[info] microRusEFI
Re: microRusEFI
MSD = USB mass storage (Mass Storage Device = MSD)
Looks like it's working though, so that's good!
Re: microRusEFI
Re: microRusEFI
OK ... mass storage ... (I know)
and another pic for future generations ...
Re: microRusEFI
I have somewhere between 3 and 10 of these microRusEFI assembled as "brain board" with pins sticking out. One day I will have the full inventory and list those on eBay
this specific one is 0.5.0 others could be different revisions
Re: microRusEFI
Is internal Flash memory used.. for anything ..??
Can I use S25FL127SAB flash ..??
cause Winbond W25Q128JVS are out of stock..
S25FL127SAB is almost the same, but 108Mhz only ...
How can I test it .?
Re: microRusEFI
micorusefi still does not use on board flash
Re: microRusEFI
PanasonicVL-621/DN is perfect RTC battery for MRE..
can be soldered directly to PCB
https://www.tme.eu/sk/details/vl-621_dn/akumulatory/panasonic/
Re: microRusEFI
Funny thing how we still do not use that on-board flash chip
In the meantime removal of the flash is the way to wire bluetooth on the older microRusEFI editions like https://rusefi.com/forum/viewtopic.php?p=37479#p37479
on anything 0.5.0+ we have extra pins available and that hack is not needed.
Re: microRusEFI
...but bluetooth works to version 20210306 ...
EDITED:
115200,8n1
EDITED:
115200,8n1
Re: microRusEFI
I'm try update to 20210719 .. and something is wrong ...
..is cam_debug "hardcoded" in current bundle ..??You do not have the required permissions to view the files attached to this post.
Re: microRusEFI
No, it is not hard coded
Please post a link to your current tune on rusEFI online
Re: microRusEFI
..I'm found it ...
EXPERIMENTAL -> cam debug ....
When I'm was try to flash it for the first time, it frozen ..
and now I have some settings broken ...
But, bluetooth commmunication still not work ..
it is 38400,8,n,1 . ?
Re: microRusEFI
Can it will be used for log file storage .. ??
..rotating ...
Re: microRusEFI
Not really worth the effort, no. Our other ECUs now all have SD cards instead, and that works really really well. Some day MRE will get an SD card too.
Re: microRusEFI
OK ... it's just a question ...
SD Card works well...
Re: microRusEFI
"22 - AN temp 4" is an option for vehicle speed sensor on VSS
JRD did it require any hardware mods at all? Anything to remove or add? What exactly are the changes to use "22 - AN temp 4" as VSS?
Re: microRusEFI
It works well...
No modifications needed.
My VSS is Hall type 12V .. and works. (Grounding signal)
Signal wire is connected to 22- AN Temp4 directly without any pull-up/down resistor or divider.
EDIT:
...and 24 - AN Temp3 works too ...
EDIT:
Re: microRusEFI
VSS Tested and calibrated this friday ...
it works at 140kph with no issues ..
"no more space" to test it at 200
..or higher ...
6teeth and 0.54ratio (coef)
..or higher ...
Re: microRusEFI
VLND5090TR can be replaced with BM2LC120FJ-C or BM2LC105FJ-C
but 3A current only ...
..it is still enough, I hope ..
and I'm not sure for IPD30N06S2L-23
Vishay SQD30N05-20L -- LOOKS BETTER ???
Re: microRusEFI
Is anyone driving on microRusEFI in US?
It looks like tle8888-2qk non-watchdog version of the main chip is no longer available and I am looking for a definitive test of a unit with tle8888-qk.
- Dron_Gus
- Github Username: dron0gus
Re: microRusEFI
L9779-SPI is a candidate for TLE8888 replacement on MRE.
Some additional cool features (comparing to TLE8888):
3.3 V logic regulator
– 3.3 V precision voltage regulator (± 2%) with over-current protection
ISO9141 interface
–ISO9141 serial interface (K-Line)
Maybe something else.
ISO9141 interface
Re: microRusEFI
Not sure why it should happen but that would definitely be a different board name. As is TLE8888 and L9779-SPI seem like more or less the same thing just from different vendors. I think as long as we can purchase TLE8888 we would stay with it?
- Dron_Gus
Re: microRusEFI
Yes. I see no reason to switch to 9779 until we (you) can get 8888.
But with 9779 we can make fully ST-based ECU.
Re: microRusEFI
..and ask for tle9201 replacement also ..?
- Dron_Gus
Re: microRusEFI
Yes. Something like L9960T
Re: microRusEFI
I'm found something "bad" .. in schema ...
(and on pcb also)
We have powered TLE9201 via 12V_MREL line..
..and ... we have NO POWER for E-Throttle WHEN we hit the starter ...
(and on pcb also)
Re: microRusEFI
Please provide much more context. My microRusEFI has working ETB so your problem has to be specific to some vehicle? Very limited telepathy abilities still, without vehicle name and portions of schematics I have no idea what problem you are reporting.
Re: microRusEFI
So ....
12VRelay is DOWN, when the starter is ON .. Right ....? (12V_MREL line)
If the answer is YES, the E-THROTTLE is OFF, and we have no power during start / cranking - for it
THEN
we can't flush cyls (if we need)
we can't add more air (via throttle pedal)
we can't driving idle ..etc ..?
I'm got focus on this when I'm can try to find 12V source for addon board....
THEN
- Dron_Gus
Re: microRusEFI
TLE8888 will enable MainRelay output as soon as 12V_KEY (connector pin 5) is high.
Check that you are using correct IGN signal for this pin. One of IGNs can be disabled during cracking.
Re: microRusEFI
..is not problem, how fast is MainRelay ON ... after ACC / IGN signal
this condition is potential problem ... probably ..?? when TLE9201 is powered via 12V_MREL .. ??
12V_MREL ON - stopped engine
12V_MREL OFF - cranking
12V_MREL ON - run / idling
RIGHT .. ?
I have no problem on any (my) car at this moment ...
but maybe someone sometime ...
.. I'm assume:12VRelay is DOWN, when the starter is ON .. Right ....? (12V_MREL line)
RIGHT .. ?
