Page 1 of 5
Моё Чудо ... VW Passat B4 ABA ... #16
Posted: Tue Sep 30, 2014 3:21 pm
by Abricos
Vw passat b4 2.0L 8v 5 speed manual ... HIH Mazda millennium Supercharger 30psi or 2.10 bar ...
Re: Моё Чудо ... VW Passat B4 ABA ...
Posted: Sun Mar 15, 2015 9:26 pm
Not rusEfi yet, just first start ever :)
[video][/video]
Posted: Wed May 27, 2015 2:09 pm
by Abricos
1995 Vw ABA engine ECU OBD1 wiring harness diagram
Posted: Wed May 27, 2015 2:12 pm
by Abricos
68/1 = Brouw & Red - Ground
68/2 = Injector out put
68/5 = Yellow & black - Check engine light
68/6 = yellow & blue -fuel pump relay (switch on)
68/7 = Brouwn & red - ground
68/8 = Black & Red - coil power side
68/9 = Black & brown - ECU relay sig (whitch on)
68/10 = Brown - Ground
68/14 = Blue - Coolant temp
68/15 = Lilac - EGR temp (cal only)
68/16 = Brown & red - MAF
68/17 = Red - MAF
68/20 = white - o2 signal/ground
68/21 = Yellow - OBD check port
68/22 = Green & black - Power
68/23 = Red & blue- Power in from ECU relay
68/24 = Injector out put
68/25 = injector out put
68/26 = injector out put
68/27 = White - IAC
68/28 = white - o2 control unit/relay
68/30 = Green & gray - EGR valve
68/31 = Green & yellow - evap valve
68/33 = Brown - Ground
68/36 = Blue & green - intake air temp
68/37 = Green - AC
68/38 = Black - coil signal side (tack side)
68/39 = Blue - AC
68/40 =Green & white -TPS
68/41 = Black & yellow - TPS
68/42 = Yellow - o2 signal/ground
68/43 = Grey & white = OBD check port
68/44 = White & red - from distributor
68/51 = Lilac & White - ???
68/53 = Black & white - IAC
68/54 = Red & yellow - from distributor
68/55 = Brown & white - Ground
68/56 = Brown & white - Ground
68/58 = White - Ground
68/65 = Blue & white- vehical speed signal form dash
68/67 = Red - crank sensor
68/68 = Green - Crank sensor
Posted: Wed May 27, 2015 2:19 pm
by Abricos
In any case, double check where Wire are going ...
Posted: Wed May 27, 2015 3:13 pm
by puff
just checking various ecu connectors and the pinouts: is there any guideline on wiring all those pins, like grouping high-current pins (injectors), grounds, signal pins, etc.
Posted: Wed May 27, 2015 5:08 pm
by Abricos
1992-1997 Passat, 1993-1999 Golf, GTI, Jetta
VR6 & ABA Motronic- OBD1 & OBD2
Motronic engine computer for the VR6 (AAA code) and 4 cylinder 2.0 (ABA code) engines. Wiring is substantially similar between all 4 engines, with differences noted below.
Bosch manufactures this system. The OBD1 system is called Motronic M2.9 (M2.9.1 for engines with coil pack), and OBD2 is called Motronic M5.9.
Posted: Mon Jun 01, 2015 3:47 am
by Abricos
Posted: Mon Jun 01, 2015 8:24 am
I wonder if there is any risk in drilling the board in terms of GND layer touching VCC layer on the sharp edges of the hole?
Posted: Wed Jun 03, 2015 1:38 am
by Abricos
Posted: Wed Jun 03, 2015 1:45 am
I wonder if these wires would be enough. These are eBay jumper wires of unknown gauges, right? At least ground wires should be probably thicker.
Posted: Wed Jun 03, 2015 3:08 am
by Abricos
22-24 AWG
Posted: Wed Jun 03, 2015 9:36 am
5A to 8.73A is a thermal limit, and an absolute minimum. As well that's a very high estimate. UL486E puts that around 2 to 3 amps. I see the voltage drop would be about .25V for this short length of wire. As fuel injectors and such turn on and off, it will cause your GND signals to vary which will cause your analog signals to vary as injectors turn on and off.
UL486E snippet found here http://www.wecoconnectors.com/data_source/fichiers/wire_size_specifications.pdf
AWG voltage drop calculator found here http://www.powerstream.com/Wire_Size.htm
Posted: Wed Jun 03, 2015 4:37 pm
by Abricos
Can I use this connection scheme ???
where to connect the ignition coil ???
Posted: Wed Jun 03, 2015 5:32 pm
by Abricos
fule pump relay ???
Posted: Wed Jun 03, 2015 5:42 pm
Posted: Wed Jun 03, 2015 11:50 pm
by Abricos
Posted: Wed Jun 03, 2015 11:51 pm
Posted: Thu Jun 04, 2015 12:19 am
ignition is HL1 or what ever HL you need. This does not drive the coil directly, you need an ignitor. The HL is for high or low driver. The high side can be configured for 12V or 5V. Your OEM VW coil probably has the ignitor integrated into the coil, but it might not.
Posted: Thu Jun 04, 2015 2:36 am
by Abricos
Yes ignitor integrated into the coil ...
Posted: Thu Jun 04, 2015 9:20 am
Is the signal 5V or 12V? You will have to configure the HL driver to driver to the proper high level. There is a jumper that needs to be installed.
Posted: Thu Jun 04, 2015 11:32 am
by Abricos
I have 12 v signal ...
60-2 VR. Sensor ...
Posted: Fri Jun 05, 2015 12:34 am
I need to add a note to this wiki. See P602 and P604. Install jumper across P604 to make this a 12V high side drive.
http://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_board#Hi_side
Posted: Fri Jun 05, 2015 10:28 pm
Posted: Sat Jun 06, 2015 12:18 am
by Abricos
First progressive ...
Posted: Sun Jun 14, 2015 6:01 pm
by Abricos
I changed the VR sensor ...
as the old do not always show a signal ...
It may be the age of the sensor ...
Posted: Fri Jun 19, 2015 2:34 am
by Abricos
Re: Моё Чудо ... VW Passat B4 ABA ... #16
Posted: Mon Jun 22, 2015 1:36 am
Running on rusEfi :)
[video][/video]
Posted: Mon Jun 22, 2015 1:50 am
That's super...
Sorry for the very bad pun.
Posted: Tue Jun 23, 2015 11:14 pm
by Abricos
