tunerstudio trigger angle
Andreas_28023
Post by Andreas_28023 »
Hello
In which direction should I measure trigger angle offset, alpha or beta?
Kind regards
Andreas
Re: tunerstudio trigger angle
Andreas_28023 wrote:
Fri Oct 09, 2020 5:54 am
Hello
Kind regards
AndreasImage
Skickat från min SM-N960F via Tapatalk
In this case, I think you want to use negative alpha. My car has the missing tooth roughly 90 degrees BTDC #1, and I enter 86 to get the timing light to match up.
Yours looks like around -60 or so.
Should we change parameter label from "trigger angle offset" to "trigger angle advance"?
AndreyB wrote:
Fri Oct 09, 2020 6:01 am
it's probably at least worth explaining in a tooltip
Andreas_28023
Thanks
//Andreas
