[rusEfi] red 2003 VVT test mule Miata NB2 #27
Re: red 2003 VVT test mule Miata NB2 #27
Screenshot of a log running Hellen72c on the Jimstim with "instandrpm" enabled. SD card logging did not work, so the logging speed is a bit slow, but instantrpm shows nice and steady rpms. Not ziggy-zaggy as one would expect when the teeth of the crank sensor are not where they are expected to be by the FW.
I should have my JimStim 1.5 MegaSquirt Stimulator with Wheel Simulator - Assembled on Wednesday
instantRpm was showing nice but value way 10% off! to be honest that's not how i was guessing it would show but at least it was wrong in this regard
nb2 decoder fixed by moving two points by 10 degrees
attached jimstim setup for nb2
on the header image yellow and red-ish on the left are +12v
black and loose grey are GND
green and yellow are cam and crank
Where is the video of it running on Hellen72?
thats better! soon it will be driving around dirty jersey!
TIL
VTCS stands for "Variable Tumble Control System" and was strictly added to help with cold start emissions regulations.
VICS stands for "Variable Inertial Charging System" and helps with power by using intake manifold resonance tuning to help force more air into the engine at a specific rpm range.
2003 has "Variable Tumble Control System" and looks like we do not really care about this system for track only applications.
https://forum.miata.net/vb/archive/index.php/t-428283.html
Here is 3O line (previous post had wrong pin, previous post removed)
They promise a record hot summer so I shall test A/C!
Compressor does not engage thus no chance to put gas into the system
Stefan says that thermal protector switch integrated into top of compressor is sometimes the reason for clutch not to get engaged but that's not the case on my vehicle
Stefan has a probably working compressor on his shelf and he is shipping that one to me next.
https://github.com/rusefi/rusefi/wiki/Images/2003_miata_ac.png
does your A/C have a pressure sensor switch?? all my commercial compressors do. If the freon level is too LOW, it will not turn on the compressor.
protects the compressor from Frying out.
Car was running bad even on stock ECU, P0301.
New cheap matching plugs installed, runs better on stock ECU now.
Bagging this set as "test set for when when we implement misfire detection" https://github.com/rusefi/rusefi/issues/936
Innovate 3844 MTX-L reads 22 AFR on OEM ECU idling, that's after maybe 45 minutes on brand new recalibrated sensor.
I am tired of this.
AEM 30-0300 X-Series purchased.
I am tired of this.
- Slack: Orchardperformance
That is certainly the correct answer.
It has been the long term result of everyone that has had an innovate.
Q: is this sensor bad?
Another day another board revision same trigger sync head banging
hellen72-rev D
hellen72-rev D
2021-07-09_17_40_18_412: EngineState: TRG rpm=0 time=69 eventIndex=4 gapIndex=0: gap=0.911 expected from 0.349 to 0.980 error=No
2021-07-09_17_40_18_516: EngineState: TRG rpm=0 time=69 eventIndex=0 gapIndex=0: gap=0.742 expected from 0.349 to 0.980 error=No
2021-07-09_17_40_18_518: EngineState: WARNING: trigger not happy current 1/0/0 expected 2/0/0
2021-07-09_17_40_18_520: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_40_18_609: EngineState: TRG rpm=0 time=70 eventIndex=0 gapIndex=0: gap=1.091 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_18_610: EngineState: TRG rpm=0 time=70 eventIndex=2 gapIndex=0: gap=0.771 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_18_730: EngineState: TRG rpm=0 time=70 eventIndex=0 gapIndex=0: gap=1.205 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_18_731: EngineState: TRG rpm=0 time=70 eventIndex=2 gapIndex=0: gap=0.783 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_18_811: EngineState: TRG rpm=0 time=70 eventIndex=0 gapIndex=0: gap=1.236 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_18_909: EngineState: TRG rpm=0 time=70 eventIndex=2 gapIndex=0: gap=0.789 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_18_910: EngineState: TRG rpm=0 time=70 eventIndex=0 gapIndex=0: gap=1.239 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_011: EngineState: TRG rpm=0 time=70 eventIndex=2 gapIndex=0: gap=0.791 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_109: EngineState: TRG rpm=0 time=70 eventIndex=0 gapIndex=0: gap=1.259 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_111: