Page 3 of 3
Re: 1993 Mazda Miata
Posted: Tue Nov 23, 2021 6:58 pm
by starsky
BeerMoneyMotorsports wrote: ↑Tue Nov 23, 2021 6:53 pm
Im not sure on your base map. You will see Fuel Pump under the Base Engine menu.
It looks like its disabled, which Pin and pin mode should I select?
- image.png (12.1 KiB) Viewed 8527 times
Posted: Wed Nov 24, 2021 2:27 am
by BeerMoneyMotorsports
Its mre pin 35 or GP1 i think. What do your options look like? I have played with mre48 in a bit.
Posted: Wed Nov 24, 2021 4:28 am
by starsky
BeerMoneyMotorsports wrote: ↑Wed Nov 24, 2021 2:27 am
Looks like pin 35 is GP1?
- image.png (3.09 KiB) Viewed 8505 times
Here is an example of my tune:
https://rusefi.com/online/view.php?msq=634
Posted: Thu Nov 25, 2021 5:03 am
That looks right. You should see a priming time reaction from the pump.
Posted: Tue Dec 07, 2021 5:53 pm
by starsky
Hi All,
Does this ECU have the capability of using an output for boost control?
Posted: Tue Dec 07, 2021 6:07 pm
https://rusefi.com/ main page has this table
- image.png (68.42 KiB) Viewed 8384 times
Boost Control is mentioned in the middle
Posted: Sun Feb 13, 2022 1:36 am
by starsky
Guys,
To use the Kia TPS, do I have to switch wires/pins around? I think I read that somewhere but for some reason I can't find the info.
Thanks
Posted: Sun Feb 13, 2022 10:27 am
by Simon@FutureProof
I believe yes. Kia tps has a different pinout and will damage things if not wired correctly.
Best to double check anything like this.
Posted: Sun Feb 13, 2022 2:53 pm
by starsky
So in this thread:
https://rusefi.com/forum/viewtopic.php?t=1908
It looks like I have to switch two pins around, and remove the R22 10k resistor?
If I just get the popular BMW TPS (used on speeduino and MS), will it work without having to do the above mods?
Thanks
Posted: Tue Feb 15, 2022 3:46 am
by stefanst
I *believe* the KIA and BMW TPS pinouts are identical. So either way you have to do the mod. Same for MS.
Posted: Tue Feb 15, 2022 2:24 pm
by dexter_lab
this is not a sorcery
analog TPS (throttle position sensors) are simple potentiometers. they have 3 ends let's label them 1,2,3. grab an om meter and measure resistances between legs and move the throttle, there should be one pair that is not changing resistance for example 1,2. one of them must be tide to GND other to 5V. the one remaining must be attached to TPS of the MRE....
Posted: Thu Feb 17, 2022 4:21 pm
if you plug the kia tps right in, you will find that the calibration values are backwards due to the switched wires but it works perfectly fine.
Posted: Mon Feb 21, 2022 1:59 am
by starsky
BeerMoneyMotorsports wrote: ↑Thu Feb 17, 2022 4:21 pm
Thanks, and I'll still have to remove the R22 resistor?
Posted: Sun Apr 17, 2022 4:14 pm
by fan
If you don't remove R22 the values will fluctuate because of unstable voltages, but it's perfectly usable
Also I did the pinout swap, but the values are still backwards
