VOLVO B20
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
When i reset the board after firmware update.
I get a all four led blink then the blue and red flashes and the green is lit all the time.
I havea little red led by the micro usb thats lit.
The big red led by the mini usb is also lit.
PD1-PC6 is my connection , will try without.
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
Now only the blue of the four is blinking.
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
Still nothing in Putty , i´ve switched tx and rx too. :(
Re: VOLVO B20
Please take a picture with the USB TTL device and without the simulation wire, maybe this would do the trick.
I am out of ideas for now, I will go fix the bug and update you once I've done that.
Re: VOLVO B20
Post by puff »
i guess you're having issues with your usb-to-serial converter - probably lack of drivers?
the easiest way to check if it works is connecting its Tx pin to its Rx pin (without any other boards) and typing stuff in your hyper terminal.
here's what I've found for XP:
http://www.compsys1.com/support/docs/usb_rs232_test.pdf
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
Thats what i think to.
But i have this:
Re: VOLVO B20
Post by puff »
so probably you should be able to connect to com15 with you hyper terminal, and, provided that everything works fine and you have connected your tx pin to your rx pin on the usb-to-serial converter, you should see what you type in your terminal. when you disconnect these two pins from each other, you shouldn't see anything on the screen when you type.
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
Aha , thank you Puff!
Now i have the right settings in my usb-ttl device.
My mistake its working.
When i type with rx and tx together i get what i write in PUTTy.
If i disconnect rx and tx nothing appears in PUTTy.
Re: VOLVO B20
Post by puff »
imho without having echo (with RX and TX pins connected to each other) there's no sense to continue with discovery :?
do you have the prolific driver installed? (http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41)
what's the OS you are using? XP? 7?
could it be that your converter is broken?
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
Sorry see my edited reply
Re: VOLVO B20
Post by puff »
nice!
well, next, when you right-click that com15 thing, you'd probably see the window where you can change the baud rate. change it to 115200. try connecting all four wires to the discovery board (not sure if the red one should go to 5V or to 3.3V). open the same hyper term, com15, and hit 't' in the english layout.
hope this works…
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
This is the last for today.
This is with micro USB and USB-TTL connected all wires TX , RX , 5V and GND.
No mini USB connected.
Re: VOLVO B20
Here you have connected TS to the wrong COM port - it does not like the microUSB feed, it wants the TTL feed.
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
This is what i get when trying to connect.
Re: VOLVO B20
russian, what version of TS are known to work? I've seen TS make updates that break older versions. Can you verify he's using a compatible version of TS.
Re: VOLVO B20
That's a compatible version and the issue is before TS for sure, we have not confirmed connectivity yet and there is a real chance there is a bug in rusEfi. Tomorrow it be better :)
hasse.69
donator
donator
Re: VOLVO B20
Post by hasse.69 »
So close. :lol:
