1991 Eagle Talon TSi AWD
Wonderingwobble
Github Username: Arthris
Slack: Arthris
Post by Wonderingwobble »
Thought I would start the build thread. As subject says its a 1991 Eagle Talon TSi AWD, Has a auto trans the W4A33. Motor is a Slowboy Racing ported head with stainless Valves, GSC S2 272 billet cams, AEM adjustable cam gears, 12 Tooth crank trigger, Weisco 9.0: Compression, Pauter X beam rods, Kiggly crank girdle. ERL Cast exhaust manifold, Holset HX40 with .82 Housing. Ill be posting pictures of everything and current progress. There is alot of Parts I have purchased and more to be. Car is being built with a Haltech Elite in mind but I purchased a MRE for testing. Id love to see what I can do for the price and maybe even help with some dev. The car is going to be a street/strip car. Should make around 600 AWHP on E85. and if im able to trim out some more fat should be a mid 9 second car.
Re: 1991 Eagle Talon TSi AWD
Exciting! Welcome :)
Wonderingwobble
Slack: Arthris
first Pic upload. More to follow
Wonderingwobble wrote:
Mon Jan 11, 2021 5:53 pm
rusEfi is going to be happier if you cut a tooth off that crank trigger wheel
Wonderingwobble
Slack: Arthris
Image dump. There's More to come
Wonderingwobble
Slack: Arthris
More Pics of Old car and new. Parts accumulation and what not.
Wonderingwobble
Slack: Arthris
Pics are so out of order. Next Image dump should be alot more current progress
Wonderingwobble
Slack: Arthris
Transmission assembly and install. The bolts im holding are Titanium. Gotta love Ebay. There pretty cheap as well.
Wonderingwobble
Slack: Arthris
Ti bolts are below. Thought they where in last batch. But I had to mod the front to properly mount the Sciroco radiator. Hopefully its large enough to keep this car cool if I decide to drive it on hotter days.
Wonderingwobble
Slack: Arthris
Garret IC core from ATPTurbo. Along with Cast ends tank's from them. 24x12x4.5 Core. Should be big enough
Wonderingwobble
Slack: Arthris
Hopefully i can make the Location of the EWP work here. Its a Pierburg off a BMW. Its a brushless pump. Ebay score for 50 bucks. I hope it works lol.
