Hellen compatibe with Bosch 17.9.7 and siblings
Little square 112 pin ECU used both on Indian bikes as in https://www.indianmotorcycle.com/ and Indian cars as in https://www.marutisuzuki.com/ with Polaris, UAZ and VAZ in between.
https://github.com/rusefi/hellen-112-17
https://rusefi.com/docs/pinouts/hellen/hellen-112-17/
Maybe one day we should make an open source design simply because of how widely this platform is used, maybe one day.
Slingshot action
Slingshot action
Re: Bosch 17.9.7 and siblings
Header is available new one of the part numbers is CKK112P-K
- Mikhail_U
- Github Username: MU
What is about circuit for me17-112-adapter?
schematics is more or less just the pinout with IGBT https://github.com/rusefi/rusefi-hardware/blob/main/breakout-boards/adapter-board-me17-112-B-schematic.pdf
I am hesitant to release gerbers for the adapter since I do not want too many people to start using the adapter instead of pushing for a proper me17 hellen. My plan is to revisit the plan in a month from now depending on how much me17 progress is made.
- Mikhail_U
What is a "proper me17 hellen"? What it means?
it means "single PCB plug and play ECU which uses original vehicle connector and usually fits inside original case"
like https://github.com/rusefi/rusefi/wiki/Hellen-154-Hyundai or https://github.com/rusefi/rusefi/wiki/Hellen-88-BMW
- Mikhail_U
Not used in VAZ/UAZ, but used on yourYou do not have the required permissions to view the files attached to this post.
Used on Polaris https://github.com/rusefi/rusefi_documentation/blob/master/OEM-Docs/Polaris/RZR%20PRO%20XP%20(Base%20Model).pdf
https://github.com/rusefi/rusefi-hardware/blob/main/breakout-boards/adapter-board-me17-112-A-schematic.pdf?raw=true
https://github.com/rusefi/rusefi-hardware/blob/main/breakout-boards/adapter-board-me17-112-B-schematic.pdf?raw=true
- Dron_Gus
- Github Username: dron0gus
Too thin wire for ground return?
Smoke was probably my fault - I've unhooked the superseal plug with power GND while vehicle was on.
- Dron_Gus
Re: Hellen compatibe with Bosch 17.9.7 and siblings
we now have an open source ECU compatible with that pinout https://github.com/rusefi/hellen-112-17
Waiting for harness components to actually test this further
