Hellen compatibe with Bosch 17.9.7 and siblings
Posted: Thu Aug 17, 2023 2:17 pm
Little square 112 pin ECU used both on Indian bikes as in
https://www.indianmotorcycle.com/ and Indian cars as in
https://www.marutisuzuki.com/ with Polaris, UAZ and VAZ in between.
https://github.com/rusefi/hellen-112-17
https://rusefi.com/docs/pinouts/hellen/hellen-112-17/
Maybe one day we should make an open source design simply because of how widely this platform is used, maybe one day.
Slingshot action
VIDEO
Re: Bosch 17.9.7 and siblings
Posted: Fri Aug 18, 2023 5:14 am
Header is available new one of the part numbers is CKK112P-K
Posted: Wed Aug 23, 2023 1:36 pm
by Mikhail_U
What is about circuit for me17-112-adapter?
Posted: Thu Aug 24, 2023 4:24 am
Mikhail_U wrote: ↑ Wed Aug 23, 2023 1:36 pm
schematics is more or less just the pinout with IGBT
https://github.com/rusefi/rusefi-hardware/blob/main/breakout-boards/adapter-board-me17-112-B-schematic.pdf
I am hesitant to release gerbers for the adapter since I do not want too many people to start using the adapter instead of pushing for a proper me17 hellen. My plan is to revisit the plan in a month from now depending on how much me17 progress is made.
Posted: Thu Aug 24, 2023 6:10 am
by Mikhail_U
What is a "proper me17 hellen"? What it means?
Posted: Thu Aug 24, 2023 7:29 am
Mikhail_U wrote: ↑ Thu Aug 24, 2023 6:10 am
it means "single PCB plug and play ECU which uses original vehicle connector and usually fits inside original case"
like
https://github.com/rusefi/rusefi/wiki/Hellen-154-Hyundai or
https://github.com/rusefi/rusefi/wiki/Hellen-88-BMW
Posted: Sat Aug 26, 2023 8:41 am
by Mikhail_U
Posted: Sat Aug 26, 2023 8:03 pm
Posted: Thu Sep 07, 2023 11:13 pm
Posted: Fri Sep 08, 2023 2:45 pm
by Dron_Gus
Too thin wire for ground return?
Posted: Fri Sep 08, 2023 2:51 pm
Dron_Gus wrote: ↑ Fri Sep 08, 2023 2:45 pm
Smoke was probably my fault - I've unhooked the superseal plug with power GND while vehicle was on.
Posted: Fri Sep 08, 2023 4:24 pm
by Dron_Gus
AndreyB wrote: ↑ Fri Sep 08, 2023 2:51 pm
Anyway wire looks to thin for power GND for 4 ingition transistors.
Re: Hellen compatibe with Bosch 17.9.7 and siblings
Posted: Sun Sep 10, 2023 5:49 pm
we now have an open source ECU compatible with that pinout
Posted: Mon Oct 09, 2023 5:23 pm
Waiting for harness components to actually test this further
Posted: Mon Oct 30, 2023 7:31 pm
VIDEO