EngineState: TRG rpm=0 time=70 eventIndex=2 gapIndex=0: gap=0.782 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_221: EngineState: TRG rpm=0 time=70 eventIndex=0 gapIndex=0: gap=1.281 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_222: EngineState: TRG rpm=0 time=70 eventIndex=2 gapIndex=0: gap=0.785 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_309: EngineState: TRG rpm=256 time=70 eventIndex=0 gapIndex=0: gap=1.265 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_310: EngineState: TRG rpm=256 time=70 eventIndex=2 gapIndex=0: gap=0.789 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_410: EngineState: TRG rpm=256 time=70 eventIndex=0 gapIndex=0: gap=1.263 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_510: EngineState: TRG rpm=256 time=70 eventIndex=2 gapIndex=0: gap=0.789 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_512: EngineState: TRG rpm=256 time=70 eventIndex=0 gapIndex=0: gap=1.269 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_40_19_609: EngineState: TRG rpm=256 time=71 eventIndex=2 gapIndex=0: gap=0.786 expected from 0.349 to 0.980 error=No
2021-07-09_17_40_19_609: EngineState: TRG rpm=256 time=71 eventIndex=0 gapIndex=0: gap=1.280 expected from 0.349 to 0.980 error=No
2021-07-09_17_40_19_710: EngineState: TRG rpm=256 time=71 eventIndex=2 gapIndex=0: gap=0.789 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_14_898: EngineState: TRG rpm=0 time=126 eventIndex=2 gapIndex=0: gap=1158.480 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_14_986: EngineState: calc 0: action 103 value 128.12
2021-07-09_17_41_14_986: EngineState: calc 1: action 1 value 0.00
2021-07-09_17_41_14_987: EngineState: calc 2: action 5 value 1.00
2021-07-09_17_41_14_990: EngineState: calc 3: action 103 value 128.12
2021-07-09_17_41_14_995: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-07-09_17_41_14_999: EngineState: calc 5: action 2 value 0.00
2021-07-09_17_41_15_002: EngineState: calc 6: action 6 value 0.00
2021-07-09_17_41_15_005: EngineState: calc 7: action 127 value 0.02
2021-07-09_17_41_15_007: EngineState: calc 8: action 1 value 1.00
2021-07-09_17_41_15_011: EngineState: calc 9: action 2 value 1.00
2021-07-09_17_41_15_012: EngineState: calc 10: action 7 value 1.00
2021-07-09_17_41_15_015: EngineState: setPin pump on
2021-07-09_17_41_15_017: EngineState: TRG rpm=0 time=126 eventIndex=4 gapIndex=0: gap=0.010 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_191: EngineState: TRG rpm=0 time=126 eventIndex=6 gapIndex=0: gap=0.962 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_192: EngineState: TRG rpm=0 time=126 eventIndex=0 gapIndex=0: gap=0.657 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_15_193: EngineState: WARNING: trigger not happy current 1/0/0 expected 2/0/0
2021-07-09_17_41_15_194: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_15_292: EngineState: TRG rpm=0 time=126 eventIndex=0 gapIndex=0: gap=1.103 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_385: EngineState: TRG rpm=0 time=126 eventIndex=2 gapIndex=0: gap=0.783 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_385: EngineState: TRG rpm=0 time=126 eventIndex=0 gapIndex=0: gap=1.196 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_487: EngineState: TRG rpm=0 time=126 eventIndex=2 gapIndex=0: gap=0.786 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_489: EngineState: TRG rpm=0 time=126 eventIndex=0 gapIndex=0: gap=1.218 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_585: EngineState: TRG rpm=0 time=127 eventIndex=2 gapIndex=0: gap=0.798 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_685: EngineState: TRG rpm=0 time=127 eventIndex=0 gapIndex=0: gap=1.235 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_697: EngineState: TRG rpm=0 time=127 eventIndex=2 gapIndex=0: gap=0.791 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_785: EngineState: TRG rpm=0 time=127 eventIndex=0 gapIndex=0: gap=1.260 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_785: EngineState: TRG rpm=0 time=127 eventIndex=2 gapIndex=0: gap=0.796 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_892: EngineState: TRG rpm=0 time=127 eventIndex=0 gapIndex=0: gap=1.251 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_992: EngineState: TRG rpm=0 time=127 eventIndex=2 gapIndex=0: gap=0.797 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_15_992: