wiring diagrams
A is RH bank drivers side , B is LH bank as viewed from the front.
put ETB 1 on drivers side bank
ETB
Pin Wire Color Description
A BRN Throttle Actuator Motor Control
B YEL Throttle Actuator Motor Control
C TAN Ground
D DK GRN TPS 1 Signal
E GRY 5 Volts
F PPL TPS 2 Signal
COIL on plug MAZDA
right hand to left hand when staring at the connector on the coil
a-- 12V
b-- trigger
c-- ion sense
d-- ground
PROTEUS WIRING
analog volt 1 -->MAP
" " 2 --> ETB 1A
' ' 3 --> ETB 1B
" " 4 --> ETB 2A
" " 5--> ETB 2 B
" " 6--> pedal A
" " 7--> pedal B
gas pedal from Ford Fusion
second pic
- mazda coil on plug wiring skyactiv.gif (21.9 KiB) Viewed 8760 times
- ford fusion gas pedal wiring.jpg (116.15 KiB) Viewed 8760 times
