MRE addon Board - Wideband controller + SD Card slot + EGT Chip
Re: MRE addon Board - Wideband controller + SD Card slot + EGT Chip
I have some addon boards for sale ...
- DSCN6034.JPG (1.33 MiB) Viewed 8624 times
..working on a new version of this board....
- Screenshot_20230123_221113.png (228 KiB) Viewed 8240 times
...the world's first dualcore MRE in ALU case...
- DSCN6175.JPG (1.22 MiB) Viewed 8278 times
- DSCN6176.JPG (1.25 MiB) Viewed 8278 times
PCB ver. 2.5 in real life ..
(some testing and coding are needed)
....and it can be fitted into the ALU case without any modification ...
It is still the same mck1117's WBO2 controller, but it has prepared OPAmps (U7) for analog output(some testing and coding are needed)
..10 boards assembled ...
- DSCN6522.JPG (1.28 MiB) Viewed 7541 times
my "dirty" github repository.. for firmware
It contains build directory for f0_addon board.
Last HW have footprints for OP amp.
It can be used as AUX outputs.
Now I need help with code, to see any "usable" output on AUX pins.
https://github.com/JRDMcLAREN/wideband-2311-f0_addon
- Screenshot_20240118_191730.png (76.96 KiB) Viewed 3845 times