EngineState: TRG rpm=249 time=127 eventIndex=0 gapIndex=0: gap=1.244 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_086: EngineState: TRG rpm=249 time=127 eventIndex=2 gapIndex=0: gap=0.807 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_086: EngineState: TRG rpm=249 time=127 eventIndex=0 gapIndex=0: gap=0.782 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_087: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_16_089: EngineState: TRG rpm=249 time=127 eventIndex=0 gapIndex=0: gap=0.435 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_101: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_16_185: EngineState: TRG rpm=249 time=127 eventIndex=0 gapIndex=0: gap=1.649 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_185: EngineState: TRG rpm=249 time=127 eventIndex=2 gapIndex=0: gap=0.701 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_186: EngineState: TRG rpm=249 time=127 eventIndex=0 gapIndex=0: gap=1.692 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_285: EngineState: TRG rpm=249 time=127 eventIndex=2 gapIndex=0: gap=0.736 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_285: EngineState: TRG rpm=249 time=127 eventIndex=0 gapIndex=0: gap=1.706 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_286: EngineState: TRG rpm=249 time=127 eventIndex=2 gapIndex=0: gap=0.924 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_389: EngineState: TRG rpm=249 time=127 eventIndex=0 gapIndex=0: gap=1.070 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_390: EngineState: TRG rpm=249 time=127 eventIndex=2 gapIndex=0: gap=0.456 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_391: EngineState: TRG rpm=270 time=127 eventIndex=0 gapIndex=0: gap=1.666 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_485: EngineState: TRG rpm=270 time=127 eventIndex=2 gapIndex=0: gap=0.711 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_507: EngineState: TRG rpm=270 time=127 eventIndex=0 gapIndex=0: gap=1.712 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_507: EngineState: TRG rpm=270 time=127 eventIndex=2 gapIndex=0: gap=0.773 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_585: EngineState: TRG rpm=270 time=128 eventIndex=0 gapIndex=0: gap=1.731 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_586: EngineState: TRG rpm=270 time=128 eventIndex=2 gapIndex=0: gap=0.629 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_691: EngineState: TRG rpm=270 time=128 eventIndex=0 gapIndex=0: gap=1.673 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_692: EngineState: TRG rpm=270 time=128 eventIndex=2 gapIndex=0: gap=0.763 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_785: EngineState: TRG rpm=372 time=128 eventIndex=0 gapIndex=0: gap=1.503 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_885: EngineState: TRG rpm=372 time=128 eventIndex=2 gapIndex=0: gap=0.792 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_885: EngineState: TRG rpm=372 time=128 eventIndex=0 gapIndex=0: gap=1.359 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_16_988: EngineState: TRG rpm=372 time=128 eventIndex=2 gapIndex=0: gap=1.364 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_086: EngineState: TRG rpm=372 time=128 eventIndex=4 gapIndex=0: gap=0.875 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_087: EngineState: error: synchronizationPoint @ index 4 expected 2/0/0 got 3/0/0
2021-07-09_17_41_17_186: EngineState: TRG rpm=372 time=128 eventIndex=0 gapIndex=0: gap=0.654 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_186: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_17_187: EngineState: TRG rpm=372 time=128 eventIndex=0 gapIndex=0: gap=1.379 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_291: EngineState: TRG rpm=372 time=128 eventIndex=2 gapIndex=0: gap=0.784 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_385: EngineState: TRG rpm=211 time=128 eventIndex=0 gapIndex=0: gap=1.227 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_386: EngineState: TRG rpm=211 time=128 eventIndex=2 gapIndex=0: gap=0.799 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_484: EngineState: TRG rpm=211 time=128 eventIndex=0 gapIndex=0: gap=1.216 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_590: EngineState: TRG rpm=211 time=128 eventIndex=2 gapIndex=0: gap=0.785 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_620: