F103 dual channel wideband controller + EGT + 2 x AUX In + 2 Aux out
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
Hi.
Here is dual channel wideband AFR controller supporting LSU4.2, 4.9 and ADV. Based on design from @mck1117 .
https://github.com/rusefi/rusefi-hardware/tree/main/lambda-x2
Pinout https://rusefi.com/docs/pinouts/lambda-x2/
Reviewers are welcomed.
Andrey.
Dron_Gus
Re: F103 dual channel wideband controller + EGT + 2 x AUX In + 2 Aux out
Post by Dron_Gus »
Designed for this enclosure.
Dron_Gus
Post by Dron_Gus »
2x AFR: Bosch LSU4.2, LSU4.9 or LSU_ADV. Heater control - BTS3028.
2x EGT: MAX31855KASA or MAX31856
2x analog inputs: 0..5V with pull-up or pull-down (configurable by soldering resistor). One can be used to source 5V to external sensor.
2x analog outputs: 0..5V. Also can be used for slow PWM signal output.
2x Open Drain outputs: BTS3028 (5A)
CAN interface.
Dron_Gus wrote:
Sun Apr 24, 2022 10:13 am
What package have you used? Looks like SOIC-8 is not very available right now while 14-Pin TSSOP is available right now.
Dron_Gus
Post by Dron_Gus »
Sun Apr 24, 2022 1:04 pm
Both.
MAX31855KASA is SOIC-8. And it is available on JLCBCB for ~$5.
MAX31856 is exist only in TSSOP. And now is not available on JLCPCB. This one is more featured, but cost twice more (on JLCPCB).
VND14NV04 are pretty available that would give 12A :)
Dron_Gus
Post by Dron_Gus »
Sun Apr 24, 2022 1:22 pm
Available on JLCPCB? Or?
12A is good, but require adequate pin in connector. 12A over current connector can possibly vaporize pin :)
JRD McLAREN
Post by JRD McLAREN »
another 2 analog outputs for "display" .. ??
Lambda1 = 1Volt .. ??
https://rusefi.com/forum/viewtopic.php?p=44963#p44963
Dron_Gus
Post by Dron_Gus »
JRD McLAREN wrote:
Wed Apr 27, 2022 6:50 am
Do it need to be "another"? We have 2 analog output with no clear purpose.
JRD McLAREN
2 per one controller / sensor ..??
(is enough pins on MCU .. ??) :roll:
BTW:
This WBO2 controller might be bigger then MRE ...
Dron_Gus
Post by Dron_Gus »
JRD McLAREN wrote:
Wed Apr 27, 2022 6:36 pm
BTW:
Two per controller.
Few problems:
1. All pins on 24-pin connector are used. Switch to another box with 32pin connector? Remove some other functionality?
2. All pins of 48-pin MCU package are also used. Switch to 64-pin package?
2a. Pin allocation for timers/pwm to generate analog output.
Yes. It is almost the same size as MRE. But because it is prototype.
Only 75% of PCB space is used. Also there are two types of termocouple ICs, just for evaluation.
So PCB size can be reduced at least twice.
Dron_Gus
Post by Dron_Gus »
Also I'd like to change 4 separate switches to something like TLE6228 or something similar. This can also save some PCB space.
JRD McLAREN
..maybe ... use the same type of Molex connector for the future ...
due to use the same pins as MRE have .. (24 or 32 pin)
2 AUX outs per one WBO2 controller is enough ... (I think)
https://www.aliexpress.com/item/4000043947422.html?spm=a2g0o.store_pc_groupList.8148356.10.4a29135b2kCSW3
https://www.aliexpress.com/item/4000219781241.html?spm=a2g0o.store_pc_groupList.8148356.2.6c7113b3WjIW7q
Dron_Gus
Post by Dron_Gus »
May be. Any wished are wellcomed for Rev 1. :)
chaoschris
Post by chaoschris »
If you build such a big external Lambda-/EGT-controller, it should be as universal as possible and work in all possible ecosystems, also out of the rusefi-world.
This means:
-data transfer to ECU via can bus and also via analog out. Every lambda controller should get its own wideband analog out 0-5V and a and if possible a narrow band simulation with 0-1V.
-start signal to heat the controllers should be possible via can bus and via digital in. If you start the heating of the lambda sondes as soon as power supply connects, this will lead to cracked nernst cells as the preheated/hot sonde don't like any water from condensation of a cold motor.
-EGT should be at least 2 Channels for any V6 or V8 engines. datatransfer to ECU also via can bus, but having a 0-5V analog out per channel will make this unit versatile and usable on any other programmable ECU. If there is any room for 4 Channels it would be more versatile to use it on 4 cylinder turbo engines.
But these wishes seems to be out of sight with a 24 pin connector... ;-)
Best regards,
Chris
Dron_Gus
Post by Dron_Gus »
chaoschris wrote:
Fri Apr 29, 2022 10:28 am
This means:
Best regards,
Chris
Yes. Two analog outputs per channel is out of connector capabilities. I believe CAN should be primary (and the only one) channel for data logging.
