[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [info] Proteus - Waterproof, High-feature ECU! - Page 3 - rusefi.com
Those original (M73) throttle bodies are twin 2xstepper motor based, unless you plan on using M70 throttle bodies you cannot use these with the proteus. Sorry
i ditched the throttle bodies. LKQ pickYourPart wanted $40 each for them.
I can buy a more modern one... for that kind of $$
A batch of v0.3 boards has been ordered! I have 25 boards enroute to me near Seattle, and half-ish will get forwarded on to CrazyStriker in France.
I'll keep y'all posted as they're fabbed!
If you have one spare, I would be interested on running one on my BMW M70 V12 E36 build? I live in Norway, so shipping wise CrazyStriker would be closest.
I think this batch is all spoken for already. I'll keep y'all posted if there are more that happen in the future.
One thing to watch out for, we have just discovered shipping into Norway from the rest of the EU means you get stung with 25% vat, so be aware of that.
If this first batch goes OK and we get a good case solution together this is probably something I will keep in stock in the UK.
I see that your board uses the STM32F7xxx
Micro, I think I have a Nucleo 411 dev board that has the same micro, wondering if I can use that to test the code on?
I am pretty new to the STM stuff, I did a little playing around awhile back using the Mbed online IDE, But outside of that I’m pretty much an Arduino hack.
Well, if all of those boards are spoken for, I can have some made.
I downloaded the KiCad file last night and looked at it, the Gerber file on the git didn’t work directly, but the PCB file looks just fine, I may just use that to generate the Gerbers and send those off.
when do you expect to have the second batch? I don't see them on sale either in USA or in Europe.
You don't see them on sale since at the moment no one is announcing plans to start fabricating them Let me check with Matt if I should start fabricating those.
I suspect that Matt was looking to get some external validation on the existing batch of boards. I suspect that waiting a week or something like that would either validate that the design is good and solid, or it might find some kind of issue that can be resolved on the next batch. I believe the existing batch has only been validated by Matt on Matt's equipment. You get an entirely different level of validation when others do something with it. I think Matt is trying to ease into it, so that if there are changes it has minimal heartburn for everyone.
Apparently! I think at least a few from this batch are planned to run V12s, which is awesome!
speaking of V-12's
do you guys want to come up with a standardized PIN-OUT for the V-12?
so we can all wire the boards the same for the injectors/coils/cam sensor/ crank sensor/ MAP sensor/ etc?
make life easier, i reckon
Just post how you are wiring it, and i will copy your layout.
First batch was a trial one, with some culprits in board design that have been solved. It is now normal to see higher pricing especially considering the work involved for each board. If the formula doesn't satisfy you you still have the option to order boards from JLC directly as the design is fully open source. You're paying for supply chain as well as time involved. Proteus will probably end up following the same pricing system as every other RE based boards.
not sure what you mean about RE pricing system, but let's wait for the actual prices then.
that was exactly elimination of logistics issues and headaches, which made that offering (afaiu, expeced $150-200 shipped, with all the needed connectors) such attracting.
just curious about the reasons for that price bump - you mean to say, the first batch didn't require soldering by hand?
One reason for a price bump is that the US-assembled batch of 0.3 boards had free connectors from TE. The connectors and pins together are around $60. The first batch did require hand soldering, but it was also a beta run to help get more boards out in to the wild to detect issues.
