I'm trying to get my first startup with the M52Bxx board I made earlier.
Attached are the .MSQ and a log of me trying to start the engine. It almost fires, but then trembles and fails.
I've currently wired each injector and ignition coil:
Cyl1 -> IGN1\INJ1
Cyl2 -> IGN2\INJ2
Cyl3 -> IGN3\INJ3
Cyl4 -> IGN4\INJ4
Cyl5 -> IGN5\INJ5
Cyl6 -> IGN6\INJ6
Currently in MAF mode for ease of integration, will later go over to MAP\SpeedDensity.
Trigger is the bosch 60\2 on the crank, only using this at the moment as there is an error in my CAM hardware. Trigger angle is set up so it's spot on at 0deg.
Injection is where I'm currently questioning my abilities, is this supposed to be at -180 deg?
Below is the schematics used for the current "modules"...
I'm new to the rusEFI console, but I added some snapshots of the Sensor\Engine Sniffer...
If anyone has any suggestions, I'm open to them!
Trigger: Injection: Ignition: Sensor Sniffer: Engine Sniffer:
