BGA in ECU
BGA in ECU
Concerns about BGA in rusEFI were raised more than once. How does OEM get away with BGA for instance TriCore in BGA-180? Better QC? Any fabrication magic?
Re: BGA in ECU
This question is half about GD32F450IIH6 half just general curiosity.
Re: BGA in ECU
I understand x-ray inspection to validate proper soldering is also a key feature from OEM. Which is difficult for us.
Re: BGA in ECU
Which is of even more curiosity is why do they offer these for their pick and place service? (Or they just don't?)
Re: BGA in ECU
I worked for my old employer in the field of networking (CAN, MOST, LIN, ...) and accordingly had a lot to do with the OEMs, especially Bosch, Siemens, VDO, Delphi, but also ZF, VW, Mercedes, BMW.... We have also developed hardware and software for networks ourselves.
I have never had an ECU from Bosch or Siemens in my hands that had BGA components in it. But, the whole thing was 7 years ago, so it may be different nowadays. In our hardware we had BGA components in it and it was so that the first approx. 80-100 pieces of hardware ended up in the scrap because the ICs were not soldered cleanly (X-ray examination at the pcb manufacturer).After that it worked, but as I said, the scrap was very large.
In the car, I would avoid the BGA ICs in any case, whenever possible. It is not an environment for BGA, extreme temperature fluctuations, vibrations, different expansion of PCB and IC ...
Re: BGA in ECU
some are certainly BGA these days, for example, bmw n52/n54 (and presumably most newer):
Re: BGA in ECU
Yes, for us, 100% true. We simply don't have the development, production, and validation resources available to make BGA work.
Re: BGA in ECU
Puh, okay, as I said, 7 years ago.
Thank you for the picture!
Re: BGA in ECU
That ECU is from 2007
Re: BGA in ECU
You are right, then I missed something...
Nevertheless, BGA sucks.
- Dron_Gus
- Github Username: dron0gus
Re: BGA in ECU
BGA will need at least 8 layer PCB. And skilled PCB developer for correct fan-out.
We been producing car monitoring systems 10-15 years ago. One was based on AT91SAM9G and another on s3c2416. Both bga. Plus DDR ram. This system been working on heavy trucks with no issue for years.
Also BGA soldering is not a problem for skilled manufacturer. From my experience I would say most problems caused by chips with no pins (QFN) and small 3-6 pins chips (sot-23 and similar).
Re: BGA in ECU
The amount of BGA failures in automotive equipment I've had to deal with is through the roof. Last one was a few months ago. 2020 Dodge Charger ECU. Press on the bga MCU, and it comes to life.
Common modules with BGA mcu failure are 2008-2020 BCMs in GM light vehicles (eg; cruze), early ford/mazda Continental ecus, BMW Tricore Ecus.
And this is just the shit off the top of my head. I have yet to see a BGA based module that is located under the hood that doesn't suffer from failure. Regular solder is susceptible to failure from micro vibrations and heat fluctuations, and sticking it under the hood where there is a fuckton of those environmental variables I consider to be idiotic.
Here is a module that does not have a BGA processor, instead fails due to soldering issues. They have tried epoxy, and then putting hot glue on top, and it still fails non-stop. This is a FICM module on diesel fords, a quick google search can explain that quite well.
No BGA. BGA bad. Fuck BGA.
OH ANOTHER POINT. Delphi, stopped using BGA processors in all their latest lineups for ECUs.
"Dave B. 5:03 PM
- Github Username: blundar
- Slack: Dave B.
- Contact:
Re: BGA in ECU
FICMs don't fail due to soldering issues. They're essentially a heavy-duty boost converter and PnH driver in one. The FETs are mildly underspecced for long term reliability, plus the usual capacitor issues. Although I replaced a lot of components "just because" I did test as far as finding a couple of FETs that were starting to become dead shorts in my FICM that was putting out 19V vs. 48 desired.
Dodge ECMs are notorious for BGA issues. BGA = the suck, especially in an environment where they experience many cold/hot thermal cycles and tons of vibration with lead-free solder.
Re: BGA in ECU
FICMS very specifically die because of soldering. Of all the FICMs I've ever fixed (and oh boy theres a fuckton), I've never had to replace a single component in them. The shunt resistors literally lift with the hot glue. Resolder them all, and its back to perfection.
Regarding BGA, completely agree, complete shit, should not exist outside of static consumer products.
"Dave B. 5:03 PM
Re: BGA in ECU
Another ECU that drops dead like flies is 64pin Magnetti Marelli in Fiats. BGA cpu and the ECU is bolted on the top of the engine. The only logical reason I see for an OEM to do that is to cut down on cable length for the harness.
Re: BGA in ECU
They shouldn't exist there either. The amount of products that die due to BGAs pads cracking with thermal cycling is massive.
I see NXP have moved to a dual row pin design for its auto specific processors to increase the pin count without needing BGA.
Its a mix of LQFP and J lead.
