128/145 pin breakout board Mercedes, also PnP ECU
Posted: Thu Aug 06, 2020 6:44 pm
Does anyone know part number of this Mercedes connector? Is it available new? How much is a cheap used ECU to take apart?
https://github.com/rusefi/rusefi/issues/1674
Re: 128 pin breakout board Mercedes
Posted: Thu Aug 06, 2020 7:45 pm
by md_sanci
It looks like it is a Bosch connector.
The smaller pins distance is the traditional 2.54 mm pitch 2 in a row.
The bigger pins are used in other ECU connectors as well i presume for higher current so it can be constructed from smaller connectors.
My plan was to do this on a test pcb and connect it to the MRE harness, actually i already did it, but is to Maad Max style :)) and i would not drive with that.
Posted: Thu Aug 06, 2020 7:53 pm
so 1264488241 and we need to find cheapest junk yard option
eBay has many 023 545 97 32 for under $20 shipped
Posted: Sun Aug 16, 2020 5:35 pm
Dave says it took him 15 minutes to dissolved with Pace SX100 magic machine - that's about $300 of magic.
Posted: Mon Nov 16, 2020 4:40 pm
Jared, your drawing on the connector is amazing - all the pins have aligned just fine!
Jared, your drawing on the connector is horrible you forgot to include two white pivot pins! Any chance you can add those onto the drawing?
https://www.ebay.com/itm/333791544427
Posted: Thu Dec 31, 2020 11:12 pm
Let me just leave this here
Posted: Sat Jan 02, 2021 5:49 pm
Open question what is the best term for this connector
On the one hand we have technical drawing which shows 8+4+40+24+48+21=145 pins
On the other hand in reality it seems to always be 23 pin in "C" section so 8+4+23+24+48+21=128
At least both 4 cylinder and 6 cylinder ECU I have in my collection have same 23 pin "C" section.
Re: 128/145 pin breakout board Mercedes, also PnP ECU
Posted: Sun Jan 03, 2021 6:13 pm
Let's reuse same topic for PnP discussion within Hellen One platform https://rusefi.com/forum/viewtopic.php?f=4&t=1913
Posted: Sat May 29, 2021 12:14 pm
Damn this 2003 C200 compressor uses different connector, it uses 4 out of 5 section on the 134 :( is not that an M111 engine? is that vehicle just a bit too new?
