benelli 1130 Tre
Posted: Wed Dec 18, 2024 2:37 pm
by MuShan
Hello everyone, I come from China and my English is not very good, so I am using translation software
What I want to match is my motorcycle, which is from Benelli, Italy
Its displacement is a 1130CC three cylinder engine
No intake pressure sensor
I want to match PROTEUS
What aspects of work do I need to prepare?
Re: benelli 1130 Tre
Posted: Thu Dec 19, 2024 12:40 pm
by mi-hol
Hi MuShan,
I had basically the same idea but due to other priorities have not yet completed that work.
The major work seems to be mapping the factory ECU connectors to the matching rusEFI ECU connectors.
A draft version is at https://rusefi.com/docs/pinouts/Benelli_Walbro/
Recently on the Benelli forum more information became available (see [url]https://www.benelliforum.com/threads/1130-tnt-ecu-walbro-on-testbench-pinout.33672/?post_id=273260#post-273260] ), but is not updated in above mapping yet.
Maybe you wanted to confirm and complete this work?
Posted: Sat Dec 21, 2024 9:43 am
by MuShan
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">嗨,MuShan,</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">我基本上有同样的想法,但由于其他优先事项,尚未完成这项工作。</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">主要工作似乎是将工厂 ECU 连接器映射到匹配的 rusEFI ECU 连接器。</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">草稿版本位于 https://ruse​​fi.com/docs/pinouts/Benelli_Walbro/</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">最近在 Benelli 论坛上提供了更多信息(请参阅 [url]https://www.benelliforum.com/threads/1130-tnt-ecu-walbro-on-testbench-pinout.33672/?post_id=273260#post-273260] ),但上述映射尚未更新。</font></font>
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">也许你想确认并完成这项工作?</font></font>
Yes, I really want to complete this operation so that Benelli can work in a closed-loop state. I will use R160 high angle camshaft for my 1130K. But it requires a lot of sensors to be added, which is really not a good idea, and my English is not very good, nor am I familiar with programming languages.
Posted: Sat Dec 21, 2024 11:20 am
by mi-hol
Could you please explain the reasoning for that?
From my understanding all required sensors are already present.
Posted: Sun Dec 22, 2024 1:01 pm
by MuShan
It lacks an intake pressure sensor, and its oxygen sensor is not very sensitive? I want its engine to work in a closed-loop state, which should make it more stable
Posted: Sun Dec 22, 2024 1:02 pm
by MuShan
And in China, the number of this car is very small, and the accessories are also very difficult to find. Fortunately, there are Benelli 752s, Benelli 1200GT, and TNT899 produced in China, which make it relatively easier to obtain some vulnerable parts
Posted: Sun Dec 22, 2024 2:59 pm
by mi-hol
right, the intake pressure sensor was inside the ECU. I intended to use TPS-based table fuel lookup with interpolation (Alpha-N).
Factory used oxygen sensor is a narrow-band version, I planned to replace it with a Bosch LSU4.9 wide-band version.
Lets see if closed-loop will actually work for a motorcycle with quickly changing load. With a constant load closed-loop would have benefits, but I don't drive my Benelli on a German Autobahn with constant load often.
Would it be possible to find out what exact sensor(s) are used by TNT899 produced in China for intake pressure and temperature?
Posted: Sun Dec 22, 2024 3:21 pm
by mi-hol
A note of caution regarding closed-loop.
At least the 900ccm Benelli engines in Tornado model with full paneling had cooling issues at low speeds and high external temperature requiring injection of additional fuel to cool pistons and avoid engine faults!
A few guys in Benelli forum retrofitted these engines with electrical water pump instead of mechanical water pump to improve cooling.
An aftermarket electrical water pump kit is available from a dealer in Germany
Posted: Mon Dec 23, 2024 7:29 am
by MuShan
The pressure sensor installed on the circuit board of its ECU is an atmospheric pressure sensor. I do not have a TNT899 vehicle produced in China, so I cannot know. I will ask friends who own this car about the oxygen sensor in their WeChat group chat. I do not believe that replacing it with the Bosch LSU4.9 you mentioned will have better improvements. And its intake temperature sensor at 1130K is not installed inside the intake air filter box at the front of the car. The overall quality of high-speed people in Germany will be better, which can make vehicles run faster. The maximum speed in China is limited to 120KM/H and motorcycles are required to drive on the far right side
Posted: Mon Dec 23, 2024 7:31 am
by MuShan
I replaced my 1130k with a Chinese made TNT899 throttle valve, but there is no position or sensor for the intake pressure sensor on it. I think the Chinese made TNT899 does not have this sensor installed
