v6 cologne engine
slavik
v6 cologne engine
Post by slavik »
Hi all,
im from Russia, Republic of Tatarstan, Kazan.
I have car for customazing and experiments - Ford Granada 1985. Ford V6 Cologne inside it.
Cologne Family engines 60-90 years - Taunas, Granada, Scorpio, Capri, Cortina, Sierra, Bronco, Explorer http://en.wikipedia.org/wiki/Ford_Cologne_V6_engine
Its carburetor V6 engine, but old version with ecu.
My question is "Can i use rusEFI with it?".
Image my Granada
Re: v6 cologne engine
slavik wrote:My question is "Can i use rusEFI with it?".
Welcome to the forum!
What exactly do you want to achieve with rusEfi? But yes, you can anyway :)
slavik
Post by slavik »
First. VAZ January 5 cant work with V6.
Second. I want play with custom ECU in my Granada ))
Third. Just for fun, and for self-education, its my hobby
I think russian was looking for a list of goals like this.
-- 6 channel port injection, or single carb injector
-- 6 channel ignition, or single coil distributor style
-- sensor including intake temp, coolant temp, MAP or MAF, ect.
Then the short answer is, yes it can do all of the options noted above.
slavik
Post by slavik »
kb1gtt wrote:I think russian was looking for a list of goals like this.
Thank you, exactly. That list describe im looking for.
Go to read more info on forum.
P.S. 2russian: first time see about rusEFI on habrahabr forum
The wiki is a semi boiled down version of the forums. You probably would find interest in this page http://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_board
what's the original purpose of ecu in this vehicle?
I recall I've seen a granada from mid 80s with injection-equipped v6. it could be the very same model of v6 engine ;-)
for instance, i've found an intake manifold from injector engine and this would be an easy swap (at least i hope so). do you intend to keep carb or go injection?
abecedarian
Post by abecedarian »
puff wrote:what's the original purpose of ecu in this vehicle?
A lot of carbureted engines from the late 1970's / early 1980's had a controller to affect O2 sensor based fuel mixture adjustments, i.e. Holley 5200 / 6500 series. Mikuni, Weber and Rochester are among other who also had feedback type carburetors. I also believe Ford / Motorcraft had a feedback type 2150 used on early 80's 6 and 8 cylinder engines.
slavik
Post by slavik »
I collect same original Ford Efi system parts. No problem with this, i use some of them for run with rusEFI, intake manifold have too.
First, my gra cant move. Today i start to swap engine. Extract old v6 to rebuild, and tomorrow, i hope, push another one v6.
Second - return the normal state with carb.
Third - implement rusEFI