EngineState: TRG rpm=211 time=129 eventIndex=0 gapIndex=0: gap=1.258 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_688: EngineState: TRG rpm=211 time=129 eventIndex=2 gapIndex=0: gap=0.804 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_688: EngineState: TRG rpm=211 time=129 eventIndex=0 gapIndex=0: gap=0.857 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_689: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_17_786: EngineState: TRG rpm=271 time=129 eventIndex=0 gapIndex=0: gap=0.352 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_787: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_17_787: EngineState: TRG rpm=271 time=129 eventIndex=0 gapIndex=0: gap=1.645 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_790: EngineState: TRG rpm=271 time=129 eventIndex=2 gapIndex=0: gap=0.701 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_815: EngineState: TRG rpm=271 time=129 eventIndex=0 gapIndex=0: gap=1.684 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_885: EngineState: TRG rpm=271 time=129 eventIndex=2 gapIndex=0: gap=0.729 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_886: EngineState: TRG rpm=271 time=129 eventIndex=0 gapIndex=0: gap=1.217 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_886: EngineState: TRG rpm=271 time=129 eventIndex=2 gapIndex=0: gap=0.511 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_887: EngineState: TRG rpm=271 time=129 eventIndex=0 gapIndex=0: gap=1.645 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_988: EngineState: TRG rpm=271 time=129 eventIndex=2 gapIndex=0: gap=0.690 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_989: EngineState: TRG rpm=561 time=129 eventIndex=0 gapIndex=0: gap=1.683 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_990: EngineState: TRG rpm=561 time=129 eventIndex=2 gapIndex=0: gap=0.732 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_17_990: EngineState: TRG rpm=561 time=129 eventIndex=0 gapIndex=0: gap=1.692 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_086: EngineState: TRG rpm=561 time=129 eventIndex=2 gapIndex=0: gap=0.778 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_086: EngineState: TRG rpm=561 time=129 eventIndex=0 gapIndex=0: gap=1.383 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_087: EngineState: TRG rpm=561 time=129 eventIndex=2 gapIndex=0: gap=0.471 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_189: EngineState: TRG rpm=561 time=129 eventIndex=0 gapIndex=0: gap=1.668 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_189: EngineState: TRG rpm=561 time=129 eventIndex=2 gapIndex=0: gap=0.705 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_190: EngineState: TRG rpm=528 time=129 eventIndex=0 gapIndex=0: gap=1.702 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_190: EngineState: TRG rpm=528 time=129 eventIndex=2 gapIndex=0: gap=0.769 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_285: EngineState: TRG rpm=528 time=129 eventIndex=0 gapIndex=0: gap=1.726 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_285: EngineState: TRG rpm=528 time=129 eventIndex=2 gapIndex=0: gap=0.919 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_385: EngineState: TRG rpm=528 time=129 eventIndex=0 gapIndex=0: gap=1.029 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_385: EngineState: TRG rpm=528 time=129 eventIndex=2 gapIndex=0: gap=0.438 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_386: EngineState: TRG rpm=528 time=129 eventIndex=0 gapIndex=0: gap=1.663 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_490: EngineState: TRG rpm=528 time=129 eventIndex=2 gapIndex=0: gap=0.706 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_490: EngineState: TRG rpm=419 time=129 eventIndex=0 gapIndex=0: gap=1.713 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_491: EngineState: TRG rpm=419 time=129 eventIndex=2 gapIndex=0: gap=0.780 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_586: EngineState: TRG rpm=419 time=130 eventIndex=0 gapIndex=0: gap=1.766 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_691: EngineState: TRG rpm=419 time=130 eventIndex=2 gapIndex=0: gap=0.931 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_692: EngineState: TRG rpm=419 time=130 eventIndex=0 gapIndex=0: gap=0.946 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_692: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_18_693: