work in progress Common Rail MC33816/PT2001 dev board - 4 injectors GDI
Re: Common Rail MC33816/PT2001 dev board - 4 injectors GDI
GDI4 ready for fabrication but can use some review https://github.com/rusefi/rusefi-hardware/blob/main/GDI-4ch/gerber/GDI-4ch.pdf
GDI4 rev A has landed
We have first hack and first success reported from Seattle.
GDI4 is now available at https://www.shop.rusefi.com/shop/p/gdi4
Bluepower
Is this only the GDI injector drivers? Or complete plug&play ECU for 4x GDI(like VW/audi TFSI engines)?
Just updated https://www.shop.rusefi.com/shop/p/gdi4 description
Chris says that Design Simulator Environment for PT2001 PSC - Standard
ASA-PT2001-STD
is the smart way to develop for this chip
ASA-PT2001-STD
In 2018 I've made a hole in TPIC
Nick made a hole in TLE8888 last year?
Chris follows this fine tradition with NXP
Yes first MRE
Still work correct no problem same tle 8888
Rev C is one JLC fabrication defect I cannot sale those. Trying to get a refund via "Quality Complaint", hopefully I would not have to go credit card charge back route. https://github.com/rusefi/rusefi-hardware/issues/143
I now have rev D boards https://github.com/rusefi/rusefi-hardware/blob/main/GDI-4ch/gerber/rev.%20d/GDI-4ch.pdf
Intention was for the boards to operate as 4 injectors + 1 pump from factory, and to fit into the stamped case.
Boards now fit in the stamped case!
I do not see signs of pump control.
On bench I have firmware with default settings, power/GND and GDI injector hooked to simulate pump. When I ground control wire pin 41 "IN_PUMP" nothing happens
When I hook same injector as injector 1 and ground control wire pin 44 "injector 1" I have injector clicking as expected.
What can I do to move towards HPFP control?
https://github.com/rusefi/rusefi-hardware/issues/208
^^^ microcode defect - it reads START6 line not START5 for pump control
New issue https://github.com/rusefi/rusefi-hardware/issues/209
I am able to reproduce with both rev A and rev D on the bench. GDI4 fails to initialize the chip as long as I have three injectors just connected to the board - one acting as fake HPFP and two others have to be on different banks.
With a few issues fixed it looks perfect
on a bench during heavy duty cycle clocking boosted voltage falls down the cliff around 5300 RPM
At 5100 RPM boosted voltage does go down as well but much much slower. Some more data at https://github.com/rusefi/rusefi-hardware/issues/221
GDI4 units are used on the flow bench of a racing injector _manufacturer_.
Their biggest concern at the moment https://github.com/rusefi/libfirmware/issues/12
Less pressing issue https://github.com/rusefi/rusefi-hardware/issues/256
Next step 4K-GDI fully integrated ECU.
Bluepower
Omen234
- Github Username: romioRN
Omen234
here are some pictures for you so that you don't get bored. fully working GDI-4
Wow these are some pretty cool pictures!
Are those recent additions we've missed?Programmable integrated End-of-Injection (EOI) measurement function
(MC33PT2001HMAE and MC33PT2001MAE)
Boost voltage up to 80 V (MC33PT2001HAE and MC33PT2001HMAE)
Noxz
possibly released in 2022? unknown when distributors got their hands on them.
BMW B58 has been started using this board!
Bluepower
Wow, that is really promising, to get a B58 running
More on B58
