L9779WD-SPI - Multifunction IC for engine management system
I'm just about to order the dev. kit for this chip:
http://www2.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/automotive-ic-eval-boards/eval-l9779wd-spi.html
Re: Multifunction IC for engine management system
Nice, $12 chip and $130 eval board. It appears the eval PCB is also 2 layer, which is a good thing. I wonder how much heat it makes, and if it might need a heat sink.
I see the mating SPC563M-DISP is $95. This is basically a full ECU for about $230.
Horizonjob is working on an SPC56 based ECU but I'm not clear on what free tools there are to support that series.
Re: L9779WD-SPI - Multifunction IC for engine management sys
84 in stock
http://www.digikey.com/product-search/en/integrated-circuits-ics/pmic-power-management-specialized/2556708?k=L9779WD-SPI
does anyone want to make our own dev board for this? If we order 50 pieces we can kind of have the piece of having this available for some time
The IC has a thermal pad underneath so you need to move the heat away through the PCB, it does rather a lot for a small chip.kb1gtt wrote:Nice, $12 chip and $130 eval board. It appears the eval PCB is also 2 layer, which is a good thing. I wonder how much heat it makes, and if it might need a heat sink.
You would need analogue input circuitry for a full ECU.
This would be a great chip to use with my CPU cards. That's basically why I kept the analog on the CPU board and put the external driver stuff on the partner card. Not having these features married is a good thing, it's easy to imagine lots of driver boards.
You should be able to set up a cross-compile environment in Linux. If you can open the serial port to the 5634 and get it to echo a character - in theory you can download a boot strap and start talking to it. I think there is free software that is well supported to do this ( U-Boot? ).
Used to be we ran Linux and all the tools for PPC development on Apple workstations which used a PPC inside ( year ~2000 ). Compilers, debuggers and whole operating systems for these architecture chips goes way back. On the dev board for the 5634 they used a USB->Serial/JTAG interface with a software package for Windows.Horizonjob is working on an SPC56 based ECU but I'm not clear on what free tools there are to support that series.
I'm open to sharing a lot of my stuff. Just to start, library stuff is pretty easy. I wonder if you can declare footprints and schematic symbols for boards outlines with connector or header pin locations included? Sounds like it would work.does anyone want to make our own dev board for this?
Yes you can. I think I've done this before with a Cinch Enclosure. Although perhaps not as automated as might have implied. Basically I used a symbol on the schematic that included the pins, then the footprint in PCB land used the same pin names. The footprint included the PCB outline, but on the drawing layer.Horizenjob wrote:I wonder if you can declare footprints and schematic symbols for boards outlines with connector or header pin locations included? Sounds like it would work.
Using this 5634 and this chip, you basically could make an ECU that's about the size of a playing card. Very small and very compact. Now if we only knew of someone who had a 5634 and could program it with free tools
I'm not a Linux guy so, as much as I like Freescale products they are a no for me for limited production runs or personal use. If the chip looks good then I will get some boards made
Hi Rhinoman. I must have given the wrong impression somewhere. Freescale doesn't even support Linux, I don't think. With WIndows you should be good to go. We can talk more about tools but maybe another thread is better?I'm not a Linux guy so, as much as I like Freescale products they are a no for me for limited production runs or personal use. If the chip looks good then I will get some boards made
- Dron_Gus
- Github Username: dron0gus
Hi all.
Did anyone have test this IC? Looks quite good for my task (make rusefi variant for ej20g is for stock wiring and in stock case).
BTW, how much current does CPU consumes over 3.3. Did any one measure? L9779 has integrated LDO 3.3 with 100 mA max load. Will it be enough?
I know http://rusefi.com/forum/viewtopic.php?f=10&t=557 is using some cool chips but not sure about this one.Dron_Gus wrote:Hi all.
- Dron_Gus
Thanks.russian wrote: I know http://rusefi.com/forum/viewtopic.php?f=10&t=557 is using some cool chips but not sure about this one.
But he uses TLE6244x - set of 18 low-side switches without any additional features.
While L9779 has some features useful for me:
4 x IGBT drivers. Not sure if there is IGBT transistors inside ignition block on my Subaru. But stock Subaru ECU uses some "special" driver builder on discrete components for pre-driving ignition comutator. For all other outputs there is basic N-channel MOSFETs.
3V3 and 5V voltage regulators. Quite weak, but enouth to power CPU and op-amps.
VR sensor block. Unfortunately only one.
And CAN and LIN drivers. But my car leak of any can or lin bus
There is another one IC for driving external IGBT-based ignition commutator - MC33810 with additional features for controlling spark. But my stock wiring leak feedback signals from ignition switches, so I will not able to use all features of this driver. Also documentation is quite lean.
L9779WD by ST
What a cool chip obviously not available https://octopart.com/search?q=L9779WD-spi
proper SPI version https://www.st.com/resource/en/datasheet/l9779wd-spi.pdf
careful there is a non-SPI version https://www.st.com/resource/en/datasheet/l9779wd.pdf
Re: L9779WD-SPI - Multifunction IC for engine management system
In light of that SPI vs MSB incompatibility I wonder what does "L9779WDAT2" marking mean - in light of all the ebay/aliexpress sellers offering that L9779WDAT2
AT - Automotive grade. 2 - no clue, double automotive?
L9779WDM - 4.9- 5.1v
L9779WD - 2.9 - 5.5v
But looking at that info, there is 0 mention from ST regarding those markings. I'm going with most likely either engineering samples, or Chinesium grabage. We shall discover jan 16
"Dave B. 5:03 PM
- Dron_Gus
Here's what I have
Nice! So L9779WDAT2 is officially L9779WD-SPI
- Dron_Gus
Funny thing: L9779 has the same WatchDog question-answer table as TLE8888.
But TLE8888 datasheed just defines answer table for each question and phase.
While L9779 datasheet also provide detailed description how to calculate answers using question, Markov (who is Mr. Markov) chain and binary logic.
What kind of detective work can we do comparing original dev board with two different aliexpress purchases? Does anyone see month of fab or anything encoded here? 935 034 are those batch numbers or else?
Look it's pretty much an ECU! At @Dron_Gus's
- Github Username: mi-hol
Thanks for mentioned this post in TLE8888 issue.
Does rusEFI firmware actually run on it?
Best Regards
Michael
Benelli Tornado 900 Tre
Benelli TNT 1130 (rebuilding)
Michael
While Dron has clearly made a lot of progress I am not aware of any real test results being published https://github.com/rusefi/rusefi/commit/10cab3390a708accfcff49f9acd09691407b96be
My interest in L9779 was revived by https://rusefi.com/forum/viewtopic.php?p=47073#p47073
@Dron_Gus would you mind to share any test results with this board?AndreyB wrote: ↑Sat Feb 18, 2023 3:35 pmWhile Dron has clearly made a lot of progress I am not aware of any real test results being published https://github.com/rusefi/rusefi/commit/10cab3390a708accfcff49f9acd09691407b96be
Best Regards
Michael
Michael
- Dron_Gus
- Github Username: junior-q
i started a draw with this chip, just used any input and output but ... have you seen any prob. ?
only doubt about dissipation and the 5V regulation due to the series mosfet (not sure really well working, may be we can add capacity) ... have you used a different mos ? (from ST desgin)
- Dron_Gus
Nothing were done with this chip since Dec 2022. Project is on hold. Sorry.junior-q wrote: ↑Wed Sep 06, 2023 10:51 pmi started a draw with this chip, just used any input and output but ... have you seen any prob. ?
