Pavel
@Mad Rat got me in touch with a 2003 and 2004 Nissan Almera owner - 1.5 and 1.8 engines
We've compared VIGN, injector and crank/cam pins, match! Time to drive a vehicle on Hellen Nissan!
Got pedal sensor calibrated, things are amazing!
Second step ETB motor - there is some buzzing but no movement. I forgot to solder pin #3 and forgot to implement ETB relay control - FSIO to rescue, we got ETB movement!!!
But got a very weird
https://github.com/rusefi/rusefi/issues/3137 error and started tracing things with digital multimeter.
That's where things went down. TPS input pins were shifted by one position on Almera. While touching things Pavel has burned his finger on coil control module on Hellen. That's where we found a relay on where we were expecting coil #1.
Good think we have a lot of 0R on the board
 With four 0R removed we got TPS to show something reasonable, and coil module is no longer hot to touch! We even clicked 3 injectors (due to chip shortage boards farbictated with 6 not 8 mosfets - would need to move on), and 2 coils (todo).
No RPM. Signal pins match expectation but Altima has crank/cam GND going into ECU while Xterra has crank/cam GND in vehicle harness.
Wait, one of the crank/cam Almera GND pins has a legit usage on Xterra!
More 0R removal more jumpers, we got RPM.
So we are at six mismatched pins, will continue after some fixes to the board and settings.
Almera wiring diagram mentioned on
https://github.com/rusefi/hellen121nissan-issues/issues/13