EngineState: TRG rpm=419 time=130 eventIndex=0 gapIndex=0: gap=0.426 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_693: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_18_786: EngineState: TRG rpm=470 time=130 eventIndex=0 gapIndex=0: gap=1.665 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_787: EngineState: TRG rpm=470 time=130 eventIndex=2 gapIndex=0: gap=0.718 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_787: EngineState: TRG rpm=470 time=130 eventIndex=0 gapIndex=0: gap=1.728 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_889: EngineState: TRG rpm=470 time=130 eventIndex=2 gapIndex=0: gap=0.804 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_890: EngineState: TRG rpm=470 time=130 eventIndex=0 gapIndex=0: gap=1.826 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_987: EngineState: TRG rpm=470 time=130 eventIndex=2 gapIndex=0: gap=0.789 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_18_988: EngineState: TRG rpm=470 time=130 eventIndex=0 gapIndex=0: gap=1.264 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_085: EngineState: TRG rpm=470 time=130 eventIndex=2 gapIndex=0: gap=0.795 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_195: EngineState: TRG rpm=470 time=130 eventIndex=0 gapIndex=0: gap=1.274 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_196: EngineState: TRG rpm=470 time=130 eventIndex=2 gapIndex=0: gap=0.793 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_289: EngineState: TRG rpm=243 time=130 eventIndex=0 gapIndex=0: gap=1.268 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_290: EngineState: TRG rpm=243 time=130 eventIndex=2 gapIndex=0: gap=0.804 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_385: EngineState: TRG rpm=243 time=130 eventIndex=0 gapIndex=0: gap=1.257 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_495: EngineState: TRG rpm=243 time=130 eventIndex=2 gapIndex=0: gap=0.804 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_495: EngineState: TRG rpm=243 time=130 eventIndex=0 gapIndex=0: gap=0.849 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_496: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_19_496: EngineState: TRG rpm=243 time=130 eventIndex=0 gapIndex=0: gap=0.430 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_497: EngineState: error: synchronizationPoint @ index 0 expected 2/0/0 got 1/0/0
2021-07-09_17_41_19_587: EngineState: TRG rpm=391 time=130 eventIndex=0 gapIndex=0: gap=1.662 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_587: EngineState: TRG rpm=391 time=131 eventIndex=2 gapIndex=0: gap=0.710 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_588: EngineState: TRG rpm=391 time=131 eventIndex=0 gapIndex=0: gap=1.710 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_685: EngineState: TRG rpm=391 time=131 eventIndex=2 gapIndex=0: gap=0.771 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_686: EngineState: TRG rpm=391 time=131 eventIndex=0 gapIndex=0: gap=1.764 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_785: EngineState: TRG rpm=391 time=131 eventIndex=2 gapIndex=0: gap=0.825 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_786: EngineState: TRG rpm=391 time=131 eventIndex=0 gapIndex=0: gap=1.428 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_889: EngineState: TRG rpm=391 time=131 eventIndex=2 gapIndex=0: gap=0.784 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_890: EngineState: TRG rpm=391 time=131 eventIndex=0 gapIndex=0: gap=1.271 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_988: EngineState: TRG rpm=391 time=131 eventIndex=2 gapIndex=0: gap=0.790 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_19_989: EngineState: TRG rpm=264 time=131 eventIndex=0 gapIndex=0: gap=1.294 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_085: EngineState: TRG rpm=264 time=131 eventIndex=2 gapIndex=0: gap=0.796 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_185: EngineState: TRG rpm=264 time=131 eventIndex=0 gapIndex=0: gap=1.261 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_186: EngineState: TRG rpm=264 time=131 eventIndex=2 gapIndex=0: gap=0.802 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_285: EngineState: TRG rpm=264 time=131 eventIndex=0 gapIndex=0: gap=1.073 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_286: EngineState: TRG rpm=264 time=131 