[help needed] 2006 VW SANTANA B2 1.8
				1065598263
- Github Username: Loft-xiaolen
Hello, I'm from China. I'm currently a college student. My major is automotive engineering.
I'm lucky to be able to see the project of rusefi (I'd like to thank hotcat for letting me know here)
I want to take this open source project as the title of my graduation thesis. In 2019, I bought a Volkswagen Santana B2 produced in October 2006, which is actually Passat B2. Shanghai Volkswagen has improved Santana to meet stricter environmental standards. The following are the improvements.
1. Upgrade the mechanical throttle to electronic throttle.
2. The distributor driven by the intermediate shaft is canceled, the camshaft position sensor and crankshaft position sensor are added, and the twin cylinder ignition coil controlled by Bosch me7.5.10ecu is configured.
3. Gave up the carburetor (this has happened since 1999)
4. A knock sensor is added between cylinders 2 and 3.
5. Two oxygen sensors are respectively arranged in front of and behind the three-way catalyst.
I can't remember anything else for the moment. I'll add it later
These upgrades can save me a lot of transformation work, so I only need to make an ECU. Shanghai Volkswagen's upgrade of Santana is not very successful, and there are still design defects. For example, after turning on the AC switch, there will be obvious power attenuation, and the acceleration response is very slow... There are many, many more.
I have downloaded the code on GitHub, and I have also checked the tutorials on GitHub. Please forgive me for my poor English level. I can't understand some places. I also use translation software for this passage.
I can't buy stm32f407igt6, I only buy stm2f407zgt6, which means I can only design PCB by myself, but this is also a good thing, which can improve my technical level.
I am currently learning stm32f4. Do I need to be very familiar with c/c++?
Finally, thank you for reading my article.
Re: 2006 VW SANTANA B2 1.8
With a LQFP144 MCU you can solder https://github.com/rusefi/alphax-4chan/ but manual assembly of any modern rusEFI unit would be a huuuuuge pain, pick and place machines do the assembly much better.
				1065598263
Wow, it looks really complicated. Let me see the price of SMT, but if it's too expensive, I'd better weld it manually. In addition, alphax-4chan also has four versions of ABCD. What is the difference between them? Some folders of this project are empty. Is it in the development stage?It is difficult to access GitHub in China. The speed of downloading files is only 20Kb/s, and many web pages can only be displayed after loading for half a day.
You know you can buy a pre-built one, right? It may be worth it to avoid the hassle of assembling and debugging a board yourself.
				1065598263
Why do I open the PCB drawings in the root directory, and some places are empty? Is this an unfinished project? Does it have anything to do with this prompt that "no drawing found" is displayed when opening? Or is it that the file data I downloaded has lost, not all?
You have not fully cloned the repository - I guess you did not clone the submodules.
As for the holes see https://rusefi.com/forum/viewtopic.php?f=4&t=1913
				1065598263
The closest one here is only 81 pins, but I have counted only 80 pins of my ECU, and I am very sure. Are they universal? My version is Bosch me7.5.10, which has fallen behind.
Can you try getting in touch with the https://rusefi.com/forum/viewtopic.php?p=45863#p45863 guy he has his custom design in China
				1065598263
Wow, thank you very much. He is in the city next to me.
				1065598263
I found the 80pin PCB in the hardware folder. I still don't know how to clone the repository and sub modules. My translation software may be inaccurate, and the translated language may make me unable to understand the meaning.So, please give me more instructions.AndreyB wrote: ↑Sat Jul 30, 2022 8:03 pmCan you try getting in touch with the https://rusefi.com/forum/viewtopic.php?p=45863#p45863 guy he has his custom design in China
				1065598263
				1065598263
New progress! I can't find the firmware of alphax-4chan. Is it common with https://github.com/rusefi/rusefi?
it's in the https://github.com/rusefi/rusefi/tree/master/firmware/config/boards/hellen subfolder of https://github.com/rusefi/rusefi/tree/master/firmware/config/boards
				1065598263
New progress! I'm looking at alpha_ 4ch. kicad_ In the sch file, the corresponding MCU pin is not explained, otherwise I don't know which pin of the corresponding MCU, and where should I check it? thank you!
https://github.com/rusefi/alphax-4chan/tree/main/boards/alphax_4ch-e/board
https://github.com/rusefi/alphax-4chan/blob/main/boards/alphax_4ch-e/board/alphax_4ch-e-schematic.pdf
				1065598263
I understand the definition of the ECU pin of Santana. It is not consistent with most 80 pin EA113 engines, because Santana is an older EA113 engine. Although Shanghai Volkswagen modified it to meet higher emission standards, it is actually a very old carburetor EA113 engine. This is very unusual! Where should I upload pin definitions? This may be helpful to others.
