[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result PNP ECU for Vw/Audi ME7 #51 - Page 3 - rusefi.com
are you looking for external for a mock up or internal for next PCB revision? what about same as on Frankenso? Can you piggyback Frankenso as a temporary solution?
I am looking for a internal solution for next revision.
I would prefer one IC, but TC4427 might be the best solution?
If you get it to work with the 4427 take some measurements and let us know amps and volts. It would be difficult to make a suggestion when I do not know the load. Also if you post the amps I can check for thermal issues.
The coils are TTL, with 390 Ohms.
I found others use them with the 4427.
I am sorry, but you are not good at transferring ideas in written form. You did not specify the subject of "not working", you did not specify your criteria of working/not working.
I am not enjoying this guessing game. I am investing my time in answering questions, please invest time into reading some links at https://rusefi.com/s/questions
I know this is a bit harsh, but I value my time and we need to compromise to be more efficient.
Ola, can you please help me wire TPS analog signal into one of the red boards? Is there a 3.3 v test point for me to use as TPS sensor power? Can you draw on a picture of the board showing signal input and which pads to jump to simply feed 3 volts TPS directly into stm32?
I know, but this is not an issue, as I just had the wrong channel selected.
When calibrating TPS with wrong channel, I had like around 1000 closed and 100 fully open.
Then it showed right at the TPS gauge.
When pressing the pedal fully down(or fully closed), it seemed right at TPS gauge.
But by pressing the pedal to anything between, and holding it still, the TPS gauge always started moving slowly towards 100%.
For 3.3V output, just put a wire to first pin at swd.
Pads are at the back CU, see attachment. Just solder wires to the pads Anout1, anout2, anout5 and anout12.