eventIndex=2 gapIndex=0: gap=0.606 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_388: EngineState: TRG rpm=264 time=131 eventIndex=0 gapIndex=0: gap=1.790 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_388: EngineState: TRG rpm=264 time=131 eventIndex=2 gapIndex=0: gap=0.802 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_487: EngineState: TRG rpm=274 time=131 eventIndex=0 gapIndex=0: gap=1.332 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_487: EngineState: TRG rpm=274 time=131 eventIndex=2 gapIndex=0: gap=0.794 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_20_586: EngineState: TRG rpm=274 time=132 eventIndex=0 gapIndex=0: gap=1.251 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_20_689: EngineState: TRG rpm=274 time=132 eventIndex=2 gapIndex=0: gap=0.801 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_20_689: EngineState: TRG rpm=274 time=132 eventIndex=0 gapIndex=0: gap=1.254 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_20_789: EngineState: TRG rpm=274 time=132 eventIndex=2 gapIndex=0: gap=0.801 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_20_789: EngineState: TRG rpm=274 time=132 eventIndex=0 gapIndex=0: gap=1.260 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_20_889: EngineState: TRG rpm=274 time=132 eventIndex=2 gapIndex=0: gap=0.802 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_20_992: EngineState: TRG rpm=253 time=132 eventIndex=0 gapIndex=0: gap=1.253 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_20_994: EngineState: TRG rpm=253 time=132 eventIndex=2 gapIndex=0: gap=0.806 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_087: EngineState: TRG rpm=253 time=132 eventIndex=0 gapIndex=0: gap=1.247 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_088: EngineState: TRG rpm=253 time=132 eventIndex=2 gapIndex=0: gap=0.809 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_189: EngineState: TRG rpm=253 time=132 eventIndex=0 gapIndex=0: gap=1.228 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_289: EngineState: TRG rpm=253 time=132 eventIndex=2 gapIndex=0: gap=0.807 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_289: EngineState: TRG rpm=253 time=132 eventIndex=0 gapIndex=0: gap=1.246 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_389: EngineState: TRG rpm=253 time=132 eventIndex=2 gapIndex=0: gap=0.804 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_426: EngineState: TRG rpm=247 time=132 eventIndex=0 gapIndex=0: gap=1.244 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_486: EngineState: TRG rpm=247 time=132 eventIndex=2 gapIndex=0: gap=0.809 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_585: EngineState: TRG rpm=247 time=133 eventIndex=0 gapIndex=0: gap=1.240 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_586: EngineState: TRG rpm=247 time=133 eventIndex=2 gapIndex=0: gap=0.811 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_686: EngineState: TRG rpm=247 time=133 eventIndex=0 gapIndex=0: gap=1.237 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_789: EngineState: TRG rpm=247 time=133 eventIndex=2 gapIndex=0: gap=1.698 expected from 0.349 to 0.980 error=No
2021-07-09_17_41_21_997: EngineState: TRG rpm=247 time=133 eventIndex=4 gapIndex=0: gap=1.361 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_22_086: EngineState: TRG rpm=247 time=133 eventIndex=6 gapIndex=0: gap=0.600 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_22_087: EngineState: error: synchronizationPoint @ index 6 expected 2/0/0 got 4/0/0
2021-07-09_17_41_22_087: EngineState: TRG rpm=247 time=133 eventIndex=0 gapIndex=0: gap=0.150 expected from 0.349 to 0.980 error=Yes
2021-07-09_17_41_22_606: EngineState: engine has STOPPED
2021-07-09_17_41_22_607: EngineState: templog engine has STOPPED 0.539083003
2021-07-09_17_41_22_610: EngineState: trigger PAL mode 1
2021-07-09_17_41_22_613: EngineState: Template HELLEN_NB2 (69) trigger TT_MIATA_VVT (33) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=715.00
2021-07-09_17_41_22_643: EngineState: trigger#1 event counters up=0/down=257
2021-07-09_17_41_22_646: EngineState: expected cycle events 2/0/0
2021-07-09_17_41_22_649: EngineState: trigger type=33/need2ndChannel=No
2021-07-09_17_41_22_650: EngineState: expected duty #0=0.38/#1=0.00
Latest firmware car starts on H72 rev C without foot on the pedal, warnings are constantly going up.
