Good morning everyone,
I'm a university professor by profession and I am working on different engine projects with my students. I do quite a bit of DIY on my own vehicle as well. I'll be using the rusEFI at first to drive a 3-cylinder Daihatsu KFVE engine and then, a Toyota 1UZFE 1st Gen. The Daihatsu has a turbo, COP and VVT. The 1UZ is for the moment running twin distributors and batch injection, I hope to transfer it to sequential ignition *and* sequential injection. Let's see how things go.
Good morning from Islamabad, Pakistan
Re: Good morning from Islamabad, Pakistan
Welcome to the forum! I like the idea of students spending time testing and expanding rusEfi
See http://rusefi.com/wiki/index.php?title=Manual:Engine_Type
I've added a close-enough-for-now version of your 36-2-2-2 crank wheel
I've also added a shortcut for your engine configuration. Do you know your injector rate? Do you know your MAP sensor calibration?
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/config/engines/daihatsu.cpp
