Hellen compatibe with Bosch 17.9.7 and siblings
Little square 112 pin ECU used both on Indian bikes as in https://www.indianmotorcycle.com/ and Indian cars as in https://www.marutisuzuki.com/ with Polaris, UAZ and VAZ in between.
https://github.com/rusefi/hellen-112-17
https://rusefi.com/docs/pinouts/hellen/hellen-112-17/
Maybe one day we should make an open source design simply because of how widely this platform is used, maybe one day.
Slingshot action
Re: Bosch 17.9.7 and siblings
Header is available new one of the part numbers is CKK112P-K
Mikhail_U
Github Username: MU
Post by Mikhail_U »
What is about circuit for me17-112-adapter?
Mikhail_U wrote:
Wed Aug 23, 2023 1:36 pm
schematics is more or less just the pinout with IGBT https://github.com/rusefi/rusefi-hardware/blob/main/breakout-boards/adapter-board-me17-112-B-schematic.pdf
I am hesitant to release gerbers for the adapter since I do not want too many people to start using the adapter instead of pushing for a proper me17 hellen. My plan is to revisit the plan in a month from now depending on how much me17 progress is made.
Mikhail_U
Github Username: MU
Post by Mikhail_U »
What is a "proper me17 hellen"? What it means?
Mikhail_U wrote:
Thu Aug 24, 2023 6:10 am
it means "single PCB plug and play ECU which uses original vehicle connector and usually fits inside original case"
like https://github.com/rusefi/rusefi/wiki/Hellen-154-Hyundai or https://github.com/rusefi/rusefi/wiki/Hellen-88-BMW
Mikhail_U
Github Username: MU
Post by Mikhail_U »
Not used in VAZ/UAZ, but used on your https://rusefi.com/docs/pinouts/hellen/hellen-112-17/?connector=H-112&pin=201
Error?
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
Too thin wire for ground return?
Dron_Gus wrote:
Fri Sep 08, 2023 2:45 pm
Smoke was probably my fault - I've unhooked the superseal plug with power GND while vehicle was on.
Dron_Gus
Post by Dron_Gus »
Fri Sep 08, 2023 2:51 pm
Anyway wire looks to thin for power GND for 4 ingition transistors.
Re: Hellen compatibe with Bosch 17.9.7 and siblings
we now have an open source ECU compatible with that pinout https://github.com/rusefi/hellen-112-17
Waiting for harness components to actually test this further
