vias on frankenso board 0.4
Posted: Mon Oct 29, 2018 9:04 pm
by alexander-n8hgeg5e
Hello, is it possible that the vias are somehow not working?
I messure 5v between pad1 r404 (GND) and P5 (GND).
They should be connected via the gnd plane, is this right?
Re: vias on frankenso board 0.4
Posted: Tue Oct 30, 2018 12:09 am
Well, everything is possible but something is not probable.
Did you get the board from me or somewhere else? Between the boards I've touched I've seen one or two defects, that's below 1%.
Posted: Tue Oct 30, 2018 2:37 am
sorry... problem solved. it were the crapy solder connections under all 3 gnd pins... of the chip and under the resistor were no connection...
I were suspicious about that because i had to flow solder into one of the via to get one of the power mosfets to go.
Thanks for the quick answer.
Posted: Tue Oct 30, 2018 7:42 am
Solder joints on the GND plane with small soldering irons can be that way, as the GND plane sucks up the heat. I put in thermal breaks on the via's to help minimize that, but with small iron's it can still be a bugger. Glad to hear you figured it out.
Posted: Tue Oct 30, 2018 5:43 pm
Yes, the large copper ground plane, didn't thought about that. Additionaly i used a dull tip, and a somewhat more attention demanding flux. My Soldering Station is cheapish but works good. As I resoldered, I used a self made tip that is good to peek down onto the plane close beside the part.
