[info] microRusEFI
Dron_Gus
Github Username: dron0gus
Re: microRusEFI
Post by Dron_Gus »
JRD McLAREN wrote:
Tue Jan 11, 2022 5:28 pm
.. I'm assume:
12V_MREL ON - stopped engine
12V_MREL OFF - cranking
12V_MREL ON - run / idling
RIGHT .. ?
Nope. 12V_MREL is on in all three states. To archive this you need 12V_KEY to be connected to IGN-1 on picture above.
JRD McLAREN
Re: microRusEFI
Post by JRD McLAREN »
YES, you right ...
my meaning is wrong ... sorry for effort ...
Some cars have two 15 lines (15 and 15A) form ignition switch ..
and some has "main relay" for whole electricity in the car - drive by ECU PCM or PMU
JRD McLAREN
Re: microRusEFI
...picked from SLACK ...
Automotive companies avoid to use small (tiny) SMD components
smallest smd (0402) can be shorted by humidity sooner ... as bigger 1206 ...
I have same old ecus ..and the smallest one are 0603 ... 0805 is standard ...
"bigger" caps are 1206 ... etc ..
(many OEM ecus has no protective film / paint / glaze)
Will be good to use "automotive grade" passives for the future.
C0603C104K3RACAUTO - for explame
..and on the other side ...
avoid to use "BIG electrolytic CAPs" ... it can be broken by vibration ..
(it is glued if it is necessary)
Re: microRusEFI
Pic of Ford or Hyundai not sure which one probably Hyundai
R22 is probably 1206?
I think I see at least caps smaller than 0603. Four sizes on the same board a bit insane.
sepp2gl
Github Username: sepp2gl
Re: microRusEFI
Post by sepp2gl »
Hi guys,
just looking through MRE. Looks really nice for 4-cyl applications.
You decided to use TLE8888 for it.
Did you find a reliable distributor for the procurement of this chip?
I only found Digikey, who seem to be willing to sell small numbers of it.
Is there any other second source?
kr, sepp2gl
Everything keeps being better ... ;)
Re: microRusEFI
It was designed before the chip shortage :( yes magic part dependency was a risk then and is a bigger risk now
JRD McLAREN
Re: microRusEFI
Mouser is distributor also ..
..and ... at this time, is problem to buy any kind of IC ...
(I waiting for stm32f407 .. 3 months)
Re: microRusEFI
http://www.itelma.ru/ M86 ECU used on https://en.wikipedia.org/wiki/Lada_Vesta
8450009519
8450009524
8450021514
8450032188
8450091352
8450091495
Re: microRusEFI
Look 0.6.0 :)
JRD McLAREN
Re: microRusEFI
WOW ... GD32F .... :shock:
Re: microRusEFI
GD - :o
Is USB still a primary way of communications with TS / devconsole?
Re: microRusEFI
puff wrote:
Tue Apr 19, 2022 9:42 pm
GD - :o
Not a gd32 batch, just an experiment :)
Re: microRusEFI
GD - :o
There must be a reason you are asking, do you want to share something? :)
Re: microRusEFI
this is probably offtopic here ;-)
nothing particular. just saw a usb connector, which reminded me of some pronounced ideas of moving to can bootloader (still under construction?)
besides, when recently my brother was chip-tuning his diesel citroen, the garage guy soldered some wires to the ecu directly. he said he could flash it through a normal diagnostics connector, but in that case he won't be able to make a backup.
K-line or LIN might be too slow for this purpose, but the bandwith of CAN (a second one?) should be enough. However, with TunerStudio supporting only serial connection, there isn't much value in all this...
JRD McLAREN
Re: microRusEFI
...is able to make backup via K-line .. when you have 45-80 min. time ...
Re: microRusEFI
puff wrote:
Wed Apr 20, 2022 5:26 pm
Just a reminder that we have a working prototype of CAN-to-serial-to-TunerStudio bridge just need to figure out if there are defects there or not.
Re: microRusEFI
JRD McLAREN wrote:
Wed Dec 22, 2021 5:06 pm
BM2LC120FJ-C or BM2LC105FJ-C
these parts have pretty similar specs why do they even have two different parts? is that a trade off between speed and resistance or something else?
105
120
MHTSOS
Github Username: MHTSOSVOODOO
Slack: Dimitri C
Re: microRusEFI
Post by MHTSOS »
Different rdson resistance. Pick the lowest one since it makes less heat while on.
Re: microRusEFI
where do I read more about that CAN-to-serial-to-TunerStudio bridge? If it works fine, it might be a good idea to implement it on board, so that the ecu can be completely sealed?
Re: microRusEFI
microRusEFI 0.5 sale at https://www.shop.rusefi.com/shop/p/microrusefi-assembled-ecu-development-module fully assembled starting at $275
Re: microRusEFI
Re: microRusEFI
klpaul wrote:
Sun May 29, 2022 5:38 pm
Sun May 29, 2022 2:44 pm
Please update to latest https://rusefi.com/build_server/rusefi_bundle_mre_f4.zip and try again - I've changed something in that specific binary
Thank's, it's work.
Great to hear that we've made progress! For anything less general please post a separate build or separate questions threads
Re: microRusEFI
mck1117 wrote:
Tue Apr 19, 2022 9:45 pm
GD32F405 GD32F4 experiment failed: have a discovery board with GD32F405 - while openocd have successfully flashed rusEFI and st-link equally happy connects to this chip I do not even have LEDs blinking. Experiment goes on the shelf since zero priority.
Re: microRusEFI
Now shipping microRusEFI 0.6.0 with on-board SD card.
For the last two months we were experimenting with $299 pricing at https://shop.rusefi.com/ but it gets back to $450 on Aug 15th.
007adr
Re: microRusEFI
Post by 007adr »
I ordered mine on the 4 th is it the 0.6 board?
Re: microRusEFI
007adr wrote:
Wed Aug 10, 2022 10:25 am
Yes, i think it is.
007adr
Re: microRusEFI
Post by 007adr »
its ok if it isn't but awesome great edition to the project
007adr
Re: microRusEFI
Post by 007adr »
Is knock sensing available yet/at all? i read something somewhere where it could be included but cant find details, but i am a dumb dumb
JRD McLAREN
Re: microRusEFI
MRE has no hardware for knock sensor ...
..but it will be good idea, to do it on this .... :roll:
https://rusefi.com/forum/viewtopic.php?f=4&t=2215&start=30
MauroSignoroni
Github Username: Mauro
Re: microRusEFI
Post by MauroSignoroni »
E' possibile aggiungere hardware hellen-one Module-knock-0.2 a MRE per rilevare il battito?
Ne ho veramente bisogno, quali sono gli ingressi "Channel 1" "Channel 2" mostrati in Tuner Studio?
