F103 Wideband Controller
Dron_Gus
Github Username: dron0gus
Re: F103 Wideband Controller
Post by Dron_Gus »
Finally arrived.
Some issue with fitment. Thanks to plastic enclosure you just need to push it harder. Acceptable result for development with no enclosure on hands.
Dron_Gus
Post by Dron_Gus »
Some progress.
TS now can read livedata from 1f_rev2 wideband.
Next step is settings.
PS communication is over UART 115200. Next step is CAN.
Fresh rev3 hardware
now targeting 26 pin small square case
now with some spare digital inputs
now using 64 pin F103
https://github.com/rusefi/rusefi-hardware/tree/main/wideband-F103
DAC output works! Next step to merge the DAC code into official repo and fix PCB dimentions.
joaodh
Post by joaodh »
It's getting really interesting. Unfortunately I have 5 boards to assembly with rev2. But you are already in rev3 :lol:.
I think I will wait until the things be more stable. Also the stm32 mcu seems be out of stock. On this board do you use a Chinese version?
stm32/gd32 questions is now clarified on https://github.com/rusefi/rusefi-hardware/blob/main/wideband-F103/readme.md my boards are a mix depending on what was available at time of order.
Also added a link to rev2 firmware binaries.
At the moment I am not sure if I will be ordering rev 4 on Tuesday or much later, overall this F103 is very much in the air.
joaodh
Post by joaodh »
Sun Sep 04, 2022 3:00 pm
I have bought today two gd32f103. I will assembly the rev0.2 to see if works properly. I have also with me two ch32f103 do you think that will be possible make this one works also?
No plans for ch32f103 sorry, each extra chip is huge amount of effort.
joaodh
Post by joaodh »
Mon Sep 05, 2022 4:10 pm
Will take time to receive the GD32. I have have spare boards let's see if I can make CH32 works :lol:
It takes time :( https://github.com/mck1117/wideband/pull/164 15 days so far no feedback no merge :(
Nissan uses 4 wire "middle band" sensors, do these have anything in common with our WBO logic?
https://github.com/rusefi/wideband/issues/12
Tue Nov 15, 2022 12:33 am
I got one to work here: https://rusefi.com/forum/viewtopic.php?p=43610#p43610
Nope, they're basically just "source voltage and measure current" type devices, no active control really needed.
Zeiss
Post by Zeiss »
@Dron_Gu: Which enclosure is this? It looks very nice :)
Thank you!
Regards,
Heinrich
My GitHub
Dron_Gus
Post by Dron_Gus »
Zeiss wrote:
Tue Nov 15, 2022 8:18 am
Thank you!
Plastic one is https://sl.aliexpress.ru/p?key=OokNx3z
Dron_Gus
Post by Dron_Gus »
But with slight modification (planned for V2) should also fit into https://aliexpress.ru/item/4000811747039.html
Zeiss
Post by Zeiss »
Thank you very much :)
Regards,
Heinrich
My GitHub
Timbelom
Github Username: Timbelom
Slack: na
Post by Timbelom »
Stock ECU
hard wired to battery
quick engine restarts seem to have a problem:
on engine cranking controller seems to go into heating mode where it takes a while to re-heat what is supposed to be a hot sensor
Dron_Gus
Post by Dron_Gus »
Battery voltage drops down to 8.53V (actually seems even lower) during cranking. This cause controller to switch to SensorNoHeatSupply state and after battery voltage rises above 9.5 - start heating from the beginning.
https://github.com/dron0gus/wideband/blob/master/firmware/wideband_config.h#L55
mck1117 wrote:
Thu Apr 07, 2022 8:17 pm
LSU adv five wire pinout
Something like 2017-2019 Audi A4 Upstream Front Oxygen Lambda Sensor 8R0906262 8R0906262E would be the sensor
