1995 Ford E-150
Re: 1995 Ford E-150
Primitovo, Zinfandel! I used to make a lot of that stuff from scratch, crusher, press, demijohns, the whole deal. Had too many unexplained failures so I gave up and just make wine at the local U-Brew. Still relatively cheap and no failures.
Back to business.
I assembled a new circuit to simulate PIP with maximum of 5 volts. Nice square wave, frequency only varies ~0.05 hz when set.I fed it through input 11, out 11 jumpered to PA5. No joy. So I connected directly to PA5 and got results, but very jumpy on all gauges. During the course of trying to figure out why I disconnected the jumper from PIP supply and still had jumpy read outs. Disconnect jumper, no RPM, others pulse at 1 hz. Connect jumper wire to PA5 only and RPM shows up jumping all over , other gauges as well.
Looks like Discovery is very fussy about noise, wherever it's coming from.
Back to business.
Robert
Re: 1995 Ford E-150
just pip simulator and that's all?? no spark plugs, no high voltages? what could be the source of that noise? any ideas?
Re: 1995 Ford E-150
If you have a wire which is connected just to the discovery pin, and the other end is not connected - that's an antenna and it's receiving whatever is in the air. I get absolutely the same behavior, that expected behavior.
Now, let's try "self-stimulation" again. (I know it sounds funny
) - please connect PD1 to your input pin. Then, use rpm 500, rpm 2500, rpm 5000 commands. That gives a pretty accurate & stable RPM value on my bench. For instance, for rpm 5000 the value is jumping from 4997 to 5005 which is less then 1% looks good enough.
Now, let's replace self-stimulation with direct pin stimulation using your stimulator. I would expect the same level of precision, right? Is it the case?
Re: 1995 Ford E-150
In self stim all is good. If I set RPM to 1000 I read ~43hz. Display is steady +_~1RPM. If I try direct connection to my stim @~43 hz the display jumps around between ~2000 and 3000 RPM. Discovery is not plugged into the analog board and I have a ground jumper between my stim ground and Discovery ground.
One other odd thing is if I'm asking for 1000 RPM on internal stim, why is the frequency ~43hz? At 3 rising edges on the input per revolution shouldn't the frequency be 1000RPM / 60 = 16.66hz x 3 = 50 hz?
Robert
Re: 1995 Ford E-150
I know your scope is questionable or something like that, but it would probably really help right now. I suspect you are getting some ringing. Can you post a picture of the setup? Hopefully something that shows the wires. Also what is generating the signals? I know some schematics have been noted, but what's actually connected and such. I'm not seeing the hip bone to leg bone kind of connections, so it's hard for me to comment very well.
Re: 1995 Ford E-150
The scope is not in question, or at least I don't think so. It is the operator of the scope that is in question.
It will take me a day or so to simplify the set up, take the photos, document the set up to the photos and post it for you, but I will do that ASAP.
Robert
Re: 1995 Ford E-150
so, are there live sparkplugs connected to the system?
russian, I believe the difference of your running engine from these two cases is that you had ecu inside the car, away from the engine. unfortunately, the other guy didn't shoot the video of his devconsole while cranking.
i've just placed an order for a foiled cardbox for the discovery board - for my kid's handycrafts lessons
and i'm looking for small steel buckets to place the sparkplugs there...
Re: 1995 Ford E-150
Here's the setup and schematics.
Robert
Re: 1995 Ford E-150
Some scope shots.
My Fluke 87 read output from the signal generator at 6.11v, 50hz, 50.7% duty cycle. Output from the 5v conditioner read 2.49v, 50hz, 50.7% duty cycle. 50hz for a 6 cyl 4 stroke is 1000 RPM.
Robert
Re: 1995 Ford E-150
Here's the setup for testing the PIP signal only and what the Dev Consol reports. As you can see, no spark plugs, injectors or any other thing that should make noise. Interesting!
Robert
Re: 1995 Ford E-150
dates on the devconsole window bar are a bit weird.
i'd remove everything from discovery but for pip simulator and check the readings.
then I'd probably submerge into the source code for that ford inline v6… those 0ms sparks seem (every odd event) look pretty strange, as if something is left in the source code (as far as I got russian has remapped certain pins - he could have forgotten to comment out some unnecessary function?)
Re: 1995 Ford E-150
russian, are we talking about this one?
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/config/engines/ford_1995_inline_6.c
or a different (customized) file?
