New to rusEFI
ThomasD
New to rusEFI
Post by ThomasD »
Hi all,
I'm Thomas, from France.
I was looking for an affordable way to replace a stock Suzuki CDI unit on a motorcycle, that's how I discovered the existence of rusEFI. After some reading here and there, I'm now planning to use a uaEFI board.
The engine is a carbed '93 Suzuki GSXR 1100W (waterboiler), and sits in a Bimota SB6-R race bike.
No plan to replace the carbs since it's not allowed by the championchip rules.
The engine has a VR crankshaft sensor, on which I will install a 24-1 (or 36-1) trigger wheel.
I allready run wasted sparks on Denso pencil coils, and it may stay as is. Maybe sequential spark control in a second step, but adding a camshaft sensor looks complicated.
TPS sensor is already installed and used for logging, mainly for carb tuning, and will be easy to route to uaEFI for alpha-N control.
There is a single WBO2 (Bosch LSU 4.9) sensor, also used for carb tuning, which could be used for altering spark advance, but it seems this feature isn't implemented yet (correct me if I'm wrong).
Cheers,
Thomas
ThomasD
Re: New to rusEFI
Post by ThomasD »
Hi all,
I received UAEFI board last week.
I prepared a small test bench for experimenting different trigger wheel designs (36-1, 24-1, 20-1, 18-1) and see which one gives me stable/reliable results with the stock sensor. I found the configuration for the wheels under Tuner Studio, but I'm not sure, are all these trigger patterns supported by rusEFI firmware?
I also have to install IGBT to drive the stock dumb coils (Denso 3 Ohms pencil coils). I found FGD3040G2-F085C cheaper and easier to source in small quantities. Are these directly compatible with UAEFI board, in place of ISL9V3040D3ST ?
cyrille
Re: New to rusEFI
Post by cyrille »
Good morning,
I think we are the two French with Uaefi.
ThomasD
Re: New to rusEFI
Post by ThomasD »
cyrille wrote:
Tue Jun 03, 2025 1:51 pm
Good morning,
Great to know there is another french onboard !
Where are you from in France ? I'm near Périgueux.
cyrille
Re: New to rusEFI
Post by cyrille »
Saint-raphael- var