Start signal. Currently +12 to AFR heater is connected outside this controller. Only Heater- is routed through controller. And we have separate +12 for controller power.
So user can connect heater's +12 through IGN line or use relay + output from main ECU or switch.
As we have EGT on board we can wait until exhaust reached some threshold temperature before starting heating AFR.
Also we can wait until battery voltage rise above +12.5 (for example) to be sure that engine is running.
BTW current (one channel) FW waits for "allow heating" signal from ECU. This is RusEFI specific.
How does AEM (and others) AFR gauges prevent nerst cell cracking? AFAIR it starts heating as soon as powered.
EGT is two channel. Currently no dedicated analog outputs. We can make two available analog outputs configurable to be able to output EGT too.
Dron_Gus
Post by Dron_Gus »
JRD McLAREN wrote:
Thu Apr 28, 2022 11:18 am
Good connector and enclosure.
To add any further feature we need to go 64 or 100 pin STM32.
Dron_Gus
Post by Dron_Gus »
BTW does anyone know is there any special rules for termocouple wiring?
Will the signal be affected if routed through general purpose connector and using copper wires?
I mean Tref point temperature should be known to calculate correct termocouple temperature. But if we have chromel/alluminium to copper connection somewhere outside controller (under hood)... Will this affect accuracy?
MHTSOS
Github Username: MHTSOSVOODOO
Slack: Dimitri C
Post by MHTSOS »
AFAIK you are not allowed to use copper wire to extend thermocouple cables since every wire connection will act as a separate thermocouple junction and alter the reading. Ideally the thermocouple should be connected to a suitable connector right next to the IC so that it's cold junction compensation can cansel out the error induced by the junction formed between the leads and the connector metal.
finding the proper connector for the thermocouple of a certain type is a quest in itself. however, if you look at cheap thermocouple plugs used in some multimeters - you might think there is nothing special in them - the wire's end forms a loop, which is just fixed to the plug with a screw. but you can't be sure what exactly alloy is used in those plugs or screws..
JRD McLAREN
how accuracy we need for thermocouple ..?
5 or 10degC ,, ??
that is yet another good question, and if 10degC is enough, probably it won't matter what sort of connector you use ;-)
JRD McLAREN
look at VWAG EGT sensors for DPF filters ...
or other marks ...
they have "stock" connectors ...
and inaccuracy is about 5-7 degC
(sensor have aprox. 2-3 degC itself)
Dron_Gus
Post by Dron_Gus »
Some progress.
kjn260
Post by kjn260 »
Dron_Gus wrote:
Sat Apr 30, 2022 9:24 am
In high level motorsport applications, they make Chromel / Alumel contacts for Autosport connectors to maintain accuracy. I suspect in this case the difference would be marginal over the required range for exhaust temperature measurement, its also very easy to add an offset in software.
Might I suggest considering something like a MCP4728 with a buffered output for the DAC in a future version? I've used this before in applications where we required to "emulate" a 0-5V (or 0-1.2V Narrow Band) its a great chip (although very hard to get at the moment to be honest, $29 at LCSC, unavailable everywhere else) - "usually" they are $2-3 - but that price point might be a year away still.
Benefits:
-Use existing i2c bus on the F103, releasing PB14 and PB15 for other uses
-Gives you 4x Analog outputs, with programmable voltage ranges (e.g. 0-1.2v for narrowband output, 0-5v for lambda, 0-5v for thermocouples etc)
-Very easy to implement in software
also +1 vote on the 32-pin enclosure!
Dron_Gus
Post by Dron_Gus »
kjn260 wrote:
Tue Jun 28, 2022 1:10 am
Benefits:
Thanks for feedback!
I been using single channel version of MCP4728 in few project for DCDC converters reference. EEPROM is cool feature that allows us to setup and save output voltage before shipping device to customer.
Due to chips shortage everything costs too much. Going to sync with our HW engineer, they just ordered new batch of devices - I wonder if they where able to found this chip or changed it to something more available.
Going to add some DAC as option. And rework current PWM to analog with this trick https://www.edn.com/cancel-pwm-dac-ripple-with-analog-subtraction/ .
Dron_Gus
Post by Dron_Gus »
Full Optimized – High Speed mode over UART@115200.
Status update - at least it heats the sensors up and something is displayed :) Also clearly a bug of some sort with wrong heater voltage only on one channel.
This board has C10 & C35 removed in light of BOM bug https://github.com/rusefi/rusefi-hardware/issues/172
This video was done with forked https://github.com/dron0gus/wideband firmware hopefully one day this would be merged into upstream completely.
Log file attached
with capacitors replaced https://github.com/rusefi/rusefi-hardware/issues/172 dual channel board shows something reasonable on a real vehicle
