Hello from Belgium - wondering if rusEFI could be used to run my engine
Posted: Tue Oct 27, 2020 9:39 am
Hi,
I have an old Toyota that at some point will get a new engine, but I want to learn some tuning & building by torturing the current one. Please correct me about any wrong assumptions, as this is all quite new to me.
My engine is a Toyota 3S-GE (gen 2). I want to add a supercharger to it (probably one from a Mercedes SLK).
This is a 10:1 compression 4-cylinder with an un-tunable ECU from 1990, and a distributor based ignition system.
As I understand it, since the ECU is not built to handle compression, I would need to adjust timing and increase fuel injection, which is easiest to achieve with a programmable ECU. I figure it would be best to switch to coil packs for better ignition tuning capabilities?
And probably replace/add some sensors for MAF/MAP/intake temperature and fuel pressure so the ECU can make decisions based on those.
All of this is happening on a budget - I'm not looking to spend more than maybe a 1000 euros on this engine, except for maybe parts that could be reused after an engine swap (fuel injectors, fuel pump, intercooler etc).
Any tips would be helpful! I'm an embedded software engineer by trade, so the electronics and software bit doesn't scare me that much, but I know almost nothing about cars. I'm not worried about ruining the engine, but it would be a shame if I ruined it without learning anything!
