CurrentTune.msq
Rotary engine Rx8 in Florida
STURX8
Re: Rotary engine Rx8
STURX8
STURX8
Just need someone now to reset the RPM count I guess it's showing double that's one problem so far
https://rusefi.com/online/view.php?msq=571&dialog=triggerConfiguration looks like I would expect it to look
Is the RPM still wrong? I can see how the RPMs are doubled or quadrupled, i.e. multiplied or divided.
Can you please paste a screen shot of engine sniffer like https://rusefi.com/forum/download/file.php?id=5246 for example? that's from rusEFI console not TunerStudio.
STURX8
"Is the RPM still wrong? I can see how the RPMs are doubled or quadrupled, i.e. multiplied or divided"
We need to divide it
At the moment my focus is still on validating where exactly is the issue if it's in the software.
STURX8
AndreyB wrote: ↑Tue Jun 29, 2021 1:57 pmhttps://rusefi.com/online/view.php?msq=571&dialog=triggerConfiguration looks like I would expect it to look
Unfortunately I would not be able to contribute here. I am failing to effectively extract actionable signal from the hints you are posting here.
I have no idea what this screen shot means. I have no idea how you got to that screen shot, I have no idea how to reproduce the issue or what it is about.
Wonderingwobble
- Github Username: Arthris
- Slack: Arthris
Think he is confused on the RusEFI console. This should help https://github.com/rusefi/rusefi/wiki/Console
STURX8
It won't connect to that console thing properly
please try www.getsharex.com or else to record screen video
STURX8
That screenshot was from basically when you connect to the ECU ... it keep asking for the correct ECU definition... was wondering if you have the updated definition for the ECU... I don't know it's a incorrect ECU definition will cause that are r.p.m. to show excessively higher than usual
No, this would not affect the RPM.
When you connect your microRusEFI to PC does it give you a driver with rusefi.ini.zip? that's the file to uncompress to create matching project.
If you do not get that drive please update firmware using https://rusefi.com/s/microrusefi release link - same software bundle contains both fresh binary and project .ini file
Our instructions suck
Zach are you saying you know OEM connector part number? Is that something we can document at https://github.com/rusefi/rusefi/wiki/OEM-connectors?
ZHoob2004
Haven't physically verified but I'm pretty confident that this is the factory connectorAndreyB wrote: ↑Wed Jun 30, 2021 1:55 amZach are you saying you know OEM connector part number? Is that something we can document at https://github.com/rusefi/rusefi/wiki/OEM-connectors?
https://www.te.com/usa-en/product-8-5353015-1.html
Edited wiki https://github.com/rusefi/rusefi/wiki/OEM-connectors#122
Funny thing I have https://www.ebay.com/itm/334058887716 for sale
STURX8
Also it doesn't transmit back to the dash also ... on the RX8 setting (CAN) that would be great if I could wake up the electric steering also
STURX8
Still trying to figure out could get the console working it's connecting and reconnecting every 2 seconds don't know what's going on or maybe I don't know what the hell I'm doing hahaha but still trying to get you that screenshotAndreyB wrote: ↑Wed Jun 30, 2021 2:28 amEdited wiki https://github.com/rusefi/rusefi/wiki/OEM-connectors#122
All I know is that I am trying to help but on average you seem not interested (edit: not interested to leverage my experience of how we can make this dialog more productive). I am trying to point you at the tools to make this more efficient but your call which route to take.
Until we see what you click and how software responds we are relying on telepathy. Relying on telepathy does not seem to work for us so far.AndreyB wrote: ↑Tue Jun 29, 2021 11:10 pmplease try www.getsharex.com or else to record screen video
blundar
- Github Username: blundar
- Slack: Dave B.
- Contact:
Translating from Andreyish (which is an unusual blend of jumble, english and russian):
-You have been told to do certain specific things (use a certain bundle, use the ini retrieved from the rusefi controller to configure TunerStudio, take a screen capture showing sequence of events leading up to problem, ...)
-You do not seem to be providing responses and replies that make it clear EXACTLY what you are doing, whether you have already followed existing instructions and which particular step of the process is causing issues.
If I were you, I'd follow the steps you've been advised to do EXACTLY. If you run into trouble, use ALL OF YOUR WORDS to describe what you were attempting. You have a great community of very smart and helpful people here that get very frustrated when they can't follow along with what you are doing well enough to help you effectively.
STURX8
I wasn't told to use a certain bundle... so if you could send me that specific file that would be great because everything on your software page doesn't seem to work properly
AndreyB wrote: ↑Tue Jun 29, 2021 11:23 pmIf you do not get that drive please update firmware using https://rusefi.com/s/microrusefi release link - same software bundle contains both fresh binary and project .ini file
Our instructions suck![]()
What does "software page" mean? did you have a chance to click https://rusefi.com/s/microrusefi? What link did you click on https://rusefi.com/s/microrusefi to get release software?
What does "doesn't seem to work properly" mean?
How do you understand the phrase "take a screen capture showing sequence of events leading up to problem"?
STURX8
Okay I fix the ECU definition problem... ini files...
I am still working on the screenshot with the rusefi console
STURX8
I am sending you the RX-8 trigger wheel firing pattern this might give you a heads up of how it works
STURX8
Also if you have any ideas how to have the trailing coils work that would be fantastic so I could get that going I have a race coming up in 8 more days I am trying to make it
Matt is making progress https://github.com/rusefi/rusefi/pull/2932
For a prototype we will probably have fixed angle offset between primary and trailing coil. What kind of control strategy are you looking for trailing coil? Fixed angle? Curve? 4x4 table? Else?
Probably needs a little table. 4x4 or 6x6 is likely more than plenty. Doesn't need much precision either.AndreyB wrote: ↑Fri Jul 09, 2021 1:53 amMatt is making progress https://github.com/rusefi/rusefi/pull/2932
duhafnusa4
- Github Username: duhafnusa4
- Slack: Jimmy *un*el
