Say 6 by 6 by 0.75 inches like
I have that WBO controller under the hood - does not it have plastic case? So how comes the WBO is OK - what's the difference between an ECU and a WBO controller, why would one tolerate plastic and the other one would not?puff wrote:if it's made of plastic then it's pointless - it won't filter any emi noise
I'd argue that if you're generating injector and ignition currents within the ECU, you really need to be concerned about EMI. It'd suck to have an injector trigger an ignition event, right?kb1gtt wrote:Concerns with EMI are based on if you expect to emiter radiate radio frequencies, of if you expect your board to be effected by possible near by radio frequencies. You can use plastic enclosures if you expect the RF is not a problem. If it is going to be a problem, you typically need the metal enclosure for shielding.
Well, the Denso case we currently use is probably a no go for under the hood - there are gaps around the connector. The not water-proof connector.kb1gtt wrote:A hole in the ECU for the SD card is pretty much a no go for under the bonnet / hood.
You could just drill a hole and print an extension piece for the current button. Basically a plastic rod maybe throw a pen spring onto it so its not flapping around.russian wrote:Not much to see - getting the shape right, waiting for new revision of brain board and tall reset button from China.
We kind of should have matched the discovery reset button locaion on the brain board but guess it's a bit too late.
