Golf Mk2 Rust bucket with 1.8T 20V engine swap
nyl
Slack: NYL
Post by nyl »
Hey,
My name is Laurentiu and i'm from Romania, I'm a Systems Engineer that works as telecomunications engineer :p
I want to show you my test mule
Golf Mk2 originally 1.8 8v Monojetronic soon to start swapping in the 1.8T engine :)
Will add DB25 or DB37 connectors so i can test multiple ECUS and have cheap plug n play solution for swaping ecu's. The car will run MRE as main ECU and another board under development that I will not mention here (maybe will try Proteus also)
Re: Golf Mk2 Rust bucket with 1.8T 20V engine swap
1.8T?
That sounds like https://rusefi.com/forum/viewtopic.php?p=39606#p39606 we hope to have first prototypes in about 5 weeks.
nyl
Slack: NYL
Post by nyl »
Thanks for info, I posted there some pinouts from ME 7.5 plugnplay ECU that i'm using on the Skoda 1.8T big turbo build
I would like to suggest using a real harness connector then make an adapter for db15 db37. Those db connectors have problems relative to automotive applications.
Simon@FutureProof
Slack: Orchardperformance
Post by Simon@FutureProof »
Yep, those DB37 connectors do not like being in an auto environment for too long,
