[Success Story] Subaru SVX with custom RusEFI
MHTSOS
Github Username: MHTSOSVOODOO
Slack: Dimitri C
Re: Subaru SVX with custom RusEFI
Post by MHTSOS »
8.4/1 compression ratio calls for big boost. Even 8.8/1 can do 250kpa on a stroker EJ20.
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
MHTSOS wrote:
Wed Feb 23, 2022 3:23 pm
Suba maniacs say 1bar is safe for pistons and rods used in this motor.
Any suggestions on turbo?
MHTSOS
Slack: Dimitri C
Post by MHTSOS »
I guess the pistons are from a EJ22 NA since only 22B had a turbo version of this engine. I don't know much about these particular engines since they were never sold around here. Generally EJ16 and EJ20 NA pistons don't tolerate much boost. People usually use 0.7 bar max but at much higher compression ratio than your engine. With 8.4 CR you'll be fairly safe from detonation but you'll have lag at low rpm. Having 3.3 liters will help a lot but before full boost the car will feel slower than before. The rods I guess are the same as the EJ20 NA and they are good up to 6500 rpm. They can tolerate a good amount of boost but no high rpm.
As for the turbo I have 0 experience with 6 cylinder Subarus. What's your empty space in the engine bay like? Do you plan to mount it in the same position as EJs or are you going for something extreme? What about exhaust manifold?
Dron_Gus
Post by Dron_Gus »
Yes. Pistons from EJ22NA. Seems EJ22 has another combustion chamber shape. Thats why its pistons has bigger pool.
Rods are the same as on EJ20G, EJ20K and so on. AFAIR Subaru were using same rods for NA and turbo engines until late 1990x.
No space at engine bay at all.
There is almost no space between firewall and engine. So stock subaru's turbo place is not a solution.
Move battery to trunk? Narrow front-mount intercooler? Or some water intercooler?
Each head had has it's own iron cast 3 to 1 manifold. Then two pipes merged behind gearbox.
So this manifolds can be rotated 180 and routed to front mount turbo. But this will eat clearance.
MHTSOS
Slack: Dimitri C
Post by MHTSOS »
Yep, that's tight in space. If you place it where the battery is now how are you going to route the downpipe and the rest of the exhaust? Unless you go full mad max and just put a straight pipe through a hole in the fender. In that case you can also mount it low on either side of the radiator and use a scavenger pump for the oil return. This also makes it very easy for the intercooler piping. Image
Στάλθηκε από το CLT-L09 μου χρησιμοποιώντας Tapatalk
Dron_Gus
Post by Dron_Gus »
MHTSOS wrote:
Sat Feb 26, 2022 7:26 am
Definitely no screamer pipes.
A bit of googling shows that these is possibility to mount turbo at stock subaru's place. But uppipe will have to much 90 rotations. And loooong pipes to front mount intercooler.
Going to pick up car from machine shop next week. This issue costs me $2K total. So no turbo in near future. Budget is over.
Dron_Gus
Post by Dron_Gus »
Engine was rebuild.
Then I had a problem with PCV, that costs me engine out and in again and set of gaskets.
Yesterday I done my first ride on RE this year.
Today it is +30C in Saint-Petersburg and I need to figure out why AC is not operational with RE.
Compressor clutch is not get activated.
Wiring is quite simple and straightforward. But I'm stuck.
+12 to AC clutch relay coil comes from IGN switch through "LowHi pressure switch". I assume I should be closed. At least AC works with stock ECU.
Ground to AC clutch relay comes from ECU pin b8.
I use "General Purpose PWM 2" to drive this pin. I see low level on this pin during tests on table.
Input from "Intermediate switch" is currently ignored.
There are also two signals between ECU and AC unit: "A/C switch" and "Auxiliary air control valve". From documentation it is not clear if ECU is sourcing these signals or receiving.
Tracing stock PCB shows that "A/C switch" signals goes to some unknown soic IC through 0.5W 2.7K resistor. Looks like ECU outputs this signal?
"Auxiliary air control valve" I was not able to trace.
Does anyone has experience with old Japanese cars AC systems? What is purpose of these signals? Who is source of these signals?
Dron_Gus
Post by Dron_Gus »
Ok. AC problem is HW problem (leaking system).
Now I have crank-run-die problem...
Tune https://rusefi.com/online/view.php?msq=1172
Log https://rusefi.com/online/view.php?log=987
Should I try latest greatest SW? Or this one look like HW issue?
There is a chance of trigger sync loss. I am confused why do we not see latest gap ratios in your log?
Dron_Gus
Post by Dron_Gus »
Ok, I was able to start engine, helping with foot. Then I slowly released gas pedal - engine idles at 1200. And then I start closing IAC valve and now engine works fine on 670 RPM. I see no gaps in Engine phase graph.
Log https://rusefi.com/online/view.php?log=988
Dron_Gus
Post by Dron_Gus »
New exhaust.
Ready for RusEFI AFR vs reference testing
Dron_Gus
Post by Dron_Gus »
Ok.
I'm still getting trigger errors due to unreliable CAM sensor. Same issue on stock ECU.
So lets try to use CAM sensor only for initial sync. This is possible?
Crank has 12 tooth. Should I set 12 to "Total tooth counter (number)" or 24?
"Skipped wheel location" is it option to set where "custom toothed wheel" is located? Skipped = Custom?
How can I set CAM shape? It has single tooth.
Dron_Gus
Post by Dron_Gus »
Trigger wheels once again.
Dron_Gus
Post by Dron_Gus »
Original composite SVX trigger/reference good signal.
coils times are almost the same. ignition time also very close.
Dron_Gus
Post by Dron_Gus »
Switching to "12 tooth crank" on crank and "single tooth second half" for cam:
Dron_Gus
Post by Dron_Gus »
Results:
Dron_Gus
Post by Dron_Gus »
Adjusting trigger offset in console does not actually moves green line.
Ignition time are quite different per cylinder...
What am I doing wrong?
Is your crank Hall or VR?
Not sure if that's 1% or 90% of your issue.
Dron_Gus
Post by Dron_Gus »
Wed Oct 19, 2022 1:27 pm
Good question. It is VR.
Now it looks 50% better. But enjine is still unstable and I hear cylinder firing skips.
Dron_Gus
Post by Dron_Gus »
CAM use also only Rising edges.
Dron_Gus
Post by Dron_Gus »
Tune with composite original SVX trigger:
https://rusefi.com/online/view.php?msq=1270
Log of idling and reving.
https://rusefi.com/online/view.php?log=1082
Dron_Gus
Post by Dron_Gus »
Wed Oct 19, 2022 2:44 pm
Absolutely agree. This is going to be fixed.
As we decided on phone call I did logging with "tune that is known to work"...
Dron_Gus
Post by Dron_Gus »
One issue with Subaru documentation is that they don't care about actual VR+ and VR-. This is another area where issue can exist.
Dron_Gus
Post by Dron_Gus »
Problem is that crank wheel has no skipped tooth. :) while correct crank polarity is the question.
Seems I need to attach oscilloscope.
