Lycoming 0-360 engine
ian-w
Post by ian-w »
Hi All,
I have a Lycoming 0-360 180 HP NA engine which I'd like to convert to electronic ignition and fuel injection with rusefi. It's a long term thing with zero work done at the moment. Firstly I'd just like to understand the feasibility and the merits of going down this path
The reason for going down the path are better fuelling and the possibility of one day using water injection to allow the use of higher compression or turbo-changing on a air boat. The current carb and manifold doesn't deliver fuel evenly to the cylinders which leads to heating
At this point I still have a lot of questions such as understanding what rusefi hardware would be the most suitable, is sequential injection worth chasing the necessary cam signal or could this be pulled from the tacho output or even which injectors are best supported.
Some of the complications with the engine are
Twin spark plugs per cylinder. (Would one ECU for each set of 4 plugs be feasible/sensible?)
Zero crank or cam sensors at the moment,
I'm not sure if a cam sensor is possible.
No knock sensors, not sure how this could be done.
It currently has two magneto's and associated drives
On the bright side
There are fuel injector inlets with a 3/8 thread in the cylinder heads
There's a starter motor gear attached directly to the crank to which a reluctor ring could be attached
I think that the tacho drive output is geared at 2:1, which might provide the necessary cycle information.
Any thoughts or comments are welcome. Including the "you're an idiot"
thx Ian
Re: Lycoming 0-360 engine
sequential injection in not worth chasing.
you would definitely need some crank sensor and a trigger wheel with a dozen of tooth or more.
fuel regulator so that your fuel pressure is not random.
ian-w
Post by ian-w »
Is there anything on returnless fuel lines?
If so does anyone have a sensor pump combination which works?
ian-w
Post by ian-w »
OK, it might help if I asked one question at a time.
The O360 enging has 4 cylinders and 8 sparkplugs, two per cylinder.
Could a single board such as the uaEFI or microrusefi drive 8 Coil on plug assemblies in pairs?
Probably yes
uaEFI double-coil might be increasing the risk of hitting some limit around https://github.com/andreika-git/hellen-one/issues/378
ian-w
Post by ian-w »
So would it make more sense to run two microrusefis or similar in parallel using the same sensors, each driving one of twin plugs of each cylinder.
This would be similar to the current setup where twin magnetos each drive one plug of the four cylinders.
However it might make doing the fuel injection a bit more complex.
Would it be possible to toggle between the units to make one of them active for fuel injection?
mpgmike
Post by mpgmike »
If you look at the Dodge Hemi engines, they have 2 plugs per cylinder. The coils are effectively waste spark. Each coil is connected to 2 different cylinders; one which will be near TDC getting ready for the power stroke, the other near TDC getting ready for the intake stroke. With the 4 cylinder your firing order is most likely 1 - 3 - 4 - 2. Pair 1 & 4 together and 2 & 3 together. Use 4 DIS waste spark coils.