https://rusefi.com/online/view.php?msq=581
https://rusefi.com/online/view.php?log=284
Note that the picture above does not look great in terms of coil events being uneven. Picture in the post above matches the problematic images on JimStim see https://github.com/rusefi/rusefi/issues/2980
eBay seems to have two similar but differently fabricated revision of the wheel. "miata trigger wheel" search query.
I assume metal shape difference does not really matter but does it support the non-Hall nature of the actual sensor?
Car still starts without throttle application but something is different/wrong with idle: after starts there is a huge swing in RPM for a couple of times, this was not happening before, cranking to idle transition was smoother
https://rusefi.com/online/view.php?msq=599
https://rusefi.com/online/view.php?log=300
Current hellen72 defaults are not great on my vehicle in terms of no-foot-cold-start
https://rusefi.com/online/view.php?msq=653
https://rusefi.com/online/view.php?log=351
and log to tune auto-match seems to be broken
If you have to apply pedal to get it to cold start try either removing some fuel or adding some IAC. This is often an issue that the AFR is too rich on cold start or the engine overall needs more air for decent cylinder filling for starting.
Had a look at the logs, you seem to be cranking until you build up enough fuel to start.
Try setting your "fuel base mass (mg)" to about 35 and try again. I will take another look at the log once you have had a chance to try that one change.
I think most of the other settings are good enough, it just wants more fuel.
Surprise! Two hours of my life on the altar of tandem garage tetris.
This miata does not like to start with a weak battery. Too many revolutions until we start to fire up due to VVT having extra cranking requirment?
https://rusefi.com/online/view.php?log=970
https://github.com/rusefi/rusefi/issues/4413
hello k-line
I have an unhealthy obsession with Geehy apm32 products. Well, no: my custom Proteus did not start a car. USB works, SD card writes logs, ADC seems to show reasonable values - but no input capture on the real vehicle. No time to investigate further, there is a chance of soldering issue on this hand-build board.
https://rusefi.com/online/view.php?log=1210
I got a reply from the FAE: APM has NVIC with 8 levels, STM has 16 levels.
One very obvious problem we found is that the ADC calibration in system memory is missing. (non existent)
on the other hand, however:
APM32F4xxx User_Manual_V1.6:
programmable priority levels
A version: 8 priority levels (3-bit interrupt priority level could be used)
C version: 16 priority levels (4-bit interrupt priority level could be used)
To check the rev.: Device ID register (DBGMCU_IDCODE)
Wafer Version Recognition
This domain identifies wafer information APM32F407/417 series products
Version A: 0x1000
Version Z: 0x1001
Version 1: 0x1003
Version 2: 0x1007
Version Y and 4: 0x100F
Version 5 and 6: 0x101F
В модуле Reset and Clock (RCM) (для STM32 это RCC) добавили бит включения тактирования FPU - RCM->AHB2CLKEN, бит с номером 1.
Только такое ощущение, что этот бит ни на что не влияет. Пробовал и выставлять его, пробовал и не выставлять - плавучка одинаково считается.
Aaaaaaand SOLD. End of an era!
