Manual:Hardware_Frankenso_board
pinout
SVN Repository
frankenso_schematic.pdf
frankenso_gerbers.zip
Bill Of Material
known_issues.txt
https://www.tinkercad.com/things/3xeOOUULskv-frankenso-mazda-64-pin-case-wire-door-v03
x12 low-side VNS14NV04
x3 op-amp LMV324IDT
x3 high-side TC4427
x2 SD card socket
x1 VR INTERFACE MAX9926
x1 CAN interface SN65HVD230
x2 33uH Inductor
x2 CAP TANT 220UF
x1 IC REG BUCK 5V 3A
x1 CAP ALUM 680UF
x1 HIP9011 knock detection chip
x1 4MHz osc for HIP9011
case hole for micro USB: d=12mm, 7 mm from top, 46mm from right.
vertical space inside the case:
from top of red board to bottom of top cover - 23mm
from top of brain boardo bottom of top cover - 10mm
ibom available at https://rusefi.com/docs/ibom/
Frankenso Soldering Youtube playlist:
UPDATE: this thread is loooong now, a few interesting posts:
https://rusefi.com/forum/viewtopic.php?p=36893#p36893