				1065598263
The result of my translation software is wrong! The incorrect translation of gerber into "footprint" and the translation of modules into "grid" is a thing of the past. Now I understand the correct meaning, that is, module design! About the 144 SCM module, I only use this path: github\rusefi\master\  hardware\brain_ boar\brain_ board_ STM32F407.kicad_ Pcb, find this file, but this is not the 144 single-chip submodule I want. Where is it? Because I can't fully understand the meaning of the circuit diagram just by looking at it.thank you!
2022-9-23 21:04:29 Supplement:
The translation function provided by Microsoft Edge is terrible!
				1065598263
I found relevant files in github\hellen-one-master\modules\mcu144\0.6, but I don't know how to import submodules?
Google "git download submodules"
git submodule update --init
Also google "clone repository locally"
				1065598263
Thank you very much. I have collected all the required hardware files (maybe) and am preparing to make a new PCB based on the original PCB size to replace the original PCB. Because I made it according to the circuit diagram of alphax-4chan, I hope it can be compatible with the firmware of alphax-4chan. Some models of parts are not easy to order, such as stm32f407igt6, which has almost no supply in China, so it has to be replaced by other models.
				1065598263
I found something missing:
In alpha_4ch-e-schematic.pdf .The resistance value of R103 of SPI1 MOSI of MCU pin 135 in the file is 10K, which is in Code R103 is not found in the file alpha_4ch-e-BOM.csv
Similarly, pin 133 SPI1_SCK The resistance with the code R105 and the resistance value of 10K cannot be searched
Please paste exact URL of the file you are looking at.
Please mention exact component reference number or a small snippet of the schematics as an image.
				1065598263
I apologize,My network is not very good. I have tried to upload pictures many times and failed.
When I checked the Produce_DanZhi.SMT_Snapshot.Top.2582135A_Y268.SMT0220905955381.png file, I found that it does not exist, but the information on the alphax_4ch-e-schematic.pdf file points to here. Are they unnecessary?
				1065598263
Santana B2 uses 1-4 and 2-3 ignition coils at the same time. The plug of the ignition coil has only four pins. One pin is 1-4 ignition, two pins+12V, three pins are 2-3 ignition, and four pins are grounded. Can I forcibly connect 1-4,2-3 signal wires together? Just like the picture.I'm worried that this will damage the transceiver chip or work abnormally.Do you need to add a diode before they are connected to prevent current from flowing back?In the following circuit diagram, N152 is the ignition coil, J220 is the harness connecting the engine, P is the spark plug plug, and Q is the spark plug. You can see that there are only two ignition signal wires at most.Because of its long history and the manufacturer's technical blockade, this is the only data that can be found.
				1065598263
The original Santana b2 communication protocol is K-line, and ABS also relies on this protocol to communicate with ECU. If ECU does not support this protocol, ABS system will not be able to exchange data with ECU. It is worth mentioning that this situation lasted until 2012, because Santana B2 stopped production in October 2012.
				1065598263
Correct my own mistakes! The engine of Santana B2 is not EA113, but belongs to EA827. EA113 is improved on the basis of EA827. It is easy to mistake it for EA113, but in fact, many of their parts are universal.1065598263 wrote: ↑Thu Sep 22, 2022 11:17 amI understand the definition of the ECU pin of Santana. It is not consistent with most 80 pin EA113 engines, because Santana is an older EA113 engine. Although Shanghai Volkswagen modified it to meet higher emission standards, it is actually a very old carburetor EA113 engine. This is very unusual! Where should I upload pin definitions? This may be helpful to others.
				1065598263
A new small question. In https://github.com/rusefi/hellen-one/blob/master/modules/power12/0.2/power12-schematic.pdf, what does the "VIGN" of V3 pin mean? What word is it abbreviated? I tried to use translation software, but I didn't get the results I wanted.
