to rusefi and im planing to use this board for shifting the transmission and controlling the trans pressure solenoid from a PWM output from the rusefi. If you are interested i can send you one so you dont have to use that crazy switch board. :lol:
YES! Just emailed you my address.
porelmundo
It's rudimentary but works,
DeckGT
Post by DeckGT »
Interesting project! My buddy got this 2003 Miata project we'll work on right after we finished installing the suspension from 4Wheelonline onto the trucks and clear the garage. I'll let him check he likes the transmission controller idea of yours.
Status update:
turbine shaft input seems to work, output shaft so far no good reading. turbine shaft is sometimes RPM sometimes output with gear ratio:
(a bit off Matt)
turbine INPUT is fixed ratio to the output when IN GEAR ONLY
in neutral it will be almost engine speed
it's on the output of the torque converter
aka locked to engine only when lockup clutch is closed
when in gear, it should exactly match transmission gear ratio for ISS / OSS
when TC locked, ISS = engine RPM
the TC has a clutch that turns it in to a fixed coupler instead of a slippy hydraulic thing
older boxes didn't have the clutch at all
it started showing up in the 90s
https://rusefi.com/online/view.php?msq=975
https://rusefi.com/online/view.php?log=768
good news zero ISS one I've turned off engine
bad news noisy value while ECU was idling
filter parameter 5 and 10 still too much variation in output
https://rusefi.com/online/view.php?log=770
https://rusefi.com/online/view.php?log=771
Some fresh data towards input shaft speed filtering
