[info] HIP9011 module
Re: HIP9011 module
russian wrote:This is a bit unfinished (untested) and a bit untested (no proof that real knock is detected), at this point I would not bother using it.
Status comment added into https://svn.code.sf.net/p/rusefi/code/trunk/firmware/hw_layer/HIP9011.cpp
Just for the record - here's an assembled board with working SPI:
Re: HIP9011 module
@ has unreliable hip9011 experience with his board - putting a finger on the chip changes the output level. I like that we see the integration on the output so something is right, but we need a reliable output level
Rhinoman
Re: HIP9011 module
Post by Rhinoman »
It looks like its in oscillation, it could be a hardware issue but maybe tweaking the control parameters will fix that.
Re: HIP9011 module
Can you post more about the setup? I don not know what channel is connected to what pin, etc. What is the input signal? Is there some kind of knock simulation, or is the input disconnected?
Re: HIP9011 module
Oh, also can you zoom in, such that you have only 3 or 4 pulses on the screen.
