Many years ago I had a not so bright orange vehicle with a Honda K engine. It has blown the head gasket for not good reason
So I've decided to purchase a bright orange vehicle, again with Honda K engine, this time GDI and turbo-charged! And Acura Care Extended Warranty
2021 Acura RDX
2021 Acura RDX
Re: 2021 Acura RDX
Hold on, does this vehicle have THREE separate CAN buses?!
https://github.com/rusefi/rusefi_documentation/blob/master/OEM-Docs/Honda/2021-Acura-RDX-data-lines.pdf
Power steering uses one bus but electronic gear shifter uses two? Two buses between ECU and ECU?
Re: 2021 Acura RDX
Active Dumper System, the less fancy one without stroke sensors like on Civic Type R.
Why do they run two dedicated wires to each strut solenoid? Why not shared high side?