Re: 1995 Ford E-150
Yes, it's this file. At this point we are not concerned with the spark - at this point the question is that trigger signal is not processed properly (it should look like a 50% wave but it looks as 99.999% wave right now - the upper row)
Re: 1995 Ford E-150
argh. i see. you believe it's caused by electromagnetic interference? or it's a software bug?
Re: 1995 Ford E-150
Since self-stimulation works, I am pretty sure that the issue with trigger decoding / rpm measurement is electrical.
Re: 1995 Ford E-150
hm. is the scope on the last picture connected to the discovery AND stimulator, or just to stimulator?
Re: 1995 Ford E-150
The photo showing Discovery with the scope in the background shows the scope connections to ground and Discovery PA5.
Robert
Re: 1995 Ford E-150
pa5 is your trigger input? what's the purpose of c8 r11 on the level shifter? could it be so that with internal resistor they form somewhat an rc generator?
jared?
jared?
Re: 1995 Ford E-150
R11 is not needed when connected to MS because the 908 CPU has internal pull-ups for input pins. I am using it in this case to get a 5 volt referenced signal for the analog board or Discovery. I have no idea what C8 does, I just copied a circuit that worked.
Robert
Re: 1995 Ford E-150
E4ODnut, could you try connecting a scope to the internal self-simulation pin (russian - was it pd1 or pd2 or anything else? there looks to be no electrical components to ruin anything…)
the other thing is I can't see where is 'div' on this walleman device. where's zero V, where is 2V? could it be the lack of voltage difference? but in that case there shouldn't be any pulses at all...
Re: 1995 Ford E-150
When I connect to PD1, the internal pulse generator I get a crisp square wave at 1.413 volts according to the scope. The wave form is no different than the form my stimulator generates.
As far as the ms/div and v/div display goes, that's the difficulty with operator part. I haven't figured out how to display that yet, but I'll try.
Robert
Re: 1995 Ford E-150
it might be you missed (or lost) just a sticker on the bezel?
Re: 1995 Ford E-150
nope
Robert
Re: 1995 Ford E-150
have you tried feeding pd1 to pa5 without turning off the stimulator (just to check for possible EMI?)
Re: 1995 Ford E-150
I hope to reply tonight, if I forget, please ping me. Also might be worth while to read about "tank circuits" I think that is what was referenced by the RC generator comment. I have to look at it closer to really make a comment.
Re: 1995 Ford E-150
OK. I finally figured out how to bring up the reference lines or grid on the scope. Using the markers the resolution is a bit coarse but it corresponds pretty close to the scope meter read outs. In the photos of the wave forms ground reference is the bottom of the waves.
My new found knowledge, which will probably be deleted from my brain in about 15 minutes, has pointed me to a possible explanation on what took out PC6. My Fluke VOM reads average DC voltage. It does have a Min/Max function but the sampling period is quite long. When I set my power supply so I was reading ~4.5v PIP input to PC6, the peak voltage would have been about 9 volts. I re-created the conditions as close as I could and with no connection to Discovery confirmed the peak voltage with the scope. It looks like I am guilty of man slaughter, or pin slaughter, or whatever.
Puff,
I tried your suggestion about possible EMI from the stim. Makes no difference, stim off or on. Lovely square wave signal to Discovery, garbage on the Consol.
Puff,
Robert
Re: 1995 Ford E-150
E4ODnut, at least you've learned how to kill a pin
russian, is there a chance that console (or console-related code in the firmware) is somehow misbehaving? (z.b. expecting/reading signal from the wrong pin?) is there a way to output that trigger signal (the internal one, after the decoding logic) to another pin?
Re: 1995 Ford E-150
I tried another thing.
I have Discovery plugged into the boards, but I'm getting the PIP signal from PD1. RPM is nice and steady at 1200+_2, but TPS, IAT, CLT and AFR are jumping all over the place. Input signals to them is nice and steady.
It's a long shot, but could it have something to do with the fact that we are powering Discovery through the USB cable and not the same power supply as the Stim and analog board?
Robert
Re: 1995 Ford E-150
AFAIK the only required thing is common ground. Is there a common ground?
Re: 1995 Ford E-150
Yes. My 5 volt power supply is connected to 5v and ground inputs on the analog board and Discovery plugs into the analog board. I have continuity between Discovery ground pins and the ground terminals on the analog board.
Robert
